gibts die datei mocros.h für den avr? was muss man ändern, wenn man die Datei nicht hat? Hier der Quellcode: //************************************** // Clock 16Mhz // Version 1.0 Janvier 2002 // Sylvain Bissonnette //************************************** //************************************** // I N C L U D E //************************************** #include <avr/io.h> #include <macros.h> //************************************** // D E F I N E //************************************** #define TRUE 0x01 #define FALSE 0x00 #define ANALOG 0x01 #define DIGITAL 0x02 //************************************** // I N T E R R U P T H A N D L E R //************************************** #pragma interrupt_handler Crossing_interrupt:2 #pragma interrupt_handler IR_interrupt:4 #pragma interrupt_handler Degre_interrupt:5 #pragma interrupt_handler Ticker_interrupt:7 //************************************** // P R O T O T Y P E //************************************** void Crossing_interrupt(void); void Degre_interrupt(void); void Time(unsigned char); void IR_interrupt(void); void Ticker_interrupt(void); void Display(void); void CopyData(int Value); void CopyDot(void); //************************************** // G L O B A L V A R I A B L E //************************************** int WeelPosition; unsigned char Pos; unsigned int Adder; unsigned char LatchedIrData; unsigned char Sec; unsigned char Min; unsigned char Hrs; int SecComp; int MinComp; int HrsComp; unsigned char ClockStyle; unsigned char TimeString[50]; unsigned char *TimeStringPtr; unsigned char i; //************************************** // C O N S T A N T //************************************** const unsigned char table[12][6] = {{ 0x3e, 0x41, 0x41, 0x41, 0x3e, 0x00 }, // 0 { 0x00, 0x21, 0x7f, 0x01, 0x00, 0x00 }, // 1 { 0x21, 0x43, 0x45, 0x49, 0x31, 0x00 }, // 2 { 0x42, 0x41, 0x51, 0x69, 0x46, 0x00 }, // 3 { 0x0c, 0x14, 0x24, 0x5f, 0x04, 0x00 }, // 4 { 0x72, 0x51, 0x51, 0x51, 0x4e, 0x00 }, // 5 { 0x1e, 0x29, 0x49, 0x49, 0x06, 0x00 }, // 6 { 0x40, 0x47, 0x48, 0x50, 0x60, 0x00 }, // 7 { 0x36, 0x49, 0x49, 0x49, 0x36, 0x00 }, // 8 { 0x30, 0x49, 0x49, 0x4a, 0x3c, 0x00 }, // 9 { 0x00, 0x36, 0x36, 0x00, 0x00, 0x00 }, // : { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }};// space //************************************** // M A I N //************************************** void main() { WDTCR = 0x0e; // Enable WatchDog at 0.97 sec PORTD = 0x0d; // Pull up on PD2&PD3 & Led White ON DDRD = 0x03; // PD0-O PD1-O PD2-I PD3-I PD4-I PD5-I PD6-I PD7-I //INT 0 MCUCR = 0x02; // Int0 generate int on falling eadge GIMSK = 0x40; // Int0 enable //Timer0 TCCR0 = 0x05; // Timer0 / 1024 //Timer1 TCCR1B = 0x42; // Timer1 / 8 & Input Capture on Rising eadge TIMSK = 0x4a; // int enable on Timer1 Compare Match // int enable on Timer 1 Input Capture // int enable on Timer0 Overflow PORTB = 0x00; DDRB = 0xff; // PB0-7 as output Hrs = 0; Min = 0; Sec = 0; ClockStyle = ANALOG; SEI(); while(1) { asm("WDR"); for (i=0;i<200;i++); if ((LatchedIrData == 0xbb) || (LatchedIrData == 0x92)) Time(TRUE); if ((LatchedIrData == 0xb3) || (LatchedIrData == 0xb0)) ClockStyle = DIGITAL; if ((LatchedIrData == 0xb4) || (LatchedIrData == 0xb1)) ClockStyle = ANALOG; LatchedIrData = 0; } } /********************************************************** Name: void Time(void) Description: Input: none Output: none Misc: **********************************************************/ void Time(unsigned char Fast) { if (Fast == FALSE) Sec++; else Sec += 60; if (Sec > 59) { Sec = 0; Min++; if (Min > 59) { Min = 0; Hrs++; if (Hrs > 11) { Hrs = 0; } } } if (ClockStyle == ANALOG) { SecComp = Sec*6; MinComp = Min*6; HrsComp = (Hrs*30)+(Min/2); } else { TimeStringPtr = &TimeString[0]; CopyData(Hrs); CopyDot(); CopyData(Min); CopyDot(); CopyData(Sec); } } /********************************************************** Name: void CopyData(int Value) Description: Input: none Output: none Misc: **********************************************************/ void CopyData(int Value) { if (Value < 10) { for (i=0;i<6;i++) *TimeStringPtr++ = table[0][i]; for (i=0;i<6;i++) *TimeStringPtr++ = table[Value][i]; } else { for (i=0;i<6;i++) *TimeStringPtr++ = table[Value/10][i]; for (i=0;i<6;i++) *TimeStringPtr++ = table[Value-((Value/10)*10)][i]; } } /********************************************************** Name: void CopySpace(void) Description: Input: none Output: none Misc: **********************************************************/ void CopyDot(void) { for (i=0;i<6;i++) *TimeStringPtr++ = table[10][i]; } /********************************************************** Name: void Crossing_interrupt(void Description: