Kann man lfuse ändern und hfuse belassen oder muss avrdude beide gleichzeitig ändern?
Geht auch getrennt. Steht sogar in der Anleitung beschrieben :->
Ich sag nur:
1 | $ man avrdude |
2 | /fuse |
3 | nnnnnnnn |
1 | -U memtype:op:filename[:format] |
2 | Perform a memory operation as indicated. The memtype field |
3 | specifies the memory type to operate on. The available |
4 | memory types are device-dependent, the actual configuration |
5 | can be viewed with the part command in terminal mode. Typ‐ |
6 | ically, a device’s memory configuration at least contains |
7 | the memory types flash and eeprom. All memory types cur‐ |
8 | rently known are: |
9 | calibration One or more bytes of RC oscillator calibration |
10 | data. |
11 | eeprom The EEPROM of the device. |
12 | efuse The extended fuse byte. |
13 | flash The flash ROM of the device. |
14 | fuse The fuse byte in devices that have only a sin‐ |
15 | gle fuse byte. |
16 | hfuse The high fuse byte. |
17 | lfuse The low fuse byte. |
18 | lock The lock byte. |
19 | signature The three device signature bytes (device ID). |
