As first exercise with FT245 I would to turn on two LEDs. So I wrote the following code [taken from this forum and adapted]. The software compiles but the LEDs keep on turned off...except for that one connected to DB1 pin of FT245 (that is always ON...). Here it is the code: // FTDI.cpp : Defines the entry point for the console application. //#include "stdafx.h" #include <windows.h> #include <stdio.h> #include "ftd2xx.h" typedef unsigned char UCHAR; FT_HANDLE fthandle; FT_STATUS status; void Reload() { FT_Reload(0403,6010); FT_Rescan(); Sleep(1000); // Open device #0 and save in handle variable the task handle status = FT_Open(0, &fthandle); // Try again the open if previuos opening failed while( status != 0) { status = FT_Open(0, &fthandle); } // Prints a message printf("[OK] Device successfully opened...\n"); } int main(int argc, char* argv[]) { Reload(); /************************************************************/ // Reset status = FT_ResetDevice(fthandle); if(status == FT_OK) { printf("[OK] Device reset...\n"); //Reload(); } else printf ( "Error!\n"); /************************************************************/ // Timeout DWORD rTimeout=1000; DWORD wTimeout=1000; status = FT_SetTimeouts(fthandle,rTimeout,wTimeout); if(status == FT_OK) { printf("[OK] Read/Write timeout successfully set to %d/%d (ms)...\n", rTimeout, wTimeout); //Reload(); } else printf ("Error!\n"); /************************************************************/ // Baudrate status = FT_SetBaudRate(fthandle, 9600); if(status == FT_OK) { printf("[OK] Baudrate set to 9600..\n"); //Reload(); } /************************************************************/ // Make a reset UCHAR mask = 0xFF; // pin all to output UCHAR mode = 0; // reset code status = FT_SetBitMode(fthandle, mask, mode); if(status == FT_OK) { printf("[OK] Device Reset...\n"); } else printf ("Error!\n"); /************************************************************/ // Set asincron bit-bang mask = 0xFF; mode = 1; status = FT_SetBitMode(fthandle, mask, mode); if(status == FT_OK) { printf("[OK] Set asyncron mode...\n"); } else printf ("Error!\n"); /************************************************************/ // Write DWORD byteWritten = 0; UCHAR buffer[] = { 128 }; // Turn on LED #2 and LED #8 status = FT_Write (fthandle, buffer, 1, &byteWritten); if(status == FT_OK) { printf("[OK] Data wrote successfully...\n"); } else printf ("Error!\n"); /************************************************************/ // Close FT_Close(fthandle); return 0; }
