Mit AVR Studio 4.16 habe ich diese fertigen Source Files als neues AVR GCC Projekt geladen. Danach Build angewählt - ...... Als Fehlermeldung kommt dann .......... rm -rf 1234567.o 1234567.elf dep/* 1234567.hex 1234567.eep 1234567.lss 1234567.map Build succeeded with 0 Warnings... avr-gcc -mmcu=attiny2313 -Wall -gdwarf-2 -std=gnu99 -DF_CPU=9216000UL -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT 1234567.o -MF dep/1234567.o.d -c ../1234567.c In file included from ../1234567.c:99: c:/winavr-20090313/lib/gcc/../../avr/include/avr/signal.h:36:2: warning: #warning "This header file is obsolete. Use <avr/interrupt.h>." ../1234567.c: In function 'Init_Chip': ../1234567.c:269: error: 'CTC1' undeclared (first use in this function) ../1234567.c:269: error: (Each undeclared identifier is reported only once ../1234567.c:269: error: for each function it appears in.) ../1234567.c:277: error: 'UCR' undeclared (first use in this function) ../1234567.c:278: error: 'UBRR' undeclared (first use in this function) ../1234567.c: At top level: ../1234567.c:321: warning: 'SIG_UART_RECV' appears to be a misspelled signal handler ../1234567.c:373: warning: 'SIG_UART_TRANS' appears to be a misspelled signal handler ../1234567.c: In function 'Phone_Init': ../1234567.c:458: warning: pointer targets in passing argument 1 of 'UART_Print' differ in signedness ../1234567.c:462: warning: pointer targets in passing argument 1 of 'UART_Print' differ in signedness ../1234567.c: In function 'Phone_ReadSimPhonebook': ../1234567.c:482: warning: pointer targets in passing argument 1 of 'UART_Print' differ in signedness ../1234567.c: In function 'main': ../1234567.c:594: warning: pointer targets in passing argument 2 of 'Str_Cpy' differ in signedness ../1234567.c:649: warning: pointer targets in passing argument 1 of 'UART_Print' differ in signedness make: *** [1234567.o] Error 1 Build failed with 5 errors and 8 warnings... Kann mir jemand helfen? Source Files.... /******************************************************************** * Title: Garagentorsteuerung mit Siemens S25 Handy * Author: Dario Carluccio * You might find more AVR related stuff at my homepage: * http://www.carluccio.de * Date: 10/2005 * Version: v2.0 * Purpose: Controls a Garage Gate with a Cellular Phone * Software: AVR-GCC to compiler * Hardware: ATS90S2313 * B.0 = Output LED Init (1= Init LED On) * B.1 = Output LED Ready (1= Ready LED On) * B.2 = Output LED Gate Open (1= Gate Open LED On) * B.3 = Output Gate Control (1= open/close Gate Impulse [1s]) * B.4 = Input Status Gate Open (1= Gate Open) * D.0 = RXD UART Input connected to Cellphone Siemens S25 * D.1 = TXD UART Output connected to Cellphone Siemens S25 * * The Gate Open/Close Control Line is triggered for one second everytime * the Celular Phone receives an incoming call from one of the Caller IDs * stored on the SIM Card on Place 2-10. (Stored without Arecode [+49|0] * to avoid malfunction when Provider does not transmit full Number) * * If the Gate is Open for more than 600 Seconds the Phone calls the Number * Stored on Place 1, which is stored with Arecode [+49] * * Status LED Init: On during Init * Status LED Ready: Flashing when Idle * Status LED Gate Open: On when the Gate is Open * ************************************************************************ ******* * The Phone has to support the