Hilfe, ich finde den Fehler einfach nicht Ferhlermeldung beim Compelieren im Keil uVesion main.c(37): error: #167: argument of type "COM_TYP *" is incompatible with parameter of type "unsigned long" main.c(37): error: #165: too few arguments in function call main()
1 | uart0_init(&com_var_1); |
C-File
1 | typedef struct |
2 | {
3 | unsigned long baudrate; |
4 | unsigned char dataBits; |
5 | unsigned char stopBits; |
6 | unsigned char parity; |
7 | } COM_TYP; |
8 | |
9 | extern COM_TYP com_var; |
1 | set_com_data(COM_TYP *pcd_data) |
2 | {
3 | pcd_data->baudrate = 9600; |
4 | pcd_data->dataBits = 8; |
5 | pcd_data->stopBits = 1; |
6 | pcd_data->parity = 0; |
7 | }
C-File
1 | /*UART0 Initialization*/
2 | int uart0_init( unsigned long int baudrate, unsigned char dataBits, unsigned char stopBits, unsigned char parity ) |
3 | {
4 | unsigned char ucTemp; |
5 | |
6 | ucTemp = 0; |
7 | // Word Lenght Select
8 | if (dataBits == 7) |
9 | ucTemp |= 0x02; |
10 | else if (dataBits == 8) |
11 | ucTemp |= 0x03; |
12 | else
13 | return(ERR_COM_INIT_LINE_SETTINGS); |
14 | |
15 | // Stop Bit Select
16 | if (stopBits == 1 ) |
17 | ucTemp |= 0x00; |
18 | else if ( stopBits == 2 ) |
19 | ucTemp |= 0x04; |
20 | else
21 | return(ERR_COM_INIT_LINE_SETTINGS); |
22 | |
23 | // Parity Enable
24 | if (parity == 0) //disable |
25 | ucTemp |= 0x00; |
26 | else if (parity == 1) //enable |
27 | ucTemp |= 0x04; |
28 | else
29 | return(ERR_COM_INIT_LINE_SETTINGS); |
30 | |
31 | //Parity Select
32 | if (parity == 'o') |
33 | ucTemp |= 0x00; |
34 | else if (parity == 'e') |
35 | ucTemp |= 0x10; |
36 | else if (parity == 1) |
37 | ucTemp |= 0x20; |
38 | else if (parity == 0) |
39 | ucTemp |= 0x30; |
40 | else
41 | return(ERR_COM_INIT_LINE_SETTINGS); |
42 | |
43 | // Devisor Latch Access Bit(DLAB) enable
44 | ucTemp |= 0x80; |
45 | U0LCR = ucTemp; /*8 bits, 1 stopbit, no Parity, enable DLAB*/ |
46 | |
47 | // Baudrate Select
48 | switch ( baudrate ) |
49 | {
50 | case 4800: |
51 | U0DLM = 0x02; /*4800 Baud Rate, 55.296.000 PCLK*/ |
52 | U0DLL = 0xD0; /*720dez=0x02Do*/ |
53 | break; |
54 | case 9600: |
55 | U0DLM = 0x01; /*9600 Baud Rate, 55.296.000 PCLK*/ |
56 | U0DLL = 0x68; /*360dez=0x0168*/ |
57 | break; |
58 | case 19200: |
59 | U0DLM = 0x00; /*19200 Baud Rate, 55.296.000 PCLK*/ |
60 | U0DLL = 0x64; /*180dez=0x0064*/ |
61 | break; |
62 | case 38400: |
63 | U0DLM = 0x00; /*38400 Baud Rate, 55.296.000 PCLK*/ |
64 | U0DLL = 0x5A; /*90dez=0x005A*/ |
65 | break; |
66 | case 76800: |
67 | U0DLM = 0x00; /*9600 Baud Rate, 55.296.000 PCLK*/ |
68 | U0DLL = 0x68; /*45dez=0x003D*/ |
69 | break; |
70 | default:
71 | //return(ERR_COM_INIT_LINE_SETTINGS);
72 | break; |
73 | |
74 | }
75 | |
76 | // Devisor Latch Access Bit(DLAB) disable
77 | ucTemp = 0; |
78 | ucTemp |= 0x00; |
79 | U0LCR = ucTemp; |
80 | |
81 | //FIFO UART enable
82 | U0FCR = 0x01; |
83 | return 1; |
84 | }
