Hi, weiß jemand auf Anhieb, wieviel Platz (RAM, Flash) die sprintf und printf in der avr-libc etwa brauchen? float-Ausgabe wird keine gebraucht. Irgendwo gibt's doch auch ne Linker-Option, um Platz zu sparen... Danke, Johann
Bau dir das makefile mit MFile, da sind alle Optionen drin, und probiers aus. Den genauen Verbrauch an SRAM zu ermitteln, wird allerdings mühsam. Oliver
>Irgendwo gibt's doch auch ne Linker-Option, um Platz zu sparen... Auszug aus avr-libc doku http://www.nongnu.org/avr-libc/user-manual/group__avr__stdio.html Since the full implementation of all the mentioned features becomes fairly large, three different flavours of vfprintf() can be selected using linker options. The default vfprintf() implements all the mentioned functionality except floating point conversions. A minimized version of vfprintf() is available that only implements the very basic integer and string conversion facilities, but only the # additional option can be specified using conversion flags (these flags are parsed correctly from the format specification, but then simply ignored). This version can be requested using the following compiler options: -Wl,-u,vfprintf -lprintf_min Bei floating point -Wl,-u,vfprintf -lprintf_flt -lm 900ss
1 | % avr-size avr/lib/avr[35]1/{*printf_*.o,ftoa*} |
2 | text data bss dec hex filename |
3 | 68 0 0 68 44 avr/lib/avr31/fprintf_p.o |
4 | 80 0 0 80 50 avr/lib/avr31/printf_p.o |
5 | 106 0 0 106 6a avr/lib/avr31/snprintf_p.o |
6 | 78 0 0 78 4e avr/lib/avr31/sprintf_p.o |
7 | 2098 0 0 2098 832 avr/lib/avr31/vfprintf_flt.o |
8 | 785 0 0 785 311 avr/lib/avr31/vfprintf_min.o |
9 | 42 0 0 42 2a avr/lib/avr31/vfprintf_p.o |
10 | 1078 0 0 1078 436 avr/lib/avr31/vfprintf_std.o |
11 | 98 0 0 98 62 avr/lib/avr31/vsnprintf_p.o |
12 | 60 0 0 60 3c avr/lib/avr31/vsprintf_p.o |
13 | 58 0 0 58 3a avr/lib/avr51/fprintf_p.o |
14 | 76 0 0 76 4c avr/lib/avr51/printf_p.o |
15 | 96 0 0 96 60 avr/lib/avr51/snprintf_p.o |
16 | 70 0 0 70 46 avr/lib/avr51/sprintf_p.o |
17 | 1856 0 0 1856 740 avr/lib/avr51/vfprintf_flt.o |
18 | 689 0 0 689 2b1 avr/lib/avr51/vfprintf_min.o |
19 | 34 0 0 34 22 avr/lib/avr51/vfprintf_p.o |
20 | 958 0 0 958 3be avr/lib/avr51/vfprintf_std.o |
21 | 86 0 0 86 56 avr/lib/avr51/vsnprintf_p.o |
22 | 56 0 0 56 38 avr/lib/avr51/vsprintf_p.o |
23 | 724 0 0 724 2d4 avr/lib/avr31/ftoa_engine.o |
24 | 682 0 0 682 2aa avr/lib/avr51/ftoa_engine.o |
Die .bss-Angaben müssen dabei nicht korrekt sein. Da das BSS als common block organisiert wird, stehen die exakten Angaben dafür erst nach dem Instanziieren durch den Linker fest. Der statische RAM-Verbrauch ist aber minimal, es werden jedoch ein paar (ca. 20 plus die zu rettenden Register) Bytes auf dem Stack benötigt.
Ok, d.h. für die Minimalversion von printf+sprintf kämen die Größen von printf_p, sprintf_p, vfprintf_p und vfprintf_min zusammen? Ich würd gerne abschätzen, ob ne eigene Implementierung merklich besser abschneidet. Mit 1.31, 1.15 und 4.12 Q-Format braucht das auch satte 1kByte... Johann
printf_p brauchst du nur für stdout, vfprintf_p wirst du rein gar nicht benötigen, also vermutlich nur sprintf_p und vfprintf_std. Weiß ja nicht, ob du eher avr31 oder avr51 brauchst, darum hab ich sie beide mal genommen. Falls du mit Q-Format ein 64-bit-Integer meinst, das ist bei vfprintf leider (noch?) nicht dabei. Wäre halt auch ein ziemlicher Klopper. Schade, dass man diesen umständlichen Weg über verschiedene Bibliotheken gehen muss. Wenn man dann N mögliche Freiheitsgrade hat, explodiert die Anzahl (und die Namensgebung...) der notwendigen verschiedenen Bibliotheken ziemlich schnell.