following Commands: * * Activate Cellular result codes (extended Format of RING-Message) * -> at+clip=1<cr><lf> * <- OK<cr><lf> * * Select SIM phonebook * -> at+cpbs=SM<cr><lf> * <- OK<cr><lf> * * Read Entry "1" from SIM phonebook * -> at+cpbr=1<cr><lf> * <- +CPBR: 1,"01234567890",145,"name"<cr><lf> * <- <cr><lf> * <- OK<cr><lf> * * Issue outgoing Call to first Number in SIM-Memory: * -> atd>SM1;<cr><lf> * * Incoming Call is signalised: * <- <cr><lf> * <- +CRING: VOICE<cr><lf> * <- <cr><lf> * <- +CLIP: +492327957555,145<cr><lf> ************************************************************************ ****** * * LEDs, Laser and Switch are connected as Follows: * +------+ +----------+ * AVR-Pin 12 (B0) o------| 330R |------| Init-LED |-------------+ * +------+ +----------+ | * | * +------+ +-----------+ | * AVR-Pin 13 (B1) o------| 330R |------| Ready-LED |------------+ * +------+ +-----------+ | * | * +------+ +-----------------+ | * AVR-Pin 14 (B2) o--+---| 330R |------| Gate-Status-LED |------+ * | +------+ +-----------------+ | * | | * | +-------+ | * | ,----| Laser |---o +5V | * | +------+ | / C +-------+ | * +---| 10 K |---|< | * +------+ B | \ E | * `------------------------+ * BC547 | * | * +------+ +-----------------+ | * AVR-Pin 15 (B3) o--+---| 330R |------| Gate-Action-LED |------+--o GND * | +------+ +-----------------+ * | * | ,--------------------o Open Button + * | +------+ | / C * +---| 10 K |---|< * +------+ B | \ E * `--------------------o Open Button - * BC547 * ************************************************************************ ******/ // ******************************************************************** // * Includes // ******************************************************************** #include <inttypes.h> #include <avr/io.h> #include <avr/eeprom.h> #include <avr/signal.h> #include <avr/pgmspace.h> #include <avr/interrupt.h> // ******************************************************************** // * Prototypes // ******************************************************************** int main (void); int EEP_eq_SB (uint8_t Ptr); void Flash_Ready_LED (uint8_t Times); void Init_Chip (void); void Open_Gate (void); void Phone_Init (void); void Phone_ReadSimPhonebook (void); void Str_Cpy (uint8_t* Destination, const uint8_t* Source); int Str_Len (uint8_t* StringVar); void UART_Print (uint8_t* Message, uint8_t Number); void Wait_for_OK (void); // ******************************************************************** // * Defines // ******************************************************************** // Frequency + Bautrate #define CRYSTAL_FREQ 9216000 // Crystal Frequency e.g. 9,216 Mhz #define UART_BAUD_RATE 19200 // Baud Rate 19200 #define Max_Gate_Open 6000 // Gate-Open Time after Phone-Call is done x 100ms #define SIM_Delimiter '\0' // EEPROM Memory Delimiter Char // Output LEDs and Gate Control #define LED_Init_PORT PORTB // Init LED - PORT #define LED_Init_PIN PINB // Init LED - PIN #define LED_Init_BIT 0 // Init LED - BIT #define LED_Ready_PORT PORTB // Ready LED - PORT #define LED_Ready_PIN PINB // Ready LED - PIN #define LED_Ready_BIT 1 // Ready LED - BIT #define LED_Gate_PORT PORTB // Gate Open LED - PORT #define LED_Gate_PIN PINB // Gate Open LED - PIN #define LED_Gate_BIT 2 // Gate Open LED - BIT #define Gate_Ctrl_PORT PORTB // Gate Control - PORT #define Gate_Ctrl_PIN