1 | ;***************************************************************************
2 | ;*
3 | ;* "mpy16u" - 16x16 Bit Unsigned Multiplication
4 | ;*
5 | ;* This subroutine multiplies the two 16-bit register variables
6 | ;* mp16uH:mp16uL and mc16uH:mc16uL.
7 | ;* The result is placed in m16u3:m16u2:m16u1:m16u0.
8 | ;*
9 | ;* Number of words :14 + return
10 | ;* Number of cycles :153 + return
11 | ;* Low registers used :None
12 | ;* High registers used :7 (mp16uL,mp16uH,mc16uL/m16u0,mc16uH/m16u1,m16u2,
13 | ;* m16u3,mcnt16u)
14 | ;*
15 | ;***************************************************************************
16 |
17 | ;***** Subroutine Register Variables
18 |
19 | .def mc16uL =r16 ;multiplicand low byte
20 | .def mc16uH =r17 ;multiplicand high byte
21 | .def mp16uL =r18 ;multiplier low byte
22 | .def mp16uH =r19 ;multiplier high byte
23 | .def m16u0 =r18 ;result byte 0 (LSB)
24 | .def m16u1 =r19 ;result byte 1
25 | .def m16u2 =r20 ;result byte 2
26 | .def m16u3 =r21 ;result byte 3 (MSB)
27 | .def mcnt16u =r22 ;loop counter
28 |
29 | ;***** Code
30 |
31 | mpy16u: clr m16u3 ;clear 2 highest bytes of result
32 | clr m16u2
33 | ldi mcnt16u,16 ;init loop counter
34 | lsr mp16uH
35 | ror mp16uL
36 |
37 | m16u_1: brcc noad8 ;if bit 0 of multiplier set
38 | add m16u2,mc16uL ;add multiplicand Low to byte 2 of res
39 | adc m16u3,mc16uH ;add multiplicand high to byte 3 of res
40 | noad8: ror m16u3 ;shift right result byte 3
41 | ror m16u2 ;rotate right result byte 2
42 | ror m16u1 ;rotate result byte 1 and multiplier High
43 | ror m16u0 ;rotate result byte 0 and multiplier Low
44 | dec mcnt16u ;decrement loop counter
45 | brne m16u_1 ;if not done, loop more
46 | ret
