Ich habe folgendes Problem wenn ich die exe in der Kommandozeile unter windows starten will kommt folgendes Problem C:\Programme\openocd-r717\bin>openocd-ftd2xx.exe -d 3 Open On-Chip Debugger (2008-06-19 19:00) svn: 717 URL: http://svn.berlios.de/svnroot/repos/openocd/trunk Debug: 5 0 command.c:432 command_run_line(): script openocd.cfg Debug: 6 0 configuration.c:87 open_file_from_path(): opened openocd.cfg Debug: 8 0 command.c:432 command_run_line(): telnet_port 4444 Debug: 10 0 command.c:432 command_run_line(): gdb_port 3333 Debug: 12 0 command.c:432 command_run_line(): gdb_memory_map enable Debug: 14 0 command.c:432 command_run_line(): gdb_flash_program enable Debug: 16 0 command.c:432 command_run_line(): interface parport Error: 17 0 jtag.c:1684 handle_interface_command(): No valid jtag interface fo und (parport) Error: 18 16 jtag.c:1685 handle_interface_command(): compiled-in jtag interfac es: Error: 19 16 jtag.c:1688 handle_interface_command(): 0: ft2232 Debug: 20 16 command.c:387 find_and_run_command(): Command failed with error c ode -101 Debug: 22 16 command.c:432 command_run_line(): parport_port 0x378 Info: 23 16 options.c:50 configuration_output_handler(): Command parport_port not found Debug: 25 16 command.c:432 command_run_line(): parport_cable wiggler Info: 26 16 options.c:50 configuration_output_handler(): Command parport_cabl e not found Debug: 28 16 command.c:432 command_run_line(): jtag_speed 0 Debug: 29 16 jtag.c:1863 handle_jtag_speed_command(): handle jtag speed Info: 30 16 options.c:50 configuration_output_handler(): jtag_speed: 0, 0 Debug: 32 16 command.c:432 command_run_line(): jtag_nsrst_delay 200 Debug: 34 16 command.c:432 command_run_line(): jtag_ntrst_delay 200 Debug: 36 16 command.c:432 command_run_line(): reset_config srst_only srst_pul ls_trst Debug: 38 16 command.c:432 command_run_line(): jtag_device 4 0x1 0xf 0xe Debug: 40 16 command.c:432 command_run_line(): daemon_startup reset Info: 41 16 options.c:50 configuration_output_handler(): Open On-Chip Debugge r (2008-06-19 19:00) svn: 717 Debug: 43 16 command.c:432 command_run_line(): target cortex_m3 little run_and _halt 0 lm3s Debug: 45 16 command.c:432 command_run_line(): run_and_halt_time 0 30 Debug: 47 16 command.c:432 command_run_line(): working_area 0 0x20000000 0x200 0 nobackup Debug: 49 32 command.c:432 command_run_line(): flash bank stellaris 0 0 0 0 0 Debug: 51 32 command.c:432 command_run_line(): init Debug: 52 32 openocd.c:102 handle_init_command(): target init complete Error: 53 32 jtag.c:1511 jtag_interface_init(): JTAG interface has to be speci fied, see "interface" command Debug: 54 32 command.c:387 find_and_run_command(): Command failed with error c ode -101 meine Config sieht wie folgt aus : #daemon configuration telnet_port 4444 gdb_port 3333 # tell gdb our flash memory map gdb_memory_map enable # enable flash programming gdb_flash_program enable #interface interface parport parport_port 0x378 parport_cable wiggler jtag_speed 0 jtag_nsrst_delay 200 jtag_ntrst_delay 200 #use combined on interfaces or targets that can't set TRST/SRST separately reset_config srst_only srst_pulls_trst #jtag scan chain #format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE) jtag_device 4 0x1 0xf 0xe #target configuration daemon_startup reset #target <type> <startup mode> #target arm7tdmi <reset mode> <chainpos> <endianness> <variant> target cortex_m3 little run_and_halt 0 lm3s run_and_halt_time 0 30 working_area 0 0x20000000 0x2000 nobackup flash bank stellaris 0 0 0 0 0 danke wenn mir wer helfen könnte! Gruß
> Error: 53 32 jtag.c:1511 jtag_interface_init(): > JTAG interface has to be specified, see "interface" command Möglicherweise ist "interface parport" in Deiner Konfigurationsdatei nicht ausreichend?
Oh, ich hatte die früheren interessanten Fehlermeldungen übersehen: > Error: 17 0 jtag.c:1684 handle_interface_command(): > No valid jtag interface found (parport) Das zusammen mit der folgenden Fehlermeldung > Error: 18 16 jtag.c:1685 handle_interface_command(): > compiled-in jtag interfaces: > Error: 19 16 jtag.c:1688 handle_interface_command(): > 0: ft2232 lässt annehmen, daß Du eine Version verwendest, die nur für das ft2232-Interface und ohne Unterstützung des Parallelports übersetzt wurde.
Sieht nach dem Paket von Yagarto/Michael Fischer aus. Darin ist eine weitere .exe-Datei enthalten. Man schaue in C:\Programme\openocd-r717\bin
