Hallo zusammen, hat eventuell jemand Informationen oder eine Quelle über den Bootloader des JTAGICE mkII ? Um diesen JTAGICE mkII geht es, http://www.flickr.com/photos/recotana/2547222052/ Mit JtagIIUpgrade.exe (wird mit AVR Studio installiert) kann man ein JTAGmkII Upgrate machen, die Datei jtagicemkii.dat wird dabei in den µC Übertragen. Ich habe im Internet Rescherschiert und bin mir nicht ganz sicher, - Die Datei ist vermutlich eine Verschlüsselte HEX Datei AVR231: AES Bootloader Application - In der Firmware Datei steht MonCoM_S_OCDS.a90 und MonCoM_M_OCDS.a90 - Das Protokoll ist das AVR067: JTAGICE mkII Communication Protocol Schöne Grüße Andreas B.
Hi Andreas, First, sorry for my English -- I don't speak German, unfortunately. I have found this topic about the bootloader for JTAGICE mkII and want to say I'm pretty much interested in the same, but for the original device. Here's what I have found. - As you probably know, there are a few clones going around, the one you have at hands is JTAGICE mkII Lite, it uses a single MCU compared to the original Atmel design which uses two. - Not sure that the bootloader for clones is the same, neither should be the algorithm they employ -- all that is needed is that the data to be transferred to the MCU. - The two data files inside jtagicemkii.dat are scrambled so you won't be able to view the contents directly by using some kind of viewer for MS Structured Storage format files (this is the format of that .dat file). The scrambling algorithm is in the .dlls that can be found in AVR Studio installation and is not very complex, considering that cloners have successfully reverse-engineered it to scramble their own firmware. The files can be extracted by SSVew utility -- you can google it. - The original Atmel bootloader does not conform to that AVR231 appnote, as well as departs from the protocol specification for JTAGICE mkII in working mode. The firmware data is scrambled too, and the algorithm is still not very clear to me. I'd suggest that you reverse-engineer the scrambling algorithm and obtain the unscrambled firmware files. From then on, you can try to guess what kind of algorithm (if any) is used for firmware encryption. As for me, I have written an JTAGICE mkII emulator to simulate the firmware upgrade process and save the data -- you can go this way too, but it will require you to reverse-engineer the bootloader protocol (it is very similar to the one used by older devices). Kind regards, Dmitry