PINB // Gate Control - PIN #define Gate_Ctrl_BIT 3 // Gate Control - BIT // Input Gate Status #define Gate_Status_PORT PORTB // Gate Status - PORT #define Gate_Status_PIN PINB // Gate Status - PIN #define Gate_Status_BIT 4 // Gate Status - BIT // EEPROM Access #ifndef EEMEM #define EEMEM _attribute_ ((section (".eeprom"))) #endif // ******************************************************************** // * Macros // ******************************************************************** // BitSet sets the BitNo #define BitSet(Byte, BitNo) Byte |= (1<<BitNo) // BitClear clears the BitNo #define BitClear(Byte, BitNo) Byte &= ~(1<<BitNo) // Output Control #define LED_Init_On BitSet (LED_Init_PORT, LED_Init_BIT) #define LED_Init_Off BitClear (LED_Init_PORT, LED_Init_BIT) #define LED_Ready_On BitSet (LED_Ready_PORT, LED_Ready_BIT) #define LED_Ready_Off BitClear (LED_Ready_PORT, LED_Ready_BIT) #define LED_Gate_On BitSet (LED_Gate_PORT, LED_Gate_BIT) #define LED_Gate_Off BitClear (LED_Gate_PORT, LED_Gate_BIT) #define Gate_Ctrl_On BitSet (Gate_Ctrl_PORT, Gate_Ctrl_BIT) #define Gate_Ctrl_Off BitClear (Gate_Ctrl_PORT, Gate_Ctrl_BIT) // Input Control #define Gate_Is_Open bit_is_clear (Gate_Status_PIN, Gate_Status_BIT) // AT-Commands #define CMD_atCLIP "at+clip=1" #define CMD_atSIM "at+cpbs=SM" #define CMD_atGetPB "at+cpbr=" #define CMD_atH0 "at+chup" #define CMD_atDT "atd>SM1;" // ******************************************************************** // *** *** // *** Global Variables in RAM *** // *** *** // ******************************************************************** // Counters volatile uint8_t cnt_2ms; // Counter 5ms volatile uint8_t cnt_Ready_Led; // Counter Ready LED volatile uint8_t cnt_Pulse; // Counter for Pulse volatile uint16_t cnt_Gate_Open; // Counter for GeteOpen (600s=6000x100ms) // UART Communication: Buffers and Vars #define UART_Rec_Len 32 #define UART_Send_Len 24 #define EEP_Len 128 volatile uint8_t UART_Rec_Buffer[UART_Rec_Len]; // UART Receive-Buffer volatile uint8_t UART_Rec_Ptr; // Actual Rec Position volatile uint8_t UART_Rec_OK; // = 1 if 'O','K',<CR>,<LF> was received (Count 4-3-2-1) volatile uint8_t UART_Rec_CLIP; // = 1 if 'C','L','I','P', [...] ',' was received (Count 5-4-3-2-1) volatile uint8_t UART_Send_Buffer[UART_Send_Len]; // UART Send-Buffer volatile uint8_t UART_Send_Active; // UART Send-Buffer Status: 0: Buffer empty, 1: Sending // EEPROM Memory uint8_t EEPROM_Array[EEP_Len] EEMEM; // Buffer for Phonenumbers copied from Phone SIM (Space for 118 Digits) // ******************************************************************** // *** *** // *** Sting Functions *** // *** *** // ******************************************************************** // Calculate Length of Sting int Str_Len (uint8_t* StringVar){ int i = 0; while (StringVar[i] != '\0') i++; return i; } // Copy String: Destination = Source void Str_Cpy (uint8_t* Destination, const uint8_t* Source) { int i=0; while (Source[i] != '\0') { Destination[i] = Source[i]; i++; } Destination[i] = '\0'; } // ******************************************************************** // *** *** // *** Init Chip *** // *** *** // ******************************************************************** // ******************************************************************** // * Init Ports, Timers, UART and Interrupts // * - Port B: