1 | /*****************************************************************************
2 | * *
3 | * EMAC DRIVER *
4 | * *
5 | *****************************************************************************/
6 |
7 | #include "eth.h"
8 | #include "endian.h"
9 | #include "part.h"
10 | #include "main.h"
11 | #include "gpio.h"
12 | #include <stdio.h>
13 | #include <stdlib.h>
14 | #include <string.h>
15 |
16 | /************************************************
17 | * VARIABLES AND STRUCTS *
18 | ************************************************/
19 |
20 | /* setting up the buffer descriptor list */
21 | unsigned int RxBd[2048]; //1024 buffer descriptors of 2 words
22 |
23 | /* setting up the receive buffer */
24 | unsigned int RxB[1024][32]; //1024 buffer of 128byte
25 |
26 |
27 | /* setting up 128 transmit buffer descriptors, thats enough! */
28 | unsigned int TxBd[256]; //128 two word buffer descriptors
29 |
30 | /* setting up the transmit buffer */
31 | unsigned int TxB[128][512]; //128 buffers of 2048 byte
32 |
33 |
34 | /* HEADER DEFINITIONS */
35 |
36 | /* ethernet encapsulation */
37 | struct ethheader {
38 | unsigned char destMAC[6];
39 | unsigned char srcMAC[6];
40 | unsigned char type[2];
41 | } __attribute__ ((packed)) *eth;
42 |
43 | /* ip header */
44 | struct ipheader {
45 | unsigned char version_header; //4bit version, 4 bit header length in 32bit-words
46 | unsigned char TOS; //0x0 for default
47 | unsigned short length; //total length of ip datagram
48 | unsigned short id; //normally incrementet by every sent packet
49 | unsigned short flags_offset; //3bit flags, 13bit offset
50 | unsigned char TTL; //time to live, normally 32 or 64
51 | unsigned char prot; //17 for UDP
52 | unsigned short chksum; //header checksum
53 | unsigned int sourceIP;
54 | unsigned int destIP;
55 | }__attribute__ ((packed)) *ip;
56 |
57 | /* udp header */
58 | struct udpheader {
59 | unsigned short srcPort; //source portnumber
60 | unsigned short destPort; //destination port number
61 | unsigned short length; //total length of udp datagram
62 | unsigned short chksum; //checksum (optional) pseudo-header, header and data
63 | } __attribute__ ((packed)) *udp;
64 |
65 |
66 | /************************************************
67 | * INITIALIZATION *
68 | ************************************************/
69 |
70 | int eth_init ( )
71 | {
72 | int i;
73 |
74 | /* enable emac in power management controller PMC */
75 | writel( 1 << AT91C_ID_EMAC, AT91C_PMC_PCER);
76 |
77 | /* disable transmit and receive circuits */
78 | writel( 0, AT91C_EMACB_NCR ); //disabling by reset network control register
79 |
80 | /* disable all interrupts */
81 | writel( ~0, AT91C_EMACB_IDR ); //disabling by writing 0xffffffff to the interrupt disable register
82 |
83 | /* set the MAC address of this device */
84 | //necessary to receive packets
85 |
86 | /* clear statistics register, enable management port, make status registers writable */
87 | writel( AT91C_EMAC_CLRSTAT |
88 | AT91C_EMAC_MPE |
89 | AT91C_EMAC_WESTAT
90 | , AT91C_EMACB_NCR );
91 |
92 | /* configure network */
93 | writel( AT91C_EMAC_SPD | //set speed to 100Mbit/s
94 | AT91C_EMAC_FD | //set full duplex mode
95 | AT91C_EMAC_CLK_HCLK_64 //set clock divider according MCK
96 | , AT91C_EMACB_NCFGR );
97 |
98 | /* enable transreceiver input clock and set to MII mode */
99 | writel( AT91C_EMAC_CLKEN, AT91C_EMACB_USRIO );
100 |
101 |
102 | /************************************************
103 | * PHY SETUP *
104 | ************************************************/
105 |
106 | /* basic control register 0x0 */
107 | writel ( PHY_SOF |
108 | PHY_WRITE |
109 | PHY_ADDRESS |
110 | PHY_BCR |
111 | PHY_CODE |
112 | PHY_BCR_AUTONEG |
113 | PHY_BCR_AUTONEG_RESTART
114 | , AT91C_EMACB_MAN );
115 | while ( !(readl(AT91C_EMACB_NSR) & AT91C_EMAC_IDLE) ); //wait for transmission completed
116 |
117 | /* read and verify PHY register entry */
118 | /* read PHY identifier, shold be 0x0022 in register 0x2 */
119 | writel ( PHY_SOF |
120 | PHY_READ |
121 | PHY_ADDRESS |
122 | PHY_ID1 |
123 | PHY_CODE
124 | , AT91C_EMACB_MAN );
125 | while ( !(readl(AT91C_EMACB_NSR) & AT91C_EMAC_IDLE) ); //wait for transmission completed
126 | if ( (readl(AT91C_EMACB_MAN) & PHY_DATA_MASK) != 0x0022 ) //read and verify ID
127 | pio_set_value(AT91C_PIN_PA(9), 0); //if doesn't match switch power LED off
128 |
129 |
130 | /************************************************
131 | * BUFFER CONFIGURATION *
132 | ************************************************/
133 |
134 | /* RECEIVE BUFFER */
135 |
136 | /* received frames are written into 128byte long receive buffers. these buffers
137 | * are stored in memory. every start location of a buffer is stored in a list.
138 | * each entry of this list consists of 2 words and is called buffer desciptor.
139 | */
140 |
141 | /* initialize descriptor list */
142 | for (i = 0; i < 1024; i++) {
143 | RxBd[i*2] = ((unsigned int) RxB[i]) & ~3; //mask the two least significant bits
144 | }
145 | RxBd[2047] |= 2; //set wrap bit of the last descriptor
146 |
147 | /* write start address of descriptor list to receive buffer queue pointer register */
148 | writel( (unsigned int) RxBd & ~3, AT91C_EMACB_RBQP ); //mask the two least significant bits of the address
149 |
150 | /* enable receiver */
151 | writel( readl(AT91C_EMACB_NCR) | AT91C_EMAC_RE, AT91C_EMACB_NCR );
152 |
153 |
154 | /* TRANSMIT BUFFER */
155 |
156 | /* Frames to be transmitted are stored in one or more buffers. the buffer size is
157 | * between 0 and 2047 byte. the start location of each transmit buffer is stored
158 | * in a tramsmit buffer descriptor list. the transmit buffer queue pointer register
159 | * points to one of the descriptors.
160 | * each descriptor entry consists of two words. the first word contains the address
161 | * and the second control and status information.
162 | */
163 |
164 | /* initialize descriptor list */
165 | for (i = 0; i < 128; i++) {
166 | TxBd[i*2] = (unsigned int) TxB[i]; //write start address of each buffer to the descriptor
167 | TxBd[i*2+1] = TxBd_USED; //set used bit, there's no frame to be sent
168 | }
169 | TxBd[255] |= TxBd_WRAP; //set wrap bit of the last buffer descriptor
170 |
171 | /* write start address of descriptor list to transmit buffer queue pointer register */
172 | writel( (unsigned int) TxBd, AT91C_EMACB_TBQP );
173 |
174 | /* enable transmitter */
175 | writel( readl(AT91C_EMACB_NCR) | AT91C_EMAC_TE, AT91C_EMACB_NCR );
176 |
177 | packet_setup();
178 |
179 | return 0;
180 | }
181 |
182 | /************************************************
183 | * PACKET SETUP *
184 | ************************************************/
185 |
186 | void packet_setup () {
187 |
188 | /* ETHERNET HEADER */
189 | /* destination MAC Address */
190 | eth->destMAC[0] = 0xff; //MAC: little endian
191 | eth->destMAC[1] = 0xff;
192 | eth->destMAC[2] = 0xff;
193 | eth->destMAC[3] = 0xff;
194 | eth->destMAC[4] = 0xff;
195 | eth->destMAC[5] = 0xff;
196 | /* Source MAC Address */
197 | eth->srcMAC[5] = 0x00;
198 | eth->srcMAC[4] = 0x2e;
199 | eth->srcMAC[3] = 0x44;
200 | eth->srcMAC[2] = 0xa2;
201 | eth->srcMAC[1] = 0x43;
202 | eth->srcMAC[0] = 0x00;
203 | /* Type */
204 | eth->type[0] = 0x08; //big endian
205 | eth->type[1] = 0x00;
206 |
207 | /* IP HEADER */
208 | /* Version and Header length */
209 | ip->version_header = 4 << 4; //version on higher-half-byte
210 | ip->version_header += 5 << 0; //header length on lower-half-byte
211 | /* TOS */
212 | ip->TOS = 0x0; //normal service
213 | /* total length */
214 | ip->length = endians(68);
215 | /* identification */
216 | ip->id = endians(0);
217 | /* flags and offset */
218 | ip->flags_offset = endians(0);
219 | /* Time To Live */
220 | ip->TTL = 32;
221 | /* Protocol */
222 | ip->prot = 17; //17 means UDP
223 | /* source IP */
224 | ip->sourceIP = endianl(10 << 0 | 0 << 8 | 168 << 16 | 192 << 24);
225 | /* destination IP (broadcast) */
226 | ip->destIP = endianl(0xffffffff);
227 | /* checksum */
228 | ip->chksum = 0; //to calculate chksum, this field has to be zero
229 | ip->chksum = endians(ip_chksum(20, (char*)ip)); //calculate IP checksum
230 |
231 | /* UDP HEADER */
232 | /* source port */
233 | udp->srcPort = endians(1044);
234 | /* destination port */
235 | udp->destPort = endians(1044);
236 | /* length */
237 | udp->length = endians(48);
238 | /* checksum */
239 | udp->chksum = endians(0); //checksum is not used
240 |
241 | }
242 |
243 | /* IP CHECKSUM CALCULATION */
244 | short ip_chksum (short header_length, char header[])
245 | {
246 | short word16;
247 | long sum = 0;
248 | short i;
249 |
250 | /* make 16 bit words out of every two adjacent 8 bit words in the packet
251 | * and add them up */
252 | for (i = 0; i < header_length; i += 2) {
253 | word16 = ((header[i] << 8) & 0xFF00) + (header[i+1] & 0xFF);
254 | sum = sum + (long) word16;
255 | }
256 |
257 | /* take only 16 bits out of the 32 bit sum and add up the carries */
258 | while (sum >> 16)
259 | sum = (sum & 0xFFFF) + (sum >> 16);
260 |
261 | /* one's complement the result */
262 | sum = ~sum;
263 |
264 | return ((short) sum);
265 | }
266 |
267 |
268 | /************************************************
269 | * TRANSMIT *
270 | ************************************************/
271 |
272 | int eth_send () //(*pBuffer, int length)
273 | {
274 |
275 | if (readl(AT91C_EMACB_FTO) >= 3)
276 | return 1;
277 | // writel(0, AT91C_EMACB_FTO);
278 |
279 | if ( TxBd[1] & (TxBd_ERR | TxBd_UNDERRUN | TxBd_BUFFEXH ))
280 | return 1;
281 | if ( !(TxBd[1] & TxBd_USED) )
282 | return 1;
283 |
284 | writel (AT91C_EMAC_COMP, AT91C_EMACB_TSR); //clear COMPLETE bit of transmit status register
285 |
286 | char *bptr = (char*) &TxB[0][0];
287 | /* copy frame in buffer */
288 | memcpy( bptr, eth, 14 );
289 | bptr += 14;
290 | memcpy( bptr, ip, 20 );
291 | bptr += 20;
292 | memcpy( bptr, udp, 8 );
293 | bptr += 8;
294 | memcpy( bptr, "1234567890helloworld1234567890helloworld", 40);
295 |
296 | /* write status and control information to TxBd */
297 | TxBd[1] = TxBd_NOCRC | TxBd_LASTBUF | 82;
298 | writel( (unsigned int) &TxBd[0], AT91C_EMACB_TBQP );
299 |
300 | writel( readl(AT91C_EMACB_NCR) | AT91C_EMAC_TSTART, AT91C_EMACB_NCR );
301 |
302 | while ( !(readl(AT91C_EMACB_TSR) & AT91C_EMAC_COMP) );
303 |
304 | /* check for error */
305 | return 0;
306 | }
