Ich versuche mit Printf_P Strings über den Uart auszugeben, hatte damit aber bislang nur wenig Erfolg. Das Ganze soll interruptgesteuert und gepuffert ablaufen. Hoffentlich kann mir hier jemand noch einen Rat geben wo der Fehler steckt... Ich benutze WinAVR-20030913 und AVR Studio 4.07 und folgenden Code: #include <avr/io.h> #include <avr/signal.h> #include <avr/interrupt.h> #include <stdio.h> #include <avr/pgmspace.h> #define UART_BUF_SIZE 40 char character = 'H'; char string[] = "ello World!"; /* uart globals */ volatile unsigned char uart_txd_buf_cnt; volatile unsigned char *uart_txd_in_ptr, *uart_txd_out_ptr; volatile unsigned char uart_txd_buffer[UART_BUF_SIZE]; SIGNAL(SIG_UART0_DATA) /* signal handler for uart data buffer empty interrupt */ { if (uart_txd_buf_cnt > 0) { outp(*uart_txd_out_ptr, UDR0); /* write byte to data buffer */ if (++uart_txd_out_ptr >= uart_txd_buffer + UART_BUF_SIZE) /* Pointer wrapping */ uart_txd_out_ptr = uart_txd_buffer; if(--uart_txd_buf_cnt == 0) /* if buffer is empty: */ cbi(UCSR0B, UDRIE0); /* disable UDRIE int */ } } int uart_putchar(char c) { if (uart_txd_buf_cnt<UART_BUF_SIZE) { cli(); uart_txd_buf_cnt++; *uart_txd_in_ptr = c; /* put character into buffer */ if (++uart_txd_in_ptr >= uart_txd_buffer + UART_BUF_SIZE) /* pointer wrapping */ uart_txd_in_ptr = uart_txd_buffer; sbi(UCSR0B, UDRIE0); /* enable UDRIE int */ sei(); return 0; } else return 1; /* buffer is full */ } unsigned char uart_putstr(char s[]) { char *c = s; while (PRG_RDB(c)) if (0 == uart_putchar(PRG_RDB(c))) c++; return 0; } int main(void) { /* initialize uart */ // USART initialization // Communication Parameters: 8 Data, 1 Stop, No Parity // USART Receiver: On // USART Transmitter: On // USART Baud rate: 38400 UCSR0A=0x00; UCSR0B=((1<<RXCIE) | (1<<RXEN) | (1<<TXEN)); // USART Mode: Asynchronous UCSR0C=0x86; UBRR0L=0x19; UBRR0H=0x00; uart_txd_in_ptr = uart_txd_out_ptr = uart_txd_buffer; uart_txd_buf_cnt = 0; fdevopen(uart_putchar,NULL,0); sei(); printf_P(character); printf_P(string); while (1) { }; return 0; }
Ähem, was ist eigentlich Dein Problem dabei? Und: a) simulierst Du nur, oder b) testest Du an echter Hardware? Wenn a), womit dann? Falls AVR Studio 4.07, dann bitte upgrade auf 4.08beta. Wenn b), hast Du daran gedacht, daß USART0 auf dem ATmega128 mit der ISP-Schnittstelle kollidiert?
Ich arbeite jetzt mit AVR Studio Version 4.08 Build 291 auf Win2000. Mit dem JTAG ICE lade ich das Programm in den Flash Speicher und lasse es dort mit dem JTAG ICE laufen. Seit ich das neue AVR Studio verwende funktioniert die Stringausgabe aus dem Flash Speicher. Ich musste nur noch diese Zeilen ändern: char character PROGMEM = 'H'; char string[] PROGMEM = "ello World!"; ... printf_P(PSTR("%c"),character); Vielen Dank Heiko
Ich habe auch kleine Probleme mit meinem Uart am Mega128 - ist das oben der komplette Quelltext? - kann ich das zum Test auch benutzen.
