1 | #include <mega168.h>
2 | #include <delay.h>
3 | #include <stdlib.h>
4 | #include <string.h>
5 |
6 |
7 | //Globale Variablen und Funktionsprototypen
8 | int FileIndex=1000;
9 | int CounterT0=0;
10 | int CounterT2=0;
11 | int iZeitT0=0;
12 | char cIST[5], cSOLL[5], cZeitT0[4];
13 | void USBinit();
14 | void NewFile(int Index, int Typ, int Handle);
15 | void ADConvert();
16 | void USBWrite(int Handle);
17 |
18 |
19 | // Alphanumeric LCD Module functions
20 | #asm
21 | .equ __lcd_port=0x05 ;PORTB
22 | #endasm
23 | #include <lcd.h>
24 |
25 | // Standard Input/Output functions
26 | #include <stdio.h>
27 |
28 | // Timer 0 overflow interrupt service routine
29 | interrupt [TIM0_OVF] void timer0_ovf_isr(void)
30 | {
31 | // Place your code here
32 | CounterT0++;
33 | if(CounterT0==60)
34 | {
35 | iZeitT0++;
36 | ADConvert();
37 | USBWrite(0);
38 | printf("\r\n");
39 | CounterT0=0;
40 | };
41 | }
42 |
43 | // Timer2 overflow interrupt service routine
44 | interrupt [TIM2_OVF] void timer2_ovf_isr(void)
45 | {
46 | // Place your code here
47 |
48 |
49 | }
50 |
51 | #define ADC_VREF_TYPE 0x00
52 |
53 | // Read the AD conversion result
54 | unsigned int read_adc(unsigned char adc_input)
55 | {
56 | ADMUX=adc_input | (ADC_VREF_TYPE & 0xff);
57 | // Delay needed for the stabilization of the ADC input voltage
58 | delay_us(10);
59 | // Start the AD conversion
60 | ADCSRA|=0x40;
61 | // Wait for the AD conversion to complete
62 | while ((ADCSRA & 0x10)==0);
63 | ADCSRA|=0x10;
64 | return ADCW;
65 | }
66 |
67 | // Declare your global variables here
68 |
69 | void main(void)
70 | {
71 | // Declare your local variables here
72 |
73 | // Crystal Oscillator division factor: 1
74 | #pragma optsize-
75 | CLKPR=0x80;
76 | CLKPR=0x00;
77 | #ifdef _OPTIMIZE_SIZE_
78 | #pragma optsize+
79 | #endif
80 |
81 | // Input/Output Ports initialization
82 | // Port B initialization
83 | // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
84 | // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
85 | PORTB=0x00;
86 | DDRB=0x00;
87 |
88 | // Port C initialization
89 | // Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
90 | // State6=T State5=T State4=T State3=T State2=T State1=T State0=T
91 | PORTC=0x00;
92 | DDRC=0x00;
93 |
94 | // Port D initialization
95 | // Func7=Out Func6=Out Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
96 | // State7=0 State6=0 State5=T State4=T State3=T State2=T State1=T State0=T
97 | PORTD=0x00;
98 | DDRD=0xC0;
99 |
100 | // Timer/Counter 0 initialization
101 | // Clock source: System Clock
102 | // Clock value: Timer 0 Stopped
103 | // Mode: Normal top=FFh
104 | // OC0A output: Disconnected
105 | // OC0B output: Disconnected
106 | TCCR0A=0x00;
107 | TCCR0B=0x00;
108 | TCNT0=0x00;
109 | OCR0A=0x00;
110 | OCR0B=0x00;
111 |
112 | // Timer/Counter 1 initialization
113 | // Clock source: System Clock
114 | // Clock value: Timer1 Stopped
115 | // Mode: Normal top=FFFFh
116 | // OC1A output: Discon.
117 | // OC1B output: Discon.
