1 | openocd: can't resolve symbol
2 | 'atexit'
3 |
4 | Open On-Chip Debugger 1.0 (2009-01-17-19:25)
5 | svn:1220M
6 | BUGS? Read
7 | http://svn.berlios.de/svnroot/repos/openocd/trunk/BUGS
8 |
9 | $URL:
10 | svn://svn.berlios.de/openocd/openocd/branches/openocd_1_0_branch/src/openocd.c
11 | $
12 | Debug: 5 12 configuration.c:88 find_file(): found mechabrick2.cfg
13 | Debug: 7 20 command.c:91 script_command(): script_command - telnet_port
14 | Debug: 8 21 command.c:108 script_command(): script_command -
15 | telnet_port, argv[0]=ocd_telnet_port
16 | Debug: 9 21 command.c:108 script_command(): script_command -
17 | telnet_port, argv[1]=4444
18 | Debug: 11 24 command.c:91 script_command(): script_command -
19 | gdb_port
20 | Debug: 12 25 command.c:108 script_command(): script_command -
21 | gdb_port, argv[0]=ocd_gdb_port
22 | Debug: 13 26 command.c:108 script_command(): script_command -
23 | gdb_port, argv[1]=3333
24 | Debug: 15 28 command.c:91 script_command(): script_command -
25 | interface
26 | Debug: 16 29 command.c:108 script_command(): script_command -
27 | interface, argv[0]=ocd_interface
28 | Debug: 17 30 command.c:108 script_command(): script_command -
29 | interface, argv[1]=dummy
30 | Debug: 19 32 command.c:91 script_command(): script_command -
31 | jtag_speed
32 | Debug: 20 33 command.c:108 script_command(): script_command -
33 | jtag_speed, argv[0]=ocd_jtag_speed
34 | Debug: 21 34 command.c:108 script_command(): script_command -
35 | jtag_speed, argv[1]=0
36 | Debug: 22 34 jtag.c:2406 handle_jtag_speed_command(): handle jtag
37 | speed
38 | User: 23 35 command.c:375 command_print(): jtag_speed:
39 | 0
40 | Debug: 25 38 command.c:91 script_command(): script_command -
41 | reset_config
42 | Debug: 26 39 command.c:108 script_command(): script_command -
43 | reset_config, argv[0]=ocd_reset_config
44 | Debug: 27 39 command.c:108 script_command(): script_command -
45 | reset_config, argv[1]=trst_and_srst
46 | Debug: 28 40 command.c:108 script_command(): script_command -
47 | reset_config, argv[2]=srst_pulls_trst
48 | Debug: 30 41 command.c:91 script_command(): script_command -
49 | reset_config
50 | Debug: 31 42 command.c:108 script_command(): script_command -
51 | reset_config, argv[0]=ocd_reset_config
52 | Debug: 32 42 command.c:108 script_command(): script_command -
53 | reset_config, argv[1]=trst_and_srst
54 | Debug: 33 43 jtag.c:1741 jim_newtap_cmd(): Creating New Tap, Chip:
55 | at91rm9200, Tap: cpu, Dotted: at91rm9200.cpu,s
56 | Debug: 34 44 jtag.c:1761 jim_newtap_cmd(): Processing option:
57 | -irlen
58 | Debug: 35 45 jtag.c:1761 jim_newtap_cmd(): Processing option:
59 | -ircapture
60 | Debug: 36 46 jtag.c:1761 jim_newtap_cmd(): Processing option:
61 | -irmask
62 | Debug: 37 46 jtag.c:1761 jim_newtap_cmd(): Processing option:
63 | -expected-id
64 | Debug: 38 47 jtag.c:1853 jim_newtap_cmd(): Created Tap: at91rm9200.cpu
65 | @ abs position 0, irlen 4, capture: 0x1 mf
66 | Debug: 39 48 target.c:3950 jim_target(): Target command
67 | params:
68 | Debug: 40 49 target.c:3951 jim_target(): target create at91rm9200.cpu
69 | arm920t -endian little -chain-position at9
70 | Debug: 42 79 command.c:91 script_command(): script_command -
71 | init
72 | Debug: 43 79 command.c:108 script_command(): script_command - init,
73 | argv[0]=ocd_init
74 | Segmentation Fault
