1 | #include <avr/io.h>
2 |
3 | #define F_CPU 8388608
4 |
5 | #include <util/delay.h>
6 |
7 | #define BAUD 9600
8 | #define MYUBRR (F_CPU/16/BAUD-1)
9 |
10 | #define DD_CS PB0 //Selektiert den Master
11 | #define DD_SCK PB1 //Takt
12 | #define DD_MOSI PB2 //Master Out, Slave In
13 | #define DD_MISO PB3 //Master In, Slave Out
14 |
15 | #define CC_FIFO PE5
16 | #define CC_FIFOP PE6
17 | #define CC_CCA PD5 //Clear Channel Assessment
18 | #define CC_SFD PD4 //Start of Frame Delimiter
19 | #define CC_RESET PB6 //Reset
20 | #define CC_VREG_EN PB7 //VREG Enable
21 |
22 | void SPI_Init(void)
23 | {
24 | // MOSI, SCK, CS, RESET ausgang, MISO eingang
25 | DDRB = (1<<DD_MOSI)|(1<<DD_SCK)|(1<<DD_CS)|(1<<CC_RESET)|(1<<CC_VREG_EN);
26 |
27 | // Master, aktiviere SPI, fck/4, MSB first, SPI mode
28 | SPCR = (1<<MSTR)|(1<<SPE)|(1<<CPHA);
29 | }
30 |
31 | uint8_t SPI_TxRx(uint8_t cData)
32 | {
33 | SPDR = cData;
34 | while(!(SPSR & (1<<SPIF)));
35 | return SPDR;
36 | }
37 |
38 | uint16_t SPI_RxReg(uint8_t Address)
39 | {
40 | uint8_t state;
41 | uint16_t data;
42 | Address = Address | 0x40;
43 |
44 | PORTB &= ~(1<<DD_CS); // CS\ low
45 |
46 | _delay_us(25);
47 |
48 | state = SPI_TxRx(Address); // eventuell den Status auswerten
49 | data = SPI_TxRx(0xff)<<8; // MSB
50 | data = data + SPI_TxRx(0xff); // LSB
51 |
52 | PORTB |= (1<<DD_CS); // CS\ high
53 | return data;
54 | }
55 |
56 | uint8_t SPI_TxReg(uint8_t Address, uint16_t data)
57 | {
58 | uint8_t state;
59 |
60 | PORTB &= ~(1<<DD_CS); // CS\ low
61 |
62 | _delay_us(25);
63 |
64 | state = SPI_TxRx(Address); // eventuell den Status auswerten
65 | SPI_TxRx(data>>8); // MSB
66 | SPI_TxRx(data); // LSB
67 |
68 | PORTB |= (1<<DD_CS); // CS\ high
69 |
70 | return state;
71 | }
72 |
73 | void SPI_TxRam(uint16_t Address, uint16_t data)
74 | {
75 | uint8_t status;
76 | Address = (Address<<6) | 0x8000;
77 |
78 | PORTB &= ~(1<<DD_CS); // CS\ low
79 |
80 | _delay_us(25);
81 | status = SPI_TxRx((uint8_t)(Address>>8));
82 |
83 | _delay_us(25);
84 | SPI_TxRx((uint8_t)(Address & 0x00ff));
85 | SPI_TxRx((uint8_t)(data>>8));
86 | SPI_TxRx((uint8_t)(data & 0x00ff));
87 |
88 | PORTB |= (1<<DD_CS); // CS\ high
89 | }
90 |
91 | void setKanal()
92 | {
93 | uint16_t FSCTRL_reg;
94 | uint16_t FSCTRL_kanal;
95 |
96 | FSCTRL_kanal = 357 + 5 * (26-11);
97 | FSCTRL_reg = (SPI_RxReg(0x18) & 0xfc00) | FSCTRL_kanal;
98 |
99 | SPI_TxReg(0x18, FSCTRL_reg);
100 | }
101 |
102 | void setShortAddress(uint16_t addr)
103 | {
104 | SPI_TxRam(0x016a, addr);
105 | }
106 |
107 | void CC2420_Init(void)
108 | {
109 | uint8_t oscStatus;
110 | uint16_t MANAND_reg;
111 |
112 | // Ein- und Ausgänge definieren
113 | DDRD &= ~(1<<CC_SFD) & ~(1<<CC_CCA);
114 | DDRE &= ~(1<<CC_FIFO) & ~(1<<CC_FIFOP);
115 |
116 | // CC2420 einschalten
117 | PORTB |= (1<<CC_VREG_EN);
118 | _delay_us(600); // VREG_EN start up time
119 |
120 | // CC2420 Reset
121 | PORTB |= (1<<CC_RESET);
122 |
123 | PORTB &= ~(1<<DD_CS); // CS\ low
124 | SPI_TxRx(0x01); // SXOSCON
125 | PORTB |= (1<<DD_CS); // CS\ high
126 | _delay_ms(1); // SXOSCON start up time
127 |
128 | // XOSC16M_PD + BIAS_PD = 0 für Crystal Oscillator (Command Strobe 0x01)
129 | MANAND_reg = SPI_RxReg(0x21);
130 | MANAND_reg &= ~(0x4080);
131 | oscStatus = SPI_TxReg(0x21, MANAND_reg);
132 |
133 | while(!(oscStatus && 0x40)); // Warte bis Crystal Oscillator stable
134 |
135 | setKanal();
136 | setShortAddress(0x0001);
137 |
138 | // Command Strobe
139 | PORTB &= ~(1<<DD_CS); // CS\ low
140 | SPI_TxRx(0x04); // STXON
141 | SPI_TxRx(0x03); // SRXON
142 | PORTB |= (1<<DD_CS); // CS\ high
143 | }
144 |
145 | int main(void)
146 | {
147 | USART_Init(MYUBRR);
148 | SPI_Init();
149 | CC2420_Init();
150 |
151 | _delay_ms(1000);
152 |
153 | while(1) {
154 | while((PINE & (1<<CC_FIFOP)) || (PIND & (1<<CC_SFD)));
155 |
156 | PORTB &= ~(1<<PB4) & ~(1<<PB5); //LED's aus
157 |
158 | // Command Strobe
159 | PORTB &= ~(1<<DD_CS); // CS\ low
160 | SPI_TxRx(0x09); // SFLUSHTX
161 | PORTB |= (1<<DD_CS); // CS\ high
162 |
163 | SPI_TxReg(0x3e, 0x0b20);
164 | SPI_TxReg(0x3e, 0x2200);
165 | SPI_TxReg(0x3e, 0x0002);
166 | SPI_TxReg(0x3e, 0x0001);
167 | SPI_TxReg(0x3e, 0x1234);
168 |
169 | while ((PIND & (1<<CC_SFD)));
170 |
171 | _delay_ms(250);
172 |
173 | PORTB |= (1<<PB4)|(1<<PB5); //LED's an
174 | _delay_ms(250);
175 | }
176 | return 0;
177 | }
