Hallöchen,
habe da eine kleine Unklarheit was die Behandlung der Vref betrifft.
Der Wandler hat einen differenziellen Eingang.
Hier mal die nicht so leicht für mich verständlichen Teile aus dem
Datasheet:
1 | 3.1 Voltage Reference (VREF)
2 | The MCP3550/1/3 devices accept single-ended reference
3 | voltages from 0.1V to VDD. Since the converter
4 | output noise is dominated by thermal noise, which is
5 | independent of the reference voltage, the output noise
6 | is not significantly improved by diminishing the reference
7 | voltage at the VREF input pin. A reduced voltage
8 | reference will significantly improve the INL performance
9 | (see Figure 2-4); the INL max error is
10 | proportional to VREF²
1 | 4.5 Voltage Reference Input Pin
2 | The MCP3550/1/3 devices accept a single-ended
3 | external reference voltage, to be connected on the
4 | VREF input pin. Internally, the reference voltage for the
5 | ADC is a differential voltage with the non-inverting input
6 | connected to the VREF pin and the inverting input
7 | connected to the VSS pin. The value of the reference
8 | voltage is VREF - VSS and the common mode of the
9 | reference is always (VREF - VSS)/2.
10 | The MCP3550/1/3 devices accept a single-ended
11 | reference voltage from 0.1V to VDD. The converter
12 | output noise is dominated by thermal noise that is
13 | independent of the reference voltage. Therefore, the
14 | output noise is not significantly improved by lowering
15 | the reference voltage at the VREF input pin. However, a
16 | reduced reference voltage will significantly improve the
17 | INL performance since the INL max error is
18 | proportional to VREF
19 | 2 (see Figure 2-4).
20 | The charge and discharge of the input capacitor create
21 | dynamic input currents at the VREF input pin inversely
22 | proportional to the sampling capacitor, which is a function
23 | of the input reference voltage. The typical value of
24 | the single-ended input impedance is 2.4 MΩ, with
25 | VDD = VREF = 5V. The DC leakage current caused by
26 | the ESD input diodes, though on the order of 1 nA
27 | typically, can cause additional gain error proportional to
28 | the source resistance at the VREF pin.
Ich habe eine Vref mit 4,096V geplant.
welche Spannung kann er damit messen???
4Volt?
oder wegen dem (...the common mode of the
reference is always (VREF - VSS)/2.) nur 2,048?
Vielleicht kann mich jemand ja aufklären ;)
Habt Dank im vorraus
Anselm
p.S.: Vin- an GND/VSS angeschlossen
Vin+ am Ausgang des Messverstärkers
Datenblatt zu finden unter:
http://ww1.microchip.com/downloads/en/DeviceDoc/21950d.pdf
