Sorry for language, I hope you will understand. For those who use 8051 and like programming in Pascal please take a look at Turbo51 - a free Pascal compiler for the 8051 family of microcontrollers: http://turbo51.com It features a fast single pass optimizing compiler, Borland Turbo Pascal 7 syntax, full floating point support, mixed pascal and assembler programming, full use of register banks, advanced multi-pass optimizer, smart linker, generates compact high quality code, output formats include binary, Intel HEX, OMF-51 and assembler source. Source level debugging possible with extended absolute object file. Give it a try!
Hi funa, I already found turbo51 but missing a reasonable documentation it's very hard to get started with it. Will it work with a 8052 without external RAM? I guess I've got to search the demos about that. Eventually I will try to feed your doc-pages through Acrobat and test the result. For the moment: Thanks for great work! But still a lot of work is waiting ;-). Guido
I already discovered your site a few days ago. The pascal comppiler looks promising, and I'll probably try it out once I'ver built myself a suitable piece of hardware - have been mostly using AVRs recently, but since I started programming with Turbo Pascal, and working with microcontrollers with the 80C535, this could make for a nice "back to the roots" experience. If I like it, I might possibly use it in real-world applications - An AT98S52 doesn't cost much more than an ATtiny2313, after all. By the way, is there any bootloader support, enabling the programmer to write code that doesn't start at address 0 and such?
Hello everybody, Regarding the docs: I will prepare a PDF document with complete documentation immediately after I will finish some urgent features I would like to implement, like OMF object file import and various calling conventions (to use existing libraries written in C). If you are familiar with Turbo Pascal then you should be also familiar with Turbo51. The syntax is VERY similar (almost identical). If there is ANY particular question or problem feel free to ask, please use Turbo51 contact page. Regarding code that doesn't start at address 0: I am already working on this, if somebody is interested for a demo version with this feature please go to Turbo51 contact page and send me a mail. Igor
A really interesting compiler. But it would be even much greater, if you also AVR-uC could be supported..!
Too many advertising links all over the pages makes turbo51.com hardly useable.
I am sorry if ads cause trouble to you. I am offering the compiler for free. Therefore I have to find some other source of income.
Regarding support for AVR microcontrollers: Turbo51 is a Pascal compiler dedicated to 8051 microcontrollers (Silabs, NXP, Atmel,...). It is very tightly connected to 8051 specific features. After I will finish it I will reconsider a compiler for AVR. But the AVR future is not clear now. Read this information: http://www.atmel.com/corporate/documents/SLL_Customer_Letter.pdf http://www.atmel.com/dyn/corporate/view_detail.asp?FileName=Micro_ON_10_2.html
1 | By the way, is there any bootloader support, enabling the programmer to |
2 | write code that doesn't start at address 0 and such? |
Now with Turbo51 version 0.1.3.2 it is possible. See doc pages for details.
moin moin, funktioniert ja schon ganz gut:-( "otschen charascho" Nur meinen Record will er nicht :-) 111: Achse = Record 112: Step : Integer; 113: Bres : LongInt; 114: isLeading : Boolean; 115: Sig : Byte; 116: End; (* Turbo51 version 0.1.3.2, Copyright 2000 - 2008 Igor Funa TEST.PAS (114): Error 220: Boolean fields are not allowed. isLeading : Boolean;(*Byte;*) ^ *) In Delphi und in meinem Macroassembler geht das so. Mit Gruß Pieter
Boolean variables use BIT (boolean) memory in 8051. If you would like to use boolean variables in DATA or XDATA memory (or even in CODE memory as typed constant) then you have two possibilities: 1) use type ByteBool (WordBool and LongBool are also possible), this will occupy one byte (or 2 for WordBool and 4 for LongBool) 2) use sets. See some examples at http://turbo51.com/documentation/8051-pascal-inline-procedures Each set element can be boolean variable and will occupy only one bit in DATA or XDATA memory, you have 8 boolean variables in on byte. Hope this answers your question. You can use the contact form on Turbo51 site for the fastest response on any problem or question.
Just a reminder for all those who have used Turbo51 before version 0.1.3.2 and now have some trouble using the latest version: In version 0.1.3.2 the syntax for $M directive was changed (to be able to set CODE memory start address). Compiler directive $M has now syntax
1 | {$M <CODE Start>, <CODE Size>, <XDATA Start>, <XDATA Size>, <Heap Size> } |
Please make sure the $M directive is updated with the new syntax.