Input: none Output: none Misc: **********************************************************/ void Crossing_interrupt(void) { static unsigned int LastCount; static unsigned int TotalCount; static int Latch; static unsigned char Lap; Latch = TCNT1; TotalCount = Latch - LastCount; LastCount = Latch; Lap++; if (Lap > 250) { Adder = TotalCount / 378; Lap = 0; } WeelPosition = 0; OCR1 = Latch + Adder; TIFR |= 0x80; Display(); } /********************************************************** Name: void Degre_interrupt(void) Description: Input: none Output: none Misc: **********************************************************/ void Degre_interrupt(void) { OCR1 = TCNT1 + Adder; Display(); } /********************************************************** Name: void Display(void) Description: Input: none Output: none Misc: **********************************************************/ void Display(void) { PORTB = 0x00; if (ClockStyle == ANALOG) { if (WeelPosition == HrsComp) PORTB = 0x80; if (WeelPosition == MinComp) PORTB = 0xff; if (WeelPosition == SecComp) PORTB |= 0x03; if ((WeelPosition == 0) || (WeelPosition == 30) || (WeelPosition == 60) || (WeelPosition == 90) || (WeelPosition == 120) || (WeelPosition == 150) || (WeelPosition == 180) || (WeelPosition == 210) || (WeelPosition == 240) || (WeelPosition == 270) || (WeelPosition == 300) || (WeelPosition == 330)) PORTB |= 0x01; } else { Pos = ((WeelPosition-100) / 3); if (Pos < 49) { PORTB = TimeString[48-Pos]; } } WeelPosition++; } /********************************************************** Name: void IR_interrupt(void) Description: This routine is called whenever a rising edge (beginning of valid IR signal) is received. - The data codes are sent using pulse coding. - Each packet has 12 bits and a header. - The basic time period T = 550us. - The header length = 4T (2.2ms) - 0 = pulse with length T followed by space of length T. - 1 = pulse with length 2T followed by space of length T. - The last 5 bits represent the Addess. - The first 7 bits represent the command. - A packet is transmitted every 25ms while a button is down. Input: none Output: Global variable LatchedIrData Misc: Sony VCR protocol **********************************************************/ void IR_interrupt(void) { static unsigned int LastCapture; unsigned int PulseWidth; static unsigned int IrPulseCount; static unsigned int IrData; PulseWidth = ICR1 - LastCapture; LastCapture = ICR1; if (PulseWidth > 4000) { IrPulseCount = 0; IrData = 0; } else { IrData = IrData >> 1; if (PulseWidth > 2800) IrData = IrData | 0x8000; IrPulseCount++; if (IrPulseCount == 12) LatchedIrData = ((IrData >> 4) & 0x00ff); } } /********************************************************** Name: void Ticker_interrupt(void) Description: Input: none Output: none Misc: **********************************************************/ void Ticker_interrupt(void) { static unsigned char Tick; Tick++; if (Tick > 62) { Time(FALSE); Tick = 0; } TCNT0 = 0x04; // reload counter } Danke Flo
Flo wrote:
> Unsinn
Dunkel deiner Rede Sinn ist.
Versuch mal in einem halbwegs kompletten Satz zu beschreiben wo dein
Problem liegt (bezüglich des Quelltextes, nicht deiner Sozialkompetenz
oder deinem Verständnis der Forenregeln).
Flo wrote: > gibts die datei mocros.h für den avr? Da es in <> steht, könnte es zu dem nichtgenannten Compiler gehören. Ist aber keine Standard C-Library. > was muss man ändern, wenn man die > Datei nicht hat? Das kriegt man nur durch Lesen der Fehlermeldungen raus. > Hier der Quellcode: Quellcode immer als Anhang. Wie soll man ihn denn sonst compilieren? Peter
Hier jetzt noch mal als Anhang... Ich hab jetzt mal versucht das mit iccvr7 zu kompilieren, geht aber auch nicht. Danke Flo
Flo wrote: > geht aber auch > nicht. Sehr "aussagekräftige" Fehlermeldung. Der Automechaniker schreibt bei solchen leeren Worthülsen schonmal vorsorglich 500,-€ mit auf die Rechnung. Peter P.S.: Mit iccvr7 kann ich nicht helfen, ich benutze AVR-GCC.
Zitat von der Webseite: "Everything is for your information only. The C/C++ codes have been written with ICCAVR. You can find the header and source CRT files by downloading their compiler." Da stellt sich mir natürlich die Frage ... hmm, doch nicht mehr ...
Icy Han MIT Silvain gemailt und er meinte icy solle unter Projects options den attiny2313 auswählen, allerdings bekomme icy das nicht hin. Könnt ihr Mir einen tipp geben? Danke Flo
Ich habs jetzt, hatte den falschen iccavr... Die Header werden jetzt gefunden, es gibt allerdings noch Fehlermeldungen des Typs: !E <library>(43): area 'bss' not large enough Ich denke, dass ich in den Optionen noch was umstellen muss, doch was? Danke Flo
