Hallo, ich arbeite mich gerade in OrCAD 16.0 ein. Der Umgang mit Capture CIS ist ok, nur beim erstellen der Netlist kommen folgende Warnungen über nicht gefundene Bauteile in den libraries: #1 WARNING(SPMHNI-192): Device/Symbol check warning detected. WARNING(SPMHNI-194): Symbol 'RC500' for device 'C_RC500_1U' not found in PSMPATH or must be "dbdoctor"ed. #2 WARNING(SPMHNI-192): Device/Symbol check warning detected. WARNING(SPMHNI-194): Symbol 'RC200_RADIAL' for device 'C_ELECT_0_RC200_RADIAL_100U' not found in PSMPATH or must be "dbdoctor"ed. #3 WARNING(SPMHNI-192): Device/Symbol check warning detected. WARNING(SPMHNI-194): Symbol 'MOLEX2' for device 'HEADER 2_MOLEX2_HEADER 2' not found in PSMPATH or must be "dbdoctor"ed. #4 WARNING(SPMHNI-192): Device/Symbol check warning detected. WARNING(SPMHNI-194): Symbol 'MOLEX3' for device 'HEADER 3_MOLEX3_HEADER 3' not found in PSMPATH or must be "dbdoctor"ed. #5 WARNING(SPMHNI-192): Device/Symbol check warning detected. WARNING(SPMHNI-194): Symbol 'RC400' for device 'R_RC400_7.4K' not found in PSMPATH or must be "dbdoctor"ed. #6 WARNING(SPMHNI-192): Device/Symbol check warning detected. WARNING(SPMHNI-194): Symbol 'RC400' for device 'R_RC400_390' not found in PSMPATH or must be "dbdoctor"ed. #7 WARNING(SPMHNI-192): Device/Symbol check warning detected. WARNING(SPMHNI-194): Symbol 'RC400' for device 'R_RC400_2.7K' not found in PSMPATH or must be "dbdoctor"ed. #8 WARNING(SPMHNI-192): Device/Symbol check warning detected. WARNING(SPMHNI-194): Symbol 'RC400' for device 'R_RC400_180' not found in PSMPATH or must be "dbdoctor"ed. #9 WARNING(SPMHNI-316): Property warning detected. WARNING(SPMHNI-301): Problems with component 'R4'. Error with component property '' and value 'VOLTAGE': 'RVMAX'. #10 WARNING(SPMHNI-316): Property warning detected. WARNING(SPMHNI-301): Problems with component 'R3'. Error with component property '' and value 'VOLTAGE': 'RVMAX'. #11 WARNING(SPMHNI-316): Property warning detected. WARNING(SPMHNI-301): Problems with component 'R2'. Error with component property '' and value 'VOLTAGE': 'RVMAX'. #12 WARNING(SPMHNI-316): Property warning detected. WARNING(SPMHNI-301): Problems with component 'R1'. Error with component property '' and value 'VOLTAGE': 'RVMAX'. #13 WARNING(SPMHNI-316): Property warning detected. WARNING(SPMHNI-301): Problems with component 'C1'. Error with component property '' and value 'VOLTAGE': 'CMAX'. Es handelt sich hier um eine Standartinstallation noch ohne Datenbankanbindung. Im OrCAD PCB Editor hab ich bereits meine Libraries auf C:\OrCAD\OrCAD_16.0\share\pcb\pcb_lib\symbols im Installationsverzeichnis eingestellt. (Da befinden sich auch mehr als 1200 Files) Vielleicht kann mir jemand von euch helfen, die Standard-footprints von OrCAD zu aktivieren, wenn da überhaupt welche sind. Besteht überhaupt die Möglichkeit zu sehen, welche Footprints installiert sind? Ich danke euch für eure hilfe
Mach doch mal ein Design Rule Check und lass dir alle Fehler anzeigen. Die Netzlist wird trotztdem ohne Fehler erzeugt. Du musst halt beim öffnen Von OrCad unter Angabe der Netzliste allen nicht gefundenen Bautteilen einen Footprint manuell zuweisen.