Bit4 Input, Others Output // * - Port D: Bit1 Input, Others Output // * - Timer 1: Interrupt every 10 ms // * - Enable Serial Port // ******************************************************************** void Init_Chip (void) { // Port B: // Bit 4 = Input // Others = Output DDRB = 0xEF; // DDR Port B: 1110 1111 PORTB = 0; // Init LED ON // Port D: // Bit 0 = Input // Others = Output DDRD = 0xFF; // DDR Port D: 1111 1110 // Timer 1: Interrupt every 10 ms // - CK/64 (CS11 + CS 10) // - CTC1 (Clear Timer on Compare match) // - OCR1 (Output Compare Register: [ms]*CRYSTAL_FREQ/(1000*64) // - OCIE1 (Output Compare Interrupt Enable) TCCR1A = 0; // No Output, No PWM TCCR1B = _BV(CS11)|_BV(CS10)|_BV(CTC1); // CK/64 , CTC1 OCR1 = 2 * CRYSTAL_FREQ / 64000L; // 2ms: 5A0h = 1440d TIMSK = (1<<OCIE1A); // Interrupt Enable // Serial Port 1 // - Enable RxD and TxD // - Enable interrupts for RxD and TxD // - Set Baud Rate: UBRR= (F_CPU / (16*BAUD) )-1 UCR = (1 << RXEN) | (1 << TXEN) | (1 << TXCIE) | (1 << RXCIE); UBRR = (CRYSTAL_FREQ / (UART_BAUD_RATE * 16L)) - 1; } // ******************************************************************** // *** *** // *** Timer Interrupt *** // *** *** // ******************************************************************** // ******************************************************************** // * Timer / Counter Interrupt every 2ms // * - every 100ms // * - increment cnt_Ready_Led // * - decrement cnt_Pulse if cnt_Pulse > 0 // * - increment 16Bit Gate Open Counter, if Gate is open // ******************************************************************** SIGNAL (SIG_OUTPUT_COMPARE1A){ if (++cnt_2ms==50){ // every 50 x 2ms = 100ms cnt_2ms=0; // Reset 2ms Counter cnt_Ready_Led++; // increment 100ms counter if (cnt_Pulse > 0) { // decrement Pulse counter as long as positive cnt_Pulse--; } // Increment Gate Open Counter, if Gate is open // !!! Attention: Overflow is NOT detected, but it is 16Bit !!! if (cnt_Gate_Open > 0){ cnt_Gate_Open++; } } } // ******************************************************************** // *** *** // *** U A R T *** // *** *** // ******************************************************************** // ******************************************************************** // * UART Receive Interrupt // * - If 0-9 of ";" ist received write Value to UART_Rec_Buffer // * - Detect OK Received // ******************************************************************** SIGNAL (SIG_UART_RECV){ int i; i = UDR; // Save only '0' to '9' and ',' and '+' if ( ((i >= '0') && (i <= '9')) || (i == ',') || (i == '+') ) { UART_Rec_Buffer[UART_Rec_Ptr] = i; if (UART_Rec_Ptr < UART_Rec_Len) { UART_Rec_Ptr++; } } // UART_Rec_OK counts down from 4 to 1 while receiving 'O' 'K' <cr> <lf> if ((UART_Rec_OK == 0) && (i == 'O')) UART_Rec_OK = 4; else if ((UART_Rec_OK == 4) && (i == 'K')) UART_Rec_OK = 3; else if ((UART_Rec_OK == 3) && (i == 0x0d)) UART_Rec_OK = 2; else if ((UART_Rec_OK == 2) && (i == 0x0a)) UART_Rec_OK = 1; else if (UART_Rec_OK != 1){ UART_Rec_OK = 0; UART_Rec_Buffer[UART_Rec_Ptr] = '\0'; } // UART_Rec_CLIP counts down from 4 to 1 while receiving 'C' 'L' 'I' 'P' if ((UART_Rec_CLIP == 0) && (i == 'C')) UART_Rec_CLIP = 5; else if ((UART_Rec_CLIP == 5) && (i == 'L')) UART_Rec_CLIP = 4; else if ((UART_Rec_CLIP == 4) && (i == 'I')) UART_Rec_CLIP = 3; else if ((UART_Rec_CLIP == 