1 | #include <inttypes.h>
2 | #include <avr/io.h>
3 | #include <avr/delay.h>
4 | #include <util/twi.h>
5 | #include <stdlib.h>
6 |
7 |
8 | //-----------------------------------------------------------------------------------------------
9 | // read and write address, A15 is uesd for communication between ATmega128 and DLP-USB245M
10 | #define ADDRESS 0x8000
11 |
12 | int SendeByte(unsigned char datenbyte, unsigned char adresse);
13 |
14 | //----------------------------------------------------------------------------------------------
15 |
16 |
17 | void sysinit(void)
18 | {
19 | SFIOR=SFIOR|0x04; // interne Pull-Ups abstellen, Seite 70 datenblatt
20 | MCUCR=MCUCR|0x80; // activate the external memory interface, P29
21 | XMCRA=0x00; // The entire external memory address space is treated as one sector.
22 | XMCRB=0x00; // Writing XMBK to one enables the bus keeper on the AD7:0 lines.
23 |
24 | DDRC=0xFF; // Output
25 | DDRD=0xFF; // Output
26 | DDRB=0xFF; // Output
27 | DDRE=0xFF; // Output
28 | DDRF=0xFF; // Output
29 | PORTB=0x00;
30 | PORTE=0x00;
31 | PORTF=0x00;
32 | PORTD=0xFF; // Leds dunkel
33 |
34 |
35 |
36 | TWAR=0x03; // Adresse 0x02 = erster und einziger Slave
37 | TWBR=0x01; // Bit Rate Register -> SCLf = (CPUf/(16+2(01)*4^1))) = 149kHz
38 | TWCR=0x45; // Control Register TWINT / TWEA / TWEN / TWIE -> "high"
39 | // TWDR=0xFF; // Data Register
40 | TWSR=0xF8; // Status Register
41 |
42 | }
43 |
44 |
45 | // CPUf = 3596400
46 |
47 | int main(void)
48 | {
49 | sysinit();
50 |
51 | unsigned char adresse, i;
52 | i=0x01;
53 | while(1) //Hauptschleife
54 | {
55 | /* PORTD = 0x01;
56 | _delay_ms(10); // Blinklicht test (geht auch nicht)
57 | PORTD = 0x02;
58 | _delay_ms(10); */
59 |
60 | if(i==0x80) i=0x01; //wenn am linken Ende, von vorne anfangen
61 | else i<<=1; //ansonsten nach links schieben
62 | PORTD = TWSR;
63 | _delay_ms(500); //500ms warten
64 | SendeByte(adresse, i); //Wert an Leds übertragen
65 | }
66 |
67 | return 0;
68 | }
69 |
70 | int SendeByte(unsigned char datenbyte, unsigned char adresse)
71 | {
72 | DDRC &= !((1<<DD0)|(1<<DD1)); //SDA und SCL lesen
73 | PORTC= (1<<DD0)|(1<<DD1); //und Pullups aktivieren
74 |
75 | TWCR= (1<<TWINT)|(1<<TWSTA)|(1<<TWEN); //TWI aktivieren und Start-Kondition auslösen
76 | while(!(TWCR & (1<<TWINT))); //warten auf Start-Kondition
77 |
78 | // PORTD = TWSR;
79 | // _delay_ms(5000);
80 |
81 | if((TWSR & 0xF8) != TWSTA) return 0; //Wenn keine Start-Kondition gesendet wurde, abbrechen
82 |
83 |
84 | TWDR=adresse & (0xFE); //Adresse mit Schreibbit (XXXXXXX0) in Datenregister laden...
85 | TWCR= ((1<<TWINT)|(1<<TWEN)); //... und senden
86 | while(!(TWCR & (1<<TWINT))); //warten auf ACK oder NAK
87 | if((TWSR & 0xF8) != TW_MT_SLA_ACK) return twiStop(); //Wenn kein Slave reagiert
88 |
89 | TWDR=datenbyte; //Byte in Datenregister laden...
90 | TWCR= ((1<<TWINT)|(1<<TWEN)); //... und senden
91 | while(!(TWCR & (1<<TWINT))); //warten auf ACK oder NAK
92 | if((TWSR & 0xF8) != TW_MT_DATA_ACK) return twiStop(); //Wenn nicht von Slave akzeptiert, abbrechen
93 |
94 | TWCR= ((1<<TWINT)|(1<<TWSTO)|(1<<TWEN)); //STOP-Kondition
95 | return 0;
96 | }