118 | // Noise Canceler: Off
119 | // Input Capture on Falling Edge
120 | // Timer1 Overflow Interrupt: Off
121 | // Input Capture Interrupt: Off
122 | // Compare A Match Interrupt: Off
123 | // Compare B Match Interrupt: Off
124 | TCCR1A=0x00;
125 | TCCR1B=0x00;
126 | TCNT1H=0x00;
127 | TCNT1L=0x00;
128 | ICR1H=0x00;
129 | ICR1L=0x00;
130 | OCR1AH=0x00;
131 | OCR1AL=0x00;
132 | OCR1BH=0x00;
133 | OCR1BL=0x00;
134 |
135 | // Timer/Counter 2 initialization
136 | // Clock source: System Clock
137 | // Clock value: 31,250 kHz
138 | // Mode: Normal top=FFh
139 | // OC2A output: Disconnected
140 | // OC2B output: Disconnected
141 | ASSR=0x00;
142 | TCCR2A=0x00;
143 | TCCR2B=0x06;
144 | TCNT2=0x00;
145 | OCR2A=0x00;
146 | OCR2B=0x00;
147 |
148 | // External Interrupt(s) initialization
149 | // INT0: Off
150 | // INT1: Off
151 | // Interrupt on any change on pins PCINT0-7: Off
152 | // Interrupt on any change on pins PCINT8-14: Off
153 | // Interrupt on any change on pins PCINT16-23: Off
154 | EICRA=0x00;
155 | EIMSK=0x00;
156 | PCICR=0x00;
157 |
158 | // Timer/Counter 0 Interrupt(s) initialization
159 | TIMSK0=0x01;
160 | // Timer/Counter 1 Interrupt(s) initialization
161 | TIMSK1=0x00;
162 | // Timer/Counter 2 Interrupt(s) initialization
163 | TIMSK2=0x01;
164 |
165 | // USART initialization
166 | // Communication Parameters: 8 Data, 1 Stop, No Parity
167 | // USART Receiver: Off
168 | // USART Transmitter: On
169 | // USART0 Mode: Asynchronous
170 | // USART Baud Rate: 9600
171 | UCSR0A=0x00;
172 | UCSR0B=0x08;
173 | UCSR0C=0x06;
174 | UBRR0H=0x00;
175 | UBRR0L=0x17;
176 |
177 | // Analog Comparator initialization
178 | // Analog Comparator: Off
179 | // Analog Comparator Input Capture by Timer/Counter 1: Off
180 | ACSR=0x80;
181 | ADCSRB=0x00;
182 |
183 | // ADC initialization
184 | // ADC Clock frequency: 1000,000 kHz
185 | // ADC Voltage Reference: AREF pin
186 | // ADC Auto Trigger Source: None
187 | // Digital input buffers on ADC0: On, ADC1: On, ADC2: On, ADC3: On
188 | // ADC4: On, ADC5: On
189 | DIDR0=0x00;
190 | ADMUX=ADC_VREF_TYPE & 0xff;
191 | ADCSRA=0x83;
192 |
193 | // LCD module initialization
194 | lcd_init(20);
195 |
196 | // Global enable interrupts
197 | #asm("sei")
198 |
199 |
200 | TCCR0B=0x03;
201 |
202 | while (1)
203 |
204 | {
205 | if(PORTD.4==1)
206 | {
207 | delay_ms(100);
208 | USBinit();
209 | };
210 |
211 | if(PORTC.2==1)
212 | {
213 | delay_ms(100);
214 | NewFile(FileIndex,0,0);
215 | NewFile(FileIndex,1,1);
216 | ADConvert();
217 | USBWrite(1);
218 | TCCR0B=0x03;
219 | };
220 |
221 |
222 |
223 | };
224 | }
225 |
226 | void USBinit()
227 | {
228 | printf("U\r");
229 | }
230 |
231 | void NewFile(int Index, int Typ, int Handle) // Funktion zum Anlegen einer neuen TXT-Datei
232 | {
233 | if(Typ==0)
234 | {
235 | printf("O %iW>MESS%i.TXT\r",Handle,Index); // neue TXT-Datei erzeugen -> Tracking
236 | };
237 | if(Typ==1)
238 | {
239 | printf("O %iW>ZUSA%i.TXT\r",Handle,Index); // neue TXT-Datei erzeugen -> Zusammenfassung
240 | };
241 | }
242 |
243 | void ADConvert()
244 | {
245 | int iIST, iSOLL;
246 | float fIST, fSOLL;
247 | // AD Werte einlesen
248 | iIST=read_adc(0);
249 | iSOLL=read_adc(1);
250 | // Winkel berechnen
251 | fIST=((float)iIST)/1023*90;
252 | fSOLL=((float)iSOLL)/1023*90;
253 | // Winkel in char wandeln
254 | ftoa(fIST,2,cIST);
255 | ftoa(fSOLL,2,cSOLL);
256 | }
257 |
258 | void USBWrite(int Handle)
259 | {
260 | int Laenge;
261 | itoa (iZeitT0, cZeitT0);
262 | //Laenge = strlen(cZeitT0) + strlen(cSOLL) + strlen(cIST) + 10;
263 | //printf("W%i>%s\r",Handle, Laenge);
264 | printf("%s;\r",cZeitT0);
265 | printf("\n");
266 | printf("%s;\r",cIST);
267 | printf("\n");
268 | printf("%s\r\n",cSOLL);
269 | //printf("C%i\r",Handle);
270 | }
