1 | //uart.c
2 | #include <NXP\iolpc2103.h>
3 | #include <stdlib.h>
4 | #include <intrinsics.h>
5 | #include "main.h"
6 | #include "uart.h"
7 | #include "interrupts.h"
8 | #include <yfuns.h>
9 |
10 | /** local definitions **/
11 | #define UART_FIFO_SIZE 200
12 |
13 | typedef struct _UartFifo_t
14 | {
15 | uint32_t PushIndx;
16 | uint32_t PopIndx;
17 | uint8_t Buffer[UART_FIFO_SIZE];
18 | } UartFifo_t, *pUartFifo_t;
19 |
20 | pUartFifo_t pUart0RxFifo; // Pointer to a FIFO Buffer of the UART0 Receive
21 | pUartFifo_t pUart0TxFifo; // Pointer to a FIFO Buffer of the UART0 Transmit
22 |
23 | // Hold UART0 Events (PE, BI, FE, OE)
24 | UartLineEvents_t Uart0LineEvents;
25 |
26 | /*************************************************************************
27 | * Function Name: FifoPush
28 | * Parameters: pUartFifo_t Fifo, uint8_t Data
29 | *
30 | * Return: uint8_t
31 | *
32 | * Description: Push a char in a FIFO. Return 1 when push is successful
33 | * or 0 when the FIFO is full.
34 | *
35 | *************************************************************************/
36 | static uint8_t FifoPush(pUartFifo_t Fifo, uint8_t Data)
37 | {
38 | uint32_t IndxTmp;
39 |
40 | // calculate next push index
41 | IndxTmp = Fifo->PushIndx + 1;
42 | IndxTmp = IndxTmp % UART_FIFO_SIZE;
43 |
44 | // Check FIFO state
45 | if (IndxTmp == Fifo->PopIndx)
46 | {
47 | // The FIFO is full
48 | return(0);
49 | }
50 | // Push the data
51 | Fifo->Buffer[Fifo->PushIndx] = Data;
52 | // Updating the push's index
53 | Fifo->PushIndx = IndxTmp;
54 | return(1);
55 | }
56 |
57 | /*************************************************************************
58 | * Function Name: FifoPop
59 | * Parameters: pUartFifo_t Fifo, uint8_t Data
60 | *
61 | * Return: uint8_t
62 | *
63 | * Description: Pop a char from a FIFO. Return 1 when pop is successful
64 | * or 0 when the FIFO is empty.
65 | *
66 | *************************************************************************/
67 | static uint8_t FifoPop(pUartFifo_t Fifo, uint8_t* pData)
68 | {
69 | uint32_t IndxTmp;
70 | // Check FIFO state
71 | if (Fifo->PushIndx == Fifo->PopIndx)
72 | {
73 | // The FIFO is empty
74 | return(0);
75 | }
76 | // Calculate the next pop index
77 | IndxTmp = Fifo->PopIndx + 1;
78 | IndxTmp = IndxTmp % UART_FIFO_SIZE;
79 | // Pop the data
80 | *pData = Fifo->Buffer[Fifo->PopIndx];
81 | // Updating of the pop's index
82 | Fifo->PopIndx = IndxTmp;
83 | return(1);
84 | }
85 |
86 | /*************************************************************************
87 | * Function Name: Uart0Isr
88 | * Parameters: none
89 | *
90 | * Return: none
91 | *
92 | * Description: UART 0 interrupt routine
93 | *
94 | *************************************************************************/
95 | static
96 | void uart0_isr(void)
97 | {
98 | uint32_t UartIntId = U0IIR, LineStatus, Counter;
99 | uint8_t Data;
100 | // Recognize the interrupt event
101 | switch (UartIntId & 0xF)
102 | {
103 | case RLS_INTR_ID: // Receive Line Status
104 | case CDI_INTR_ID: // Character Time-out Indicator
105 | case RDA_INTR_ID: // Receive Data Available
106 | // Read the line state of the UART
107 | LineStatus = U0LSR;
108 | do
109 | {
110 | if(LineStatus & RLS_OverrunError)
111 | {
112 | // Overrun Error
113 | Uart0LineEvents.bOE = 1;
114 | }
115 | Data = U0RBR;
116 | if (LineStatus & RLS_BreakInterruptr)
117 | {
118 | // Break Indicator
119 | Uart0LineEvents.bBI = 1;
120 | }
121 | else if (LineStatus & RLS_FramingError)
122 | {
123 | // Framing Error
124 | Uart0LineEvents.bFE = 1;
125 | }
126 | else if (LineStatus & RLS_ParityError)
127 | {
128 | // Parity Error
129 | Uart0LineEvents.bPE = 1;
130 | }
131 | // Push a new data into the receiver buffer
132 | if(!FifoPush(pUart0RxFifo,Data))
133 | {
134 | // the FIFO is full
135 | Uart0LineEvents.bOE = 1;
136 | break;
137 | }
138 | // Read the line state of the UART
139 | LineStatus = U0LSR;
140 | }
141 | while(LineStatus & RLS_ReceiverDataReady); // Is the hardware FIFO empty?
142 | break;
143 | case THRE_INTR_ID: // THRE Interrupt
144 | // Tx UART FIFO size - 1
145 | // Fill whole hardware transmit FIFO
146 | for (Counter = 15; Counter; --Counter)
147 | {
148 | // Pop a data from the transmit buffer
149 | if(!FifoPop(pUart0TxFifo,&Data))
150 | {
151 | // The tx software FIFO is empty
152 | break;
153 | }
154 | U0THR = Data;
155 | }
156 | break;
157 | }
158 | }
159 |
160 | /*************************************************************************
161 | * Function Name: UartInit
162 | * Parameters: UartNum_t Uart, uint32_t IrqSlot, UartMode_t UartMode
163 | *
164 | * Return: uint8_t
165 | *
166 | * Description: Init UART
167 | *
168 | *************************************************************************/
169 | uint8_t uart0_init(uint32_t Baudrate, uint32_t IrqSlot)
170 | {
171 | volatile uint8_t Tmp;
172 |
173 | pUart0RxFifo = (pUartFifo_t)malloc(sizeof(UartFifo_t));
174 | if(!pUart0RxFifo)
175 | {
176 | return(0);
177 | }
178 | pUart0TxFifo = (pUartFifo_t)malloc(sizeof(UartFifo_t));
179 | if(!pUart0TxFifo)
180 | {
181 | free(pUart0RxFifo);
182 | return(0);
183 | }
184 | // Init receive and transmit FIFOs
185 | pUart0RxFifo->PopIndx = pUart0RxFifo->PushIndx = 0;
186 | pUart0TxFifo->PopIndx = pUart0TxFifo->PushIndx = 0;
187 |
188 | PCONP_bit.PCUART0 = 1; // Enable UART0
189 | PINSEL0_bit.P0_0 = 1; //Uart TX function select
190 | PINSEL0_bit.P0_1 = 1; //Uart RX function select
191 |
192 | U0LCR = 0x03; // Word Length =8, no parity , 1 stop
193 | U0FDR_bit.MULVAL = 1; //set fractional divider register multiplier to 1
194 | U0FDR_bit.DIVADDVAL = 0; //disable fractional divider (this should change for other baudrates
195 |
196 | U0LCR_bit.DLAB = 1; //Devisor Latch Access enabled
197 | U0DLL = ((PCLK/16)/Baudrate)%256; //configure divisor latch register lsb..
198 | U0DLM = ((PCLK/16)/Baudrate)/256; //..and msb
199 | U0LCR_bit.DLAB = 0; //Clear Devisor Latch Access bit
200 | U0FCR = 0x03;//0x7; // Enable and Clear the UART0 FIFO, Set RX FIFO interrupt level - 1 char
201 |
202 | U0TER_bit.TXEN = 1; // Transmit enable
203 | Tmp = U0IER; // Clear pending interrupts
204 | U0IER = 0x07; // enable RBR Interrupt, THRE Interrupt, RX Line Status Interrupt
205 |
206 | Install_IRQ(VIC_UART0, uart0_isr, IrqSlot); //Install Interrupt
207 | return(1);
208 | }
209 |
210 |
211 | /*************************************************************************
212 | * Function Name: uart0_read
213 | * Parameters: uint8_t* pBuffer, uint32_t BufferSize
214 | *
215 | * Return: uint32_t
216 | *
217 | * Description: Read received data from UART0.
218 | * Return number of readied characters
219 | *
220 | *************************************************************************/
221 | uint32_t uart0_read(uint8_t* pBuffer, uint32_t BufferSize)
222 | {
223 | uint32_t Count;
224 | for (Count = 0; Count < BufferSize; ++Count)
225 | {
226 | if(!FifoPop(pUart0RxFifo,pBuffer+Count))
227 | {
228 | break;
229 | }
230 | }
231 | return(Count);
232 | }
233 |
234 | /*************************************************************************
235 | * Function Name: UartWrite
236 | * Parameters: UartNum_t Uart, uint8_t* pBuffer, uint32_t BufferSize
237 | *
238 | * Return: uint32_t
239 | *
240 | * Description: Write a data to UART. Return number of successful
241 | * transmitted bytes
242 | *
243 | *************************************************************************/
244 | uint32_t uart0_write(uint8_t* pBuffer, uint32_t BufferSize)
245 | {
246 | uint32_t Count = 0;
247 |
248 | if(BufferSize != 0)
249 | {
250 | volatile uint8_t* pUartTxReg;
251 | __disable_interrupt();
252 | //TX FIFO is empty
253 | if((pUart0TxFifo->PushIndx == pUart0TxFifo->PopIndx))
254 | {
255 | pUartTxReg = (uint8_t*)&U0THR;
256 | if(U0LSR_bit.THRE)
257 | {
258 | *pUartTxReg = *pBuffer;
259 | ++Count;
260 | }
261 | }
262 | for ( ; Count < BufferSize; ++Count)
263 | {
264 | if(!FifoPush(pUart0TxFifo,*(pBuffer+Count)))
265 | {
266 | break;
267 | }
268 | }
269 | __enable_interrupt();
270 | }
271 | return(Count);
272 | }
273 |
274 | /*************************************************************************
275 | * Function Name: uart0_getUartLineEvents
276 | * Parameters:
277 | *
278 | * Return: UartLineEvents_t
279 | *
280 | * Description: Get Uart Line events (PE, OE, FE, BI)
281 | *
282 | *************************************************************************/
283 | UartLineEvents_t uart0_getUartLineEvents()
284 | {
285 | UartLineEvents_t LineEvents;
286 | LineEvents.Data = Uart0LineEvents.Data;
287 | return(LineEvents);
288 | }
