1 | ./openocd -f openocd_lpc2148.script.test
2 | Open On-Chip Debugger 1.0 (2009-04-05-14:17) svn:exportiert
3 |
4 |
5 | BUGS? Read http://svn.berlios.de/svnroot/repos/openocd/trunk/BUGS
6 |
7 |
8 | $URL: svn://svn.berlios.de/openocd/trunk/src/openocd.c $
9 | Debug: 6 0 command.c:91 script_command(): script_command - telnet_port
10 | Debug: 7 0 command.c:108 script_command(): script_command - telnet_port, argv[0]=ocd_telnet_port
11 | Debug: 8 0 command.c:108 script_command(): script_command - telnet_port, argv[1]=4444
12 | Debug: 10 0 command.c:91 script_command(): script_command - gdb_port
13 | Debug: 11 0 command.c:108 script_command(): script_command - gdb_port, argv[0]=ocd_gdb_port
14 | Debug: 12 0 command.c:108 script_command(): script_command - gdb_port, argv[1]=3333
15 | Debug: 14 0 command.c:91 script_command(): script_command - tcl_port
16 | Debug: 15 0 command.c:108 script_command(): script_command - tcl_port, argv[0]=ocd_tcl_port
17 | Debug: 16 0 command.c:108 script_command(): script_command - tcl_port, argv[1]=6666
18 | Debug: 18 0 command.c:91 script_command(): script_command - interface
19 | Debug: 19 0 command.c:108 script_command(): script_command - interface, argv[0]=ocd_interface
20 | Debug: 20 0 command.c:108 script_command(): script_command - interface, argv[1]=ft2232
21 | Debug: 22 0 command.c:91 script_command(): script_command - ft2232_device_desc
22 | Debug: 23 0 command.c:108 script_command(): script_command - ft2232_device_desc, argv[0]=ocd_ft2232_device_desc
23 | Debug: 24 0 command.c:108 script_command(): script_command - ft2232_device_desc, argv[1]=Olimex OpenOCD JTAG A
24 | Debug: 26 0 command.c:91 script_command(): script_command - ft2232_layout
25 | Debug: 27 0 command.c:108 script_command(): script_command - ft2232_layout, argv[0]=ocd_ft2232_layout
26 | Debug: 28 0 command.c:108 script_command(): script_command - ft2232_layout, argv[1]=olimex-jtag
27 | Debug: 30 1 command.c:91 script_command(): script_command - ft2232_vid_pid
28 | Debug: 31 1 command.c:108 script_command(): script_command - ft2232_vid_pid, argv[0]=ocd_ft2232_vid_pid
29 | Debug: 32 1 command.c:108 script_command(): script_command - ft2232_vid_pid, argv[1]=0x15ba
30 | Debug: 33 1 command.c:108 script_command(): script_command - ft2232_vid_pid, argv[2]=0x0003
31 | Debug: 35 1 command.c:91 script_command(): script_command - jtag_khz
32 | Debug: 36 1 command.c:108 script_command(): script_command - jtag_khz, argv[0]=ocd_jtag_khz
33 | Debug: 37 1 command.c:108 script_command(): script_command - jtag_khz, argv[1]=2000
34 | Debug: 38 1 jtag.c:2606 handle_jtag_khz_command(): handle jtag khz
35 | User : 39 1 command.c:383 command_print(): 2000 kHz
36 | Debug: 41 1 command.c:91 script_command(): script_command - jtag_nsrst_delay
37 | Debug: 42 1 command.c:108 script_command(): script_command - jtag_nsrst_delay, argv[0]=ocd_jtag_nsrst_delay
38 | Debug: 43 1 command.c:108 script_command(): script_command - jtag_nsrst_delay, argv[1]=200
39 | Debug: 45 1 command.c:91 script_command(): script_command - jtag_ntrst_delay
40 | Debug: 46 1 command.c:108 script_command(): script_command - jtag_ntrst_delay, argv[0]=ocd_jtag_ntrst_delay
41 | Debug: 47 1 command.c:108 script_command(): script_command - jtag_ntrst_delay, argv[1]=200
42 | Debug: 49 1 command.c:91 script_command(): script_command - reset_config
43 | Debug: 50 1 command.c:108 script_command(): script_command - reset_config, argv[0]=ocd_reset_config
44 | Debug: 51 1 command.c:108 script_command(): script_command - reset_config, argv[1]=trst_and_srst
45 | Debug: 52 1 command.c:108 script_command(): script_command - reset_config, argv[2]=srst_pulls_trst
46 | Debug: 53 1 jtag.c:1853 jim_newtap_cmd(): Creating New Tap, Chip: lpc2148, Tap: cpu, Dotted: lpc2148.cpu, 8 params
47 | Debug: 54 1 jtag.c:1872 jim_newtap_cmd(): Processing option: -irlen
48 | Debug: 55 1 jtag.c:1872 jim_newtap_cmd(): Processing option: -ircapture
49 | Debug: 56 1 jtag.c:1872 jim_newtap_cmd(): Processing option: -irmask
50 | Debug: 57 1 jtag.c:1872 jim_newtap_cmd(): Processing option: -expected-id
51 | Debug: 58 1 jtag.c:1985 jim_newtap_cmd(): Created Tap: lpc2148.cpu @ abs position 0, irlen 4, capture: 0x1 mask: 0xf
52 | Debug: 59 1 target.c:3961 jim_target(): Target command params:
53 | Debug: 60 1 target.c:3962 jim_target(): target create lpc2148.cpu arm7tdmi -endian little -chain-position lpc2148.cpu -variant arm7tdmi-s_r4
54 | Debug: 62 2 command.c:91 script_command(): script_command - bank
55 | Debug: 63 2 command.c:108 script_command(): script_command - bank, argv[0]=ocd_flash_bank
56 | Debug: 64 2 command.c:108 script_command(): script_command - bank, argv[1]=lpc2000
57 | Debug: 65 2 command.c:108 script_command(): script_command - bank, argv[2]=0x0
58 | Debug: 66 2 command.c:108 script_command(): script_command - bank, argv[3]=0x7d000
59 | Debug: 67 2 command.c:108 script_command(): script_command - bank, argv[4]=0
60 | Debug: 68 2 command.c:108 script_command(): script_command - bank, argv[5]=0
61 | Debug: 69 2 command.c:108 script_command(): script_command - bank, argv[6]=0
62 | Debug: 70 2 command.c:108 script_command(): script_command - bank, argv[7]=lpc2000_v2
63 | Debug: 71 2 command.c:108 script_command(): script_command - bank, argv[8]=14765
64 | User : 72 2 command.c:494 command_run_line():
65 | Debug: 74 2 command.c:91 script_command(): script_command - init
66 | Debug: 75 2 command.c:108 script_command(): script_command - init, argv[0]=ocd_init
67 | Debug: 76 3 openocd.c:137 handle_init_command(): target init complete
68 | Debug: 77 3 ft2232.c:1540 ft2232_init_ftd2xx(): 'ft2232' interface using FTD2XX with 'olimex-jtag' layout (15ba:0003)
69 | Debug: 78 296 ft2232.c:1651 ft2232_init_ftd2xx(): current latency timer: 2
70 | Debug: 79 297 ft2232.c:2079 olimex_jtag_init(): 80 08 1b
71 | Debug: 80 298 ft2232.c:2122 olimex_jtag_init(): 82 09 0f
72 | Debug: 81 298 ft2232.c:294 ft2232_speed(): 86 02 00
73 | Debug: 82 299 openocd.c:144 handle_init_command(): jtag interface init complete
74 | Debug: 83 299 jtag.c:2201 jtag_init_inner(): Init JTAG chain
75 | Debug: 84 299 jtag.c:390 jtag_call_event_callbacks(): jtag event: JTAG controller reset (RESET or TRST)
76 | Debug: 85 299 jtag.c:1450 jtag_reset_callback(): -
77 | Debug: 86 300 jtag.c:390 jtag_call_event_callbacks(): jtag event: JTAG controller reset (RESET or TRST)
78 | Debug: 87 300 jtag.c:1450 jtag_reset_callback(): -
79 | Info : 88 302 jtag.c:1570 jtag_examine_chain(): JTAG tap: lpc2148.cpu tap/device found: 0x9f3f1f0f (Manufacturer: 0x787, Part: 0xf3f1, Version: 0x9)
80 | Error: 89 302 jtag.c:1594 jtag_examine_chain(): JTAG tap: lpc2148.cpu got: 0x9f3f1f0f (mfg: 0x787, part: 0xf3f1, ver: 0x9)
81 | Error: 90 302 jtag.c:1603 jtag_examine_chain(): JTAG tap: lpc2148.cpu expected 1 of 1: 0x9f3f1f1f (mfg: 0x78f, part: 0xf3f1, ver: 0x9)
82 | Error: 91 302 jtag.c:2216 jtag_init_inner(): trying to validate configured JTAG chain anyway...
83 | Debug: 92 302 jtag.c:390 jtag_call_event_callbacks(): jtag event: JTAG controller reset (RESET or TRST)
84 | Debug: 93 302 jtag.c:1450 jtag_reset_callback(): -
85 | Debug: 94 305 openocd.c:150 handle_init_command(): jtag init complete
86 | Error: 95 307 embeddedice.c:197 embeddedice_build_reg_cache(): unknown EmbeddedICE version (comms ctrl: 0x80000000)
87 | Debug: 96 307 embeddedice.c:401 embeddedice_write_reg(): 12: 0x00000000
88 | Debug: 97 307 embeddedice.c:401 embeddedice_write_reg(): 20: 0x00000000
89 | Debug: 98 307 openocd.c:153 handle_init_command(): jtag examine complete
90 | Debug: 99 307 openocd.c:159 handle_init_command(): flash init complete
91 | Debug: 100 307 openocd.c:163 handle_init_command(): mflash init complete
