1 | #define XTAL 8000000 /**< clock frequency in Hz, used to calculate delay timer */
2 |
3 |
4 | /**
5 | * @name Definition for LCD controller type
6 | * Use 0 for HD44780 controller, change to 1 for displays with KS0073 controller.
7 | */
8 | #define LCD_CONTROLLER_KS0073 0 /**< Use 0 for HD44780 controller, 1 for KS0073 controller */
9 |
10 | /**
11 | * @name Definitions for Display Size
12 | * Change these definitions to adapt setting to your display
13 | */
14 | #define LCD_LINES 2 /**< number of visible lines of the display */
15 | #define LCD_DISP_LENGTH 16 /**< visibles characters per line of the display */
16 | #define LCD_LINE_LENGTH 0x40 /**< internal line length of the display */
17 | #define LCD_START_LINE1 0x00 /**< DDRAM address of first char of line 1 */
18 | #define LCD_START_LINE2 0x40 /**< DDRAM address of first char of line 2 */
19 | #define LCD_START_LINE3 0x14 /**< DDRAM address of first char of line 3 */
20 | #define LCD_START_LINE4 0x54 /**< DDRAM address of first char of line 4 */
21 | #define LCD_WRAP_LINES 0 /**< 0: no wrap, 1: wrap at end of visibile line */
22 |
23 |
24 | #define LCD_IO_MODE 1 /**< 0: memory mapped mode, 1: IO port mode */
25 | #if LCD_IO_MODE
26 | /**
27 | * @name Definitions for 4-bit IO mode
28 | * Change LCD_PORT if you want to use a different port for the LCD pins.
29 | *
30 | * The four LCD data lines and the three control lines RS, RW, E can be on the
31 | * same port or on different ports.
32 | * Change LCD_RS_PORT, LCD_RW_PORT, LCD_E_PORT if you want the control lines on
33 | * different ports.
34 | *
35 | * Normally the four data lines should be mapped to bit 0..3 on one port, but it
36 | * is possible to connect these data lines in different order or even on different
37 | * ports by adapting the LCD_DATAx_PORT and LCD_DATAx_PIN definitions.
38 | *
39 | */
40 | #define LCD_PORT PORTA /**< port for the LCD lines */
41 | #define LCD_DATA0_PORT LCD_PORT /**< port for 4bit data bit 0 */
42 | #define LCD_DATA1_PORT LCD_PORT /**< port for 4bit data bit 1 */
43 | #define LCD_DATA2_PORT LCD_PORT /**< port for 4bit data bit 2 */
44 | #define LCD_DATA3_PORT LCD_PORT /**< port for 4bit data bit 3 */
45 | #define LCD_DATA0_PIN 0 /**< pin for 4bit data bit 0 */
46 | #define LCD_DATA1_PIN 1 /**< pin for 4bit data bit 1 */
47 | #define LCD_DATA2_PIN 2 /**< pin for 4bit data bit 2 */
48 | #define LCD_DATA3_PIN 3 /**< pin for 4bit data bit 3 */
49 | #define LCD_RS_PORT LCD_PORT /**< port for RS line */
50 | #define LCD_RS_PIN 4 /**< pin for RS line */
51 | #define LCD_RW_PORT LCD_PORT /**< port for RW line */
52 | #define LCD_RW_PIN 5 /**< pin for RW line */
53 | #define LCD_E_PORT LCD_PORT /**< port for Enable line */
54 | #define LCD_E_PIN 6 /**< pin for Enable line */
