PCI-1202H Neu und originalverpackt, inkl Anleitung, Software und Kabel: Natürlich von den gängien Tols wie LabVIEW unterstützt. http://www.icpdas.com/oldweb/products/card/pci-1202.htm # 12-bit 110KHz A/D converter # PCI-1202H, 32 single-ended/ 16 differential inputs, 1K word FIFO buffer # The sampling rates of single channel or multiple channels is 40K samples/s # Three different external trigger : post-trigger, pre-trigger, middle trigger # 16 digital input / 16 digital output channels # PCI-1202H provides programmable high gain: 0.5, 1, 5, 10, 50, 100, 500, 1000. # Internal / external trigger. # Two 12-bit independent programmable DAC.; 2 MHz throughput per channel (maxi) # 2.7 M word /high speed data transfer rate. Ich dachte so an 120 Euro inkl Versand.
