1 | /*----------------------------------------------------------------------------
2 | Copyright: Radig Ulrich mailto: mail@ulrichradig.de
3 | Author: Radig Ulrich
4 | Remarks:
5 | known Problems: none
6 | Version: 14.06.2007
7 | Description: RS232 Routinen
8 | ----------------------------------------------------------------------------*/
9 |
10 | #include "usart.h"
11 |
12 | volatile unsigned char buffercounter = 0;
13 | char usart_rx_buffer[BUFFER_SIZE];
14 |
15 | //----------------------------------------------------------------------------
16 | //Init serielle Schnittstelle
17 | void usart_init(unsigned int baudrate)
18 | {
19 | //Enable TXEN im Register UCR TX-Data Enable
20 | UCR =(1 << TXEN | 1 << RXEN | 1<< RXCIE);
21 | //Teiler wird gesetzt
22 | UBRR=(SYSCLK / (baudrate * 16L) - 1);
23 | }
24 |
25 | //----------------------------------------------------------------------------
26 | //Routine für die Serielle Ausgabe eines Zeichens
27 | void usart_write_char(char c)
28 | {
29 | if (c == '\n')
30 | usart_write_char('\r');
31 | //Warten solange bis Zeichen gesendet wurde
32 | while(!(USR & (1<<UDRE)));
33 | //Ausgabe des Zeichens
34 | UDR = c;
35 | return;
36 | }
37 |
38 | //------------------------------------------------------------------------------
39 | void usart_write_P (const char *Buffer,...)
40 | {
41 | va_list ap;
42 | va_start (ap, Buffer);
43 |
44 | int format_flag;
45 | char str_buffer[10];
46 | char str_null_buffer[10];
47 | char move = 0;
48 | char Base = 0;
49 | int tmp = 0;
50 | char by;
51 | char *ptr;
52 |
53 | //Ausgabe der Zeichen
54 | for(;;)
55 | {
56 | by = pgm_read_byte(Buffer++);
57 | if(by==0) break; // end of format string
58 |
59 | if (by == '%')
60 | {
61 | by = pgm_read_byte(Buffer++);
62 | if (isdigit(by)>0)
63 | {
64 |
65 | str_null_buffer[0] = by;
66 | str_null_buffer[1] = '\0';
67 | move = atoi(str_null_buffer);
68 | by = pgm_read_byte(Buffer++);
69 | }
70 |
71 | switch (by)
72 | {
73 | case 's':
74 | ptr = va_arg(ap,char *);
75 | while(*ptr) { usart_write_char(*ptr++); }
76 | break;
77 | case 'b':
78 | Base = 2;
79 | goto ConversionLoop;
80 | case 'c':
81 | //Int to char
82 | format_flag = va_arg(ap,int);
83 | usart_write_char (format_flag++);
84 | break;
85 | case 'i':
86 | Base = 10;
87 | goto ConversionLoop;
88 | case 'o':
89 | Base = 8;
90 | goto ConversionLoop;
91 | case 'x':
92 | Base = 16;
93 | //****************************
94 | ConversionLoop:
95 | //****************************
96 | itoa(va_arg(ap,int),str_buffer,Base);
97 | int b=0;
98 | while (str_buffer[b++] != 0){};
99 | b--;
100 | if (b<move)
101 | {
102 | move -=b;
103 | for (tmp = 0;tmp<move;tmp++)
104 | {
105 | str_null_buffer[tmp] = '0';
106 | }
107 | //tmp ++;
108 | str_null_buffer[tmp] = '\0';
109 | strcat(str_null_buffer,str_buffer);
110 | strcpy(str_buffer,str_null_buffer);
111 | }
112 | usart_write_str (str_buffer);
113 | move =0;
114 | break;
115 | }
116 |
117 | }
118 | else
119 | {
120 | usart_write_char ( by );
121 | }
122 | }
123 | va_end(ap);
124 | }
125 |
126 | //----------------------------------------------------------------------------
127 | //Ausgabe eines Strings
128 | void usart_write_str(char *str)
129 | {
130 | while (*str)
131 | {
132 | usart_write_char(*str++);
133 | }
134 | }
135 |
136 | //Empfang eines Zeichens
137 | ISR(USART_RXC_vect)
138 | {
139 | PORTC &= ~ (1<<PC1); // Zur überprüfung ob ISR überhaupt aufgerufen wird
140 | /* unsigned char receive_char;
141 | receive_char = (UDR);
142 |
143 | if (usart_status.usart_ready)
144 | {
145 | usart_status.usart_rx_ovl = 1;
146 | return;
147 | }
148 |
149 | if (receive_char == 13 && (!(usart_rx_buffer[buffercounter-1] == '\\')))
150 | {
151 |
152 | usart_rx_buffer[buffercounter] = 0;
153 | buffercounter = 0;
154 | usart_status.usart_ready = 1;
155 | return;
156 | }
157 |
158 | if (buffercounter < BUFFER_SIZE - 1)
159 | {
160 | usart_rx_buffer[buffercounter++] = receive_char;
161 | }
162 | return; */
163 | }
