1 | /////Master
2 | #include "p18F4550.h"
3 | #include <stdio.h>
4 | #include <delays.h>
5 | #include "Spi_Init.h"
6 | #include "PortConfiguration.h"
7 | int u08LSend_Data=0x75;
8 | void SPI_Init_Master(void)
9 | {
10 | SSPSTATbits.SMP=0 ; //1= Input data sampled at end of data output time
11 | //0= Input data sampled at middle of data output time
12 |
13 | SSPSTATbits.CKE=1 ; //1= Transmit occurs on transition from active to Idle clock state
14 | //0= transmit occurs on transition from Idle to active clock state
15 |
16 | SSPCON1bits.WCOL=0 ; //1= The SSPBUF register is written while it is still transmitting the previous word (must be clear in Software)
17 | //0= No collision
18 |
19 | SSPCON1bits.SSPEN= 1; //1= Enables serial port and configures SCK, SDO, SDI and SS as serial port pins
20 | //0= Disables serial port and configures these pins as I/O port pins
21 |
22 | SSPCON1bits.CKP=1; //1= Idle state for clock is a high level
23 | //0= Idle state for clock is a low level
24 | //SSPM3:SSPM0: Master sychronous Serial Port Mode Select bits
25 | SSPCON1bits.SSPM3= 0; //0101= SPI Slave mode, clock =SCK pin, SS pin control disabled, ss can be used as I/O pin
26 | SSPCON1bits.SSPM2= 0; //0100= SPI slave mode, clock =SCK pin, SS pin control enabled
27 | SSPCON1bits.SSPM1= 0; //0011= SPI Master mode, clock = TMR2 output/2
28 | SSPCON1bits.SSPM0= 1; //0010= SPI Master mode, clock = FOSC/64
29 | //0001= SPI Master mode, clock = FOSC/16
30 | //0000= SPI Master mode, clock = FOSC/4
31 | PIR1bits.SSPIF=0; //1= The transmission/reception is complete(must be cleared in software)
32 | //0= wating to transmit/receive
33 | TRISCbits.TRISC7=0; // Serial Data Out
34 | TRISBbits.TRISB0=1; // Serial Data In
35 | //CLK
36 | TRISBbits.TRISB1=0;
37 | //SS
38 | TRISDbits.TRISD5=0;
39 | }
40 | int SPI_MASTER_WRITE(void)
41 | {
42 | INTCONbits.GIEH = 0;
43 | TRISDbits.TRISD5=0;
44 | SSPBUF = u08LSend_Data; // load the register SSPBUF
45 | if ( SSPCON1bits.SSPOV) // test if write collision occurred
46 | {
47 | return ( -1 ); // if WCOL bit is set return negative #
48 | }
49 | else
50 | {
51 | while(!SSPSTATbits.BF) // control wenn the register is full
52 |
53 | TRISDbits.TRISD5=1; // CS
54 | u08LSend_Data= SSPBUF;
55 |
56 | SSPSTATbits.BF=0; //
57 | return SSPBUF;
58 | }
59 | INTCONbits.GIEH = 1;
60 | }
61 | /////Slave
62 | #include "p18F4550.h"
63 | #include <stdio.h>
64 | #include <delays.h>
65 | #include "Spi_Init.h"
66 | #include "PortConfiguration.h"
67 |
68 | void SPI_INIT_SLAVE(void)
69 | {
70 | SSPSTATbits.SMP=0 ; // SPM must be cleared when SPI is used in Slave mode
71 |
72 | SSPSTATbits.CKE=0 ; //1= Transmit occurs on transition from active to Idle clock state
73 | //0= transmit occurs on transition from Idle to active clock state
74 | SSPCON1bits.WCOL=0 ; //1= The SSPBUF register is written while it is still transmitting the previous word (must be clear in Software)
75 | //0= No collision
76 | SSPCON1bits.SSPEN= 1; //1= Enables serial port and configures SCK, SDO, SDI and SS as serial port pins
77 | //0= Disables serial port and configures these pins as I/O port pins
78 | SSPCON1bits.CKP=1; //1= Idle state for clock is a high level
79 | //0= Idle state for clock is a low level
80 | //SSPM3:SSPM0: Master sychronous Serial Port Mode Select bits
81 | SSPCON1bits.SSPM3= 0; //0101= SPI Slave mode, clock =SCK pin, SS pin control disabled, ss can be used as I/O pin
82 | SSPCON1bits.SSPM2= 1; //0100= SPI slave mode, clock =SCK pin, SS pin control enabled
83 | SSPCON1bits.SSPM1= 0; //0011= SPI Master mode, clock = TMR2 output/2
84 | SSPCON1bits.SSPM0= 1; //0010= SPI Master mode, clock = FOSC/64
85 | //0001= SPI Master mode, clock = FOSC/16
86 | //0000= SPI Master mode, clock = FOSC/4
87 | PIR1bits.SSPIF=0; //1= The transmission/reception is complete(must be cleared in software)
88 | //0= wating to transmit/receive
89 | TRISCbits.RC7=1; // Serial Data Out
90 | TRISBbits.RB0=0; // Serial Data In
91 | //CLK
92 | TRISBbits.TRISB1=1;
93 | //SS
94 | TRISDbits.TRISD5=1;
95 | }
96 |
97 | int SPI_SLAVE_READ( void )
98 | {
99 | SSP1BUF = 0x00; // initiate bus cycle
100 | while ( !SSP1STATbits.BF ); // wait until cycle complete
101 | return ( SSP1BUF ); // return with byte read
102 | }
