was ist dem an dem Code Falsch?
Als Compiler verwnde ich WinAvr
1 | #include <avr/io.h>
2 |
3 | #define USART_BAUDRATE 9600
4 | #define BAUD_PRESCALE (((F_CPU / (USART_BAUDRATE * 16UL))) - 1)
5 |
6 | int main (void)
7 | {
8 | char ReceivedByte;
9 |
10 | UCSRB |= (1 << RXEN) | (1 << TXEN); // Turn on the transmission and reception circuitry
11 | UCSRC |= (1 << URSEL) | (1 << UCSZ0) | (1 << UCSZ1); // Use 8-bit character sizes
12 |
13 | UBRRL = BAUD_PRESCALE; // Load lower 8-bits of the baud rate value into the low byte of the UBRR register
14 | UBRRH = (BAUD_PRESCALE >> 8); // Load upper 8-bits of the baud rate value into the high byte of the UBRR register
15 |
16 | for (;;) // Loop forever
17 | {
18 | while ((UCSRA & (1 << RXC)) == 0) {}; // Do nothing until data have been recieved and is ready to be read from UDR
19 | ReceivedByte = UDR; // Fetch the recieved byte value into the variable "ByteReceived"
20 |
21 | while ((UCSRA & (1 << UDRE)) == 0) {}; // Do nothing until UDR is ready for more data to be written to it
22 | UDR = ReceivedByte; // Echo back the received byte back to the computer
23 | }
24 | }
Als Fehlermeldung erhalte ich:
main.c:10: error: 'UCSRB' undeclared (first use in this function)
main.c:10: error: (Each undeclared identifier is reported only once
main.c:10: error: for each function it appears in.)
main.c:11: error: 'UCSRC' undeclared (first use in this function)
main.c:11: error: 'URSEL' undeclared (first use in this function)
main.c:13: error: 'UBRRL' undeclared (first use in this function)
main.c:14: error: 'UBRRH' undeclared (first use in this function)
main.c:18: error: 'UCSRA' undeclared (first use in this function)
main.c:19: error: 'UDR' undeclared (first use in this function)
Und zwar immer wenn ich den USART beutzen möcht auch bei anderen Codes.
mfg alex