3) && (i == 'P')) { UART_Rec_CLIP = 2; UART_Rec_Ptr = 0; // If CLIP Received Reset Pointer } else if ((UART_Rec_CLIP == 2) && (i == ',')) UART_Rec_CLIP = 1; else if (UART_Rec_CLIP > 2) UART_Rec_CLIP = 0; // Reset Pointer after ':' // if (i == ':'){ // UART_Rec_Ptr = 0; // Reset Pointer // } } // ******************************************************************** // * UART Transmit Complete Interrupt Function // * - Send the Rest of UART_Send_Buffer // * - UART_Send_Active is used as Pointer to UART_Send_Buffer // * - When finished set UART_Send_Active = 0 // ******************************************************************** SIGNAL (SIG_UART_TRANS) { if (UART_Send_Active > 0){ /* Go to next character in string */ if (UART_Send_Buffer[UART_Send_Active] == '\0') { /* String has been sent */ UART_Send_Active = 0; } else { /* Send next character in string */ UDR = UART_Send_Buffer[UART_Send_Active]; UART_Send_Active++; } } } // ******************************************************************** // * Print Strint to UART // * - Wait until last Sting is send completly // * - If Number >0 and Number <10 then attach Number to String // * - Add 'CR' to String // * - Add 'LF' to String // * - Send first Char of String // * - Rest of Buffer will be send by SIGNAL(SIG_UART_TRANS) // ******************************************************************** void UART_Print (uint8_t* Message, uint8_t Number) { while(UART_Send_Active); // wait for UART_Send_Activeto become 0 UART_Send_Active=1; // Active Str_Cpy ((uint8_t*)UART_Send_Buffer, Message); // copy Message to Buffer int i = Str_Len((uint8_t*)UART_Send_Buffer); // UART_Send_Buffer &= [ASC(Number)] if ((Number > 0) && (Number < 10)){ UART_Send_Buffer[i++] = Number + '0'; } UART_Send_Buffer[i++] = 0xd; // UART_Send_Buffer &= <CR> UART_Send_Buffer[i++] = 0xa; // UART_Send_Buffer &= <LF> UART_Send_Buffer[i] = '\0'; UDR = UART_Send_Buffer[0]; // Send first character } // ******************************************************************** // *** *** // *** Subroutines *** // *** *** // ******************************************************************** // ******************************************************************** // * Open The Gate: // * - Set Gate Control High // * - Set Counter to release Gate Control after one second // ******************************************************************** void Open_Gate (void) { Gate_Ctrl_On; // Activate Gate Control cnt_Pulse = 10; // Set Counter while (cnt_Pulse>0); // Wait 1s Gate_Ctrl_Off; // Release Gate Control cnt_Pulse = 10; // Set Counter while (cnt_Pulse>0); // Wait 1s } // ******************************************************************** // * Flash the Ready-LED // * - Flash Ready-LED Times = Counter // ******************************************************************** void Flash_Ready_LED (uint8_t Times) { uint8_t Flash_Cnt; for (Flash_Cnt=1;Flash_Cnt<=Times;Flash_Cnt++){ LED_Ready_On; // Switch Ready LED On cnt_Pulse = 2; // Set Counter while (cnt_Pulse>0); // Wait 0.2s LED_Ready_Off; // Switch Ready LED Off cnt_Pulse = 2; // Set Counter while (cnt_Pulse>0); // Wait 0.2s } } // ******************************************************************** // * Init the Phone // * - Activate CLIP Mesages // * - Select SIM Phonebook // ********************************************************************/ void