1 | /** I N C L U D E S ********************************/
2 | #include <p18f4550.h>
3 | #include "delay.h"
4 |
5 | /** Configuration **********************************/
6 | #pragma config PLLDIV = 5 // (20 MHz crystal on PICDEMFS USB board)
7 | #pragma config CPUDIV = OSC1_PLL2
8 | #pragma config USBDIV = 2 // Clock source from 96MHzPLL/2
9 | #pragma config FOSC = HSPLL_HS
10 | #pragma config FCMEN = OFF
11 | #pragma config IESO = OFF
12 | #pragma config PWRT = OFF
13 | #pragma config BOR = ON
14 | #pragma config BORV = 3
15 | #pragma config VREGEN = ON //USB Voltage Regulator
16 | #pragma config WDT = OFF
17 | #pragma config WDTPS = 32768
18 | #pragma config MCLRE = ON
19 | #pragma config LPT1OSC = OFF
20 | #pragma config PBADEN = OFF
21 | // #pragma config CCP2MX = ON
22 | #pragma config STVREN = ON
23 | #pragma config LVP = OFF
24 | // #pragma config ICPRT = OFF // Dedicated In-CircuitDebug/Programming
25 | #pragma config XINST = OFF // Extended Instruction Set
26 | #pragma config CP0 = OFF
27 | #pragma config CP1 = OFF
28 | // #pragma config CP2 = OFF
29 | // #pragma config CP3 = OFF
30 | #pragma config CPB = OFF
31 | // #pragma config CPD = OFF
32 | #pragma config WRT0 = OFF
33 | #pragma config WRT1 = OFF
34 | // #pragma config WRT2 = OFF
35 | // #pragma config WRT3 = OFF
36 | #pragma config WRTB = OFF // Boot Block Write Protection
37 | #pragma config WRTC = OFF
38 | // #pragma config WRTD = OFF
39 | #pragma config EBTR0 = OFF
40 | #pragma config EBTR1 = OFF
41 | // #pragma config EBTR2 = OFF
42 | // #pragma config EBTR3 = OFF
43 | #pragma config EBTRB = OFF
44 |
45 | /** F U N C T I O N S ******************************/
46 | void low_isr( void );
47 | void high_isr( void );
48 |
49 | /** I N T E R R U P T S ****************************/
50 | /*
51 | * Bei PIC18 ist der low Interrupt Vector bei
52 | * 00000018h.
53 | */
54 | #pragma code low_vector=0x18
55 | void interrupt_at_low_vector( void )
56 | {
57 | _asm GOTO low_isr _endasm
58 | }
59 | #pragma code
60 |
61 | #pragma interruptlow low_isr
62 | void low_isr( void )
63 | {
64 |
65 | }
66 |
67 | /*
68 | * Bei PIC18 ist der high Interrupt Vector bei
69 | * 00000008h.
70 | */
71 | #pragma code high_vector=0x08
72 | void interrupt_at_high_vector( void )
73 | {
74 | _asm GOTO high_isr _endasm
75 | }
76 | #pragma code
77 |
78 | #pragma interruptlow high_isr
79 | void high_isr( void )
80 | {
81 | if( INTCONbits.RBIF ) // PORTB Change Interrupt
82 | {
83 | INTCONbits.RBIF = 0; // Wenn ja Interruptflag löschen
84 | Delay_ms( 750 );
85 | PORTD += 1; // PORTD xor Verknüpfen
86 | }
87 | }
88 |
89 | /** D E C L A R A T I O N S ************************/
90 | #pragma code
91 |
92 | // **********************************************
93 | //
94 | // Hauptprogramm
95 | //
96 | //
97 | // **********************************************
98 | void main( void )
99 | {
100 | // Variablen definieren
101 | int test;
102 |
103 | //Einstellen der Ports
104 | // 0 = Output
105 | // 1 = Input
106 | TRISD = 0x00; //PORTD Ausgang
107 | PORTD = 0x00;
108 |
109 | TRISB = 0xFF; //PORTB Eingang
110 |
111 | test = PORTB;
112 |
113 | // Interrupt Konfigurieren
114 | INTCONbits.GIE = 1; // Interrupts generell erlauben
115 | //INTCONbits.GIEL = 1; // Peripheral Interrupt enable
116 | INTCONbits.RBIF = 0; // Interrupt on Change Flag aus
117 | INTCONbits.RBIE = 1; // Interrupt on Change an den PINs
118 | // PORTB(7:4)
119 | //INTCON2bits.RBIP = 0; // Low Priority
120 |
121 | RCONbits.IPEN = 0; // Interrupt Priority off
122 |
123 | while( 1 );
124 | }
