1 | //**************************************************************************************************************************
2 | // Definitionen von globalen Variablen
3 | //**************************************************************************************************************************
4 |
5 | u8 IIC_DevAddr; // IIC-Device Adresse
6 | u16 IIC_Addr; // Register-Adresse
7 | u16 IIC_Data; // Daten Wort
8 | u8 IIC_Mode; // Modus: 0=kein, 1=schreiben, 2=lesen
9 | u8 IIC_Stat; // Status: 0=in Arbeit, 1=Fertig
10 |
11 | s16 IIC_Count;
12 |
13 | // Initialiseren IIC Bus
14 | void IICInit(char bRefresh)
15 | {
16 | if (!bRefresh)
17 | {
18 | IIC_DevAddr = 0x58;
19 | IIC_Addr = 0;
20 | IIC_Data = 0;
21 | IIC_Mode = 0;
22 | IIC_Stat = 1;
23 | IIC_Count = 0;
24 | I2C_DeInit(I2C2);
25 | }
26 | RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2, ENABLE);
27 |
28 | /* Configure I2C2 pins: SCL and SDA ----------------------------------------*/
29 | GPIO_InitTypeDef GPIO_InitStructure;
30 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11;
31 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
32 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
33 | GPIO_Init(GPIOB, &GPIO_InitStructure);
34 |
35 | I2C_Cmd(I2C2, ENABLE);
36 |
37 | /* I2C2 configuration ------------------------------------------------------*/
38 | I2C_InitTypeDef I2C_InitSt;
39 | I2C_InitSt.I2C_Mode = I2C_Mode_I2C;
40 | I2C_InitSt.I2C_DutyCycle = I2C_DutyCycle_2;
41 | I2C_InitSt.I2C_OwnAddress1 = IIC_DevAddr;
42 | I2C_InitSt.I2C_Ack = I2C_Ack_Enable;
43 | I2C_InitSt.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
44 | I2C_InitSt.I2C_ClockSpeed = 40000;
45 | I2C_Init(I2C2, &I2C_InitSt);
46 |
47 | /* Configure and enable I2C2 interrupt -------------------------------------*/
48 | NVIC_InitTypeDef NVIC_InitSt;
49 | NVIC_InitSt.NVIC_IRQChannel = I2C2_EV_IRQChannel;
50 | NVIC_InitSt.NVIC_IRQChannelPreemptionPriority = 0;
51 | NVIC_InitSt.NVIC_IRQChannelSubPriority = 0;
52 | NVIC_InitSt.NVIC_IRQChannelCmd = ENABLE;
53 | NVIC_Init(&NVIC_InitSt);
54 |
55 | I2C_ITConfig(I2C2, I2C_IT_EVT | I2C_IT_BUF, ENABLE);
56 | }
57 |
58 | // IIC Übertragung abgeschlossen
59 | u8 IIC_Ready(void)
60 | {
61 | return IIC_Stat;
62 | }
63 |
64 | // Schreibe Daten
65 | void IIC_Write(u16 Addr, u16 Data)
66 | {
67 | if (!IIC_Stat) return; // Doppelte Befehle gehen nicht!
68 | IIC_Addr = Addr;
69 | IIC_Data = Data;
70 | IIC_Mode = 1;
71 | IIC_Stat = 0;
72 | IIC_Count = 0;
73 | //I2C_GenerateSTOP(I2C2, DISABLE);
74 | I2C_GenerateSTART(I2C2, ENABLE);
75 | }
76 |
77 | // Leseanforderung Daten starten
78 | void IIC_ReadStart(u16 Addr)
79 | {
80 | IICInit(0); // *DEBUG für Test
81 | if (!IIC_Stat) return; // Doppelte Befehle gehen nicht!
82 | IIC_Addr = Addr;
83 | IIC_Data = 0;
84 | IIC_Mode = 2;
85 | IIC_Stat = 0;
86 | IIC_Count = 0;
87 | //I2C_GenerateSTOP(I2C2, DISABLE);
88 | I2C_GenerateSTART(I2C2, ENABLE);
89 | }
90 |
91 | // Daten der Leseanforderung
92 | u16 IIC_ReadData(void)
93 | {
94 | if (!IIC_Stat) return 0; // Nicht fertig
95 | return IIC_Data;
96 | }
97 |
98 | // Interrupt
99 | void IIC_ISR(void)
100 | {
101 | u32 i = I2C_GetLastEvent(I2C2);
102 | switch (i)
103 | {
104 | /* Test on I2C2 EV5 and clear it */
105 | case I2C_EVENT_MASTER_MODE_SELECT:
106 | /* Send I2C2 slave Address for write */
107 | if (IIC_Mode <= 2)
108 | I2C_Send7bitAddress(I2C2, IIC_DevAddr, I2C_Direction_Transmitter);
109 | else if (IIC_Mode == 3)
110 | I2C_AcknowledgeConfig(I2C2, ENABLE);
111 | // I2C_Send7bitAddress(I2C2, IIC_DevAddr, I2C_Direction_Receiver);
112 | break;
113 |
114 | /* Test on I2C2 EV6 and first EV8 and clear them */
115 | case I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED:
116 | /* I2C2 and I2C2 PEC Transmission Enable */
117 | I2C_CalculatePEC(I2C2, ENABLE);
118 | /* Send the first data */
119 | I2C_SendData(I2C2, (u8)((u16)(IIC_Addr >> 8) & 0xFF)); //EV8 just after EV6
120 | IIC_Count++;
121 | break;
122 |
123 | case I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED:
124 | break;
125 |
126 | case I2C_EVENT_MASTER_BYTE_RECEIVED:
127 | switch (IIC_Count)
128 | {
129 | case 4:
130 | I2C_AcknowledgeConfig(I2C2, DISABLE);
131 | IIC_Data = ((u16)I2C_ReceiveData(I2C2)) << 8;
132 | break;
133 | case 5:
134 | I2C_GenerateSTOP(I2C2, ENABLE);
135 | IIC_Data |= ((u16)I2C_ReceiveData(I2C2));
136 | I2C_AcknowledgeConfig(I2C2, ENABLE);
137 | IIC_Stat = 1;
138 | break;
139 | }
140 | IIC_Count++;
141 | break;
142 | case 196611:
143 | I2C_AcknowledgeConfig(I2C2, DISABLE);
144 | // I2C_AcknowledgeConfig(I2C2, ENABLE);
145 | //IIC_Data = ((u16)I2C_ReceiveData(I2C2)) << 8;
146 | //IIC_Data |= ((u16)I2C_ReceiveData(I2C2));
147 | //IIC_Stat = 1;
148 | break;
149 | case 196677:
150 | I2C_GenerateSTOP(I2C2, ENABLE);
151 | //IIC_Data |= ((u16)I2C_ReceiveData(I2C2));
152 | break;
153 |
154 | /* Test on I2C2 EV8 and clear it */
155 | case I2C_EVENT_MASTER_BYTE_TRANSMITTED:
156 | if (I2C2->SR1 & 0x04000) // NACK Returned!
157 | {
158 | I2C_GenerateSTOP(I2C2, ENABLE);
159 | IIC_Stat = 1;
160 | return;
161 | }
162 | switch (IIC_Count)
163 | {
164 | case 1:
165 | I2C_SendData(I2C2, IIC_Addr & 0xFF);
166 | break;
167 | case 2:
168 | if (IIC_Mode == 2)
169 | {
170 | //I2C_GenerateSTOP(I2C2, ENABLE);
171 | I2C_GenerateSTART(I2C2, ENABLE); // Start-Bit für nächstes Lesen
172 | IIC_Mode = 3;
173 | } else I2C_SendData(I2C2, (u8)((u16)(IIC_Data >> 8) & 0xFF));
174 | break;
175 | case 3:
176 | if (IIC_Mode == 3)
177 | {
178 | //I2C_GenerateSTOP(I2C2, ENABLE);
179 | I2C_AcknowledgeConfig(I2C2, DISABLE);
180 | I2C_Send7bitAddress(I2C2, IIC_DevAddr, I2C_Direction_Receiver);
181 | } else {
182 | I2C_SendData(I2C2, IIC_Data & 0xFF);
183 | IIC_Stat = 1;
184 | }
185 | break;
186 | case 4:
187 | I2C_GenerateSTOP(I2C2, ENABLE);
188 | IIC_Stat = 1;
189 | break;
190 | default:
191 | I2C_TransmitPEC(I2C2, ENABLE);
192 | break;
193 | }
194 | IIC_Count++;
195 | break;
196 |
197 | case I2C_EVENT_SLAVE_ACK_FAILURE:
198 | I2C_GenerateSTOP(I2C2, ENABLE);
199 | IIC_Stat = 1;
200 | break;
201 |
202 | default:
203 | break;
204 | }
205 | }