Phone_Init (void) { Flash_Ready_LED(1); // Flash Ready LED UART_Print(CMD_atCLIP,0); // Activate CLIP while (UART_Rec_OK != 1); // Wait until UART_Rec_OK = 1 UART_Rec_OK = 0; // Clear UART_Rec_OK Flag Flash_Ready_LED(1); // Flash Ready LED UART_Print(CMD_atSIM,0); // Select SIM Phonebook while (UART_Rec_OK != 1); // Wait until UART_Rec_OK = 1 UART_Rec_OK = 0; // Clear UART_Rec_OK Flag } // ******************************************************************** // * Read SIM-Numbers // * - Read 9 Phonebook Entrys // * - Store Numbers in EEPROM // * - Divider = "," // ********************************************************************/ void Phone_ReadSimPhonebook (void) { uint8_t i = 0; uint8_t j; uint8_t EE_Ptr = 0; // Pointer to EEPROM_Array uint8_t Comma_Cnt; // Conter for ',' in UART_Rec_Buffer for (i=1;i<10;i++){ // Read 9 Phonebook Entrys Flash_Ready_LED(1); // Flash Ready LED UART_Rec_Ptr=0; // Clear Receive Buffer UART_Print(CMD_atGetPB,i); // Send SIM-Number Request while (UART_Rec_OK != 1); // Wait until UART_Rec_OK = 1 UART_Rec_OK = 0; // Clear UART_Rec_OK Flag Comma_Cnt=0; // Reset Counter for ',' j = 0; // Store Number in EEPROM while ((Comma_Cnt < 2) && (UART_Rec_Buffer[j] != '\0')){ // Search for ',' if (UART_Rec_Buffer[j++] == ','){ Comma_Cnt++; } // Store only Numbers between first and for second ',' if ((Comma_Cnt == 1) && (UART_Rec_Buffer[j] != ',')){ eeprom_write_byte(&EEPROM_Array[EE_Ptr++],UART_Rec_Buffer[j]); } } // Store Delimiter between each Phone Number eeprom_write_byte(&EEPROM_Array[EE_Ptr++],SIM_Delimiter); } } // ******************************************************************** // Compare String in EEPROM with UART_Send_Buffer // - Compares String in EEPROM after Pointer Ptr // - Lenght Ptr minus SIM_Delimiter afer Ptr // * Pos: 0123456789 123456789 123456789 123456789 * // * eg: EEPROM: 012341213156X1245412X1212122154X14514XXX * // * 1. Call: j=12: right() must be '1245412' [13-19] * // * 2. Call: j=20: right() must be '1212122154' [21-30] * // * 3. Call: j=31: right() must be '145144' [32-36] * // * 4. Call: j=37: length = 0 -> return 0 * // * 5. Call: j=38: length = 0 -> return 0 * // ******************************************************************** int EEP_eq_SB (uint8_t Ptr) { uint8_t i; uint8_t ee_len=0; uint8_t sb_len=0; uint8_t result=1; // ee_len = Lenght of String in EEPROM between this and next while (eeprom_read_byte(&EEPROM_Array[Ptr+1+ee_len]) != SIM_Delimiter) ee_len++; // if ee_len = 0 then result = 0 if (ee_len == 0 ) { result = 0; } else { // Length of String mut be at least ee_len sb_len = Str_Len((uint8_t*)UART_Send_Buffer); // Compare ee_len=4 Chars: // - EEProm [Ptr+(ee_len-0)] == UART_Send_Buffer [sb_len-1-0] // - EEProm [Ptr+(ee_len-1)] == UART_Send_Buffer [sb_len-1-1] // - EEProm [Ptr+(ee_len-2)] == UART_Send_Buffer [sb_len-1-2] // - EEProm [Ptr+(ee_len-3)] == UART_Send_Buffer [sb_len-1-3] result = 1; for (i=0;i<ee_len;i++){ if (eeprom_read_byte(&EEPROM_Array[Ptr+ee_len-i]) != UART_Send_Buffer[sb_len-1-i]) result = 0; } } return result; } // ******************************************************************** // * Main // * - Init // * - Init Chip (Ports, Timers, UART and Interrupts) // * - Clear Buffers // * - Enable Interrupts // * - Init the Phone // * - Read Entrys 1-9 of SIM Phonebook // * - Main Loop // * - Check Gate State and Switