1 | //-----------------------------------------------------------------------------
2 | // Includes
3 | //-----------------------------------------------------------------------------
4 | #include <c8051f330.h> // SFR declarations
5 | #include <stdio.h>
6 |
7 |
8 | //-----------------------------------------------------------------------------
9 | // Global CONSTANTS
10 | //-----------------------------------------------------------------------------
11 | #define SYSCLK 24500000 // SYSCLK frequency in Hz
12 | #define BAUDRATE 9600 // Baud rate of UART in bps
13 |
14 | //-----------------------------------------------------------------------------
15 | // Function PROTOTYPES
16 | //-----------------------------------------------------------------------------
17 | void SYSCLK_Init (void);
18 | void PORT_Init (void);
19 | void UART0_Init (void);
20 |
21 | //-----------------------------------------------------------------------------
22 | // Global VARIABLES
23 | //-----------------------------------------------------------------------------
24 |
25 |
26 |
27 | //-----------------------------------------------------------------------------
28 | // MAIN Routine
29 | //-----------------------------------------------------------------------------
30 |
31 | void main (void)
32 | {
33 | char input_char;
34 |
35 | //WDTCN = 0xde; // disable watchdog timer
36 | //WDTCN = 0xad;
37 |
38 | SYSCLK_Init (); // initialize oscillator
39 | PORT_Init (); // initialize crossbar and GPIO
40 | UART0_Init (); // initialize UART0
41 |
42 | //transmit example
43 |
44 | printf ("Hello World!\n");
45 |
46 |
47 | while (1)
48 | {
49 | input_char = getchar();
50 | printf("`%c`, 0x%02x\n",(unsigned char)input_char, (unsigned) input_char);
51 |
52 | }
53 | }
54 |
55 |
56 | //-----------------------------------------------------------------------------
57 | // SYSCLK_Init
58 | //-----------------------------------------------------------------------------
59 | //
60 | // This routine initializes the system clock to use an 24.5MHz crystal
61 | // as its clock source.
62 | //
63 |
64 | void SYSCLK_Init (void)
65 | {
66 |
67 | OSCICN = 0x83; // start internal oscillator with
68 | // 24.5MHz crystal
69 |
70 | }
71 |
72 |
73 | //-----------------------------------------------------------------------------
74 | // PORT_Init
75 | //-----------------------------------------------------------------------------
76 | //
77 | // Configure the Crossbar and GPIO ports
78 | //
79 |
80 | void PORT_Init (void)
81 | {
82 | P0MDOUT = 0x10; // enable TX0 as a push-pull output
83 |
84 | XBR0 = 0x01; // Enable UART0
85 | XBR1 = 0xC0;
86 |
87 | }
88 |
89 |
90 | //-----------------------------------------------------------------------------
91 | // UART0_Init
92 | //-----------------------------------------------------------------------------
93 | //
94 | // Configure the UART0 using Timer1, for <baudrate> and 8-N-1.
95 | //
96 |
97 | void UART0_Init (void)
98 | {
99 | SCON0 = 0x50; // SCON0: mode 1, 8-bit UART, enable RX
100 | TCON = 0x40;
101 | TMOD = 0x20; // TMOD: timer 1, mode 2, 8-bit reload
102 | TH1 = 0x96; // set Timer1 reload value for baudrate
103 | //PCON |= 0x80; // SMOD00 = 1
104 | TI0 = 1; // Indicate TX0 ready
105 | }
