Hallo zusammen! ich wollte mein programm debuggen und da sind mir im massage-fenster ein paar meldung aufgefallen! z.B AVR Simulator: Stack Overflow at 0x005a AVR Simulator: Stack Overflow at 0x072b AVR Simulator: Unsupported instruction 'jmp' at address 0x000945 AVR Simulator: Stack Underflow at 0x0e09 AVR Simulator: Stack Underflow at 0x0e09 AVR Simulator: Stack Underflow at 0x0e09 AVR Simulator: Stack Underflow at 0x0e09 AVR Simulator: Stack Underflow at 0x0e09 AVR Simulator: Stack Underflow at 0x0e09 AVR Simulator: Stack Underflow at 0x0e09 AVR Simulator: Too many stack errors - further reporting suppressed AVR Simulator: Unsupported instruction 'call' at address 0x000043 AVR Simulator: Unsupported instruction 'jmp' at address 0x000945 AVR Simulator: Unsupported instruction 'call' at address 0x000043 AVR Simulator: Unsupported instruction 'jmp' at address 0x000945 AVR Simulator: Unsupported instruction 'call' at address 0x000043 AVR Simulator: Unsupported instruction 'jmp' at address 0x000945 AVR Simulator: Unsupported instruction 'call' at address 0x000043 AVR Simulator: Unsupported instruction 'jmp' at address 0x000945 AVR Simulator: Unsupported instruction 'call' at address 0x000043 AVR Simulator: Unsupported instruction 'jmp' at address 0x000945 AVR Simulator: Unsupported instruction 'call' at address 0x000043 AVR Simulator: Unsupported instruction 'jmp' at address 0x000945 AVR Simulator: Unsupported instruction 'call' at address 0x000043 AVR Simulator: Unsupported instruction 'jmp' at address 0x000945 AVR Simulator: Unsupported instruction 'call' at address 0x000043 AVR Simulator: Uninitialized stack pointer used at 0x0043 okee, ich versteh was er mir sagen will, aber leider nicht, was ich falsch mache! z.b: wie genau verhindere ich einen stack over/underflow !? MfG Tom
Erst mal für den richtigen Controller übersetzen, also für den, der auch zu simulieren ist. Offenbar passt das nicht zusammen.
Wenn du eine massage-Fenster siehst, musst du erst mal die schweinischen Sachen wieder zumachen!
Wenn ich mich nicht irre, gab es mal eine Studio-Version, die einen Bug hatte. Ob das in den aktuellen Versionen auch noch so ist, keine Ahnung... Lass dein Programm halt bis zum ersten Stack-Fehler laufen, und schau dir die Adressen an. Dann solltest du erkennen, was los ist. Oliver
