1 | #include "stm32f10x_lib.h" // STM32F10x Library Definitions
2 | #include <stdio.h>
3 | #include "STM32_Init.h" // STM32 Initialization
4 | #include "stm32f10x_usart.h"
5 |
6 | //#define UART UART_3
7 | typedef unsigned int Int32U; // Unsigned 32 bit quantity
8 |
9 | #define LOOP_DLY_100US 450
10 |
11 |
12 | void Clk_Init (void)
13 | {
14 | // 1. Clocking the controller from internal HSI RC (8 MHz)
15 | RCC_HSICmd(ENABLE);
16 | // wait until the HSI is ready
17 | while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
18 | RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
19 | // 2. Enable ext. high frequency OSC
20 | RCC_HSEConfig(RCC_HSE_ON);
21 | // wait until the HSE is ready
22 | while(RCC_GetFlagStatus(RCC_FLAG_HSERDY) == RESET);
23 | // 3. Init PLL
24 | RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9); // 72MHz
25 | RCC_PLLCmd(ENABLE);
26 | // wait until the PLL is ready
27 | while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
28 | // 4. Set system clock dividers
29 | RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);
30 | RCC_ADCCLKConfig(RCC_PCLK2_Div8);
31 | RCC_PCLK2Config(RCC_HCLK_Div1);
32 | RCC_PCLK1Config(RCC_HCLK_Div2);
33 | RCC_HCLKConfig(RCC_SYSCLK_Div1);
34 | #ifdef EMB_FLASH
35 | // 5. Init Embedded Flash
36 | // Zero wait state, if 0 < HCLK 24 MHz
37 | // One wait state, if 24 MHz < HCLK 56 MHz
38 | // Two wait states, if 56 MHz < HCLK 72 MHz
39 | // Flash wait state
40 | FLASH_SetLatency(FLASH_Latency_2);
41 | // Half cycle access
42 | FLASH_HalfCycleAccessCmd(FLASH_HalfCycleAccess_Disable);
43 | // Prefetch buffer
44 | FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
45 | #endif // EMB_FLASH
46 | // 5. Clock system from PLL
47 | RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
48 | }
49 |
50 | /*************************************************************************
51 | * Function Name: Dly100us
52 | * Parameters: Int32U Dly
53 | *
54 | * Return: none
55 | *
56 | * Description: Delay Dly * 100us
57 | *
58 | *************************************************************************/
59 | void Dly100us(void *arg)
60 | {
61 | Int32U Dly = (Int32U)arg;
62 | while(Dly--)
63 | {
64 | for(volatile int i = LOOP_DLY_100US; i; i--);
65 | }
66 | }
67 |
68 |
69 | void UART_init()
70 | {
71 |
72 | }
73 | /*************************************************************************
74 | * Function Name: main
75 | * Parameters: none
76 | *
77 | * Return: none
78 | *
79 | * Description: main
80 | *
81 | *************************************************************************/
82 | void main(void)
83 | {
84 | GPIO_InitTypeDef GPIO_InitStructure;
85 | NVIC_InitTypeDef NVIC_InitStructure;
86 | #ifdef DEBUG
87 | debug();
88 | #endif
89 |
90 | // Init clock system
91 | Clk_Init();
92 |
93 | // NVIC init
94 | #ifndef EMB_FLASH
95 | /* Set the Vector Table base location at 0x20000000 */
96 | NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
97 | #else /* VECT_TAB_FLASH */
98 | /* Set the Vector Table base location at 0x08000000 */
99 | NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
100 | #endif
101 | NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
102 |
103 | // Enable timer counting
104 | //TIM1_Cmd(ENABLE);
105 |
106 |
107 | UART_init();
108 |
109 |
110 | while(1)
111 | {
112 |
113 |
114 |
115 | }
116 | }
117 | #ifdef DEBUG
118 |
119 | void assert_failed(u8* file, u32 line)
120 | {
121 | /* User can add his own implementation to report the file name and line number,
122 | ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
123 |
124 | /* Infinite loop */
125 | while (1)
126 | {
127 | }
128 | }
129 | #endif
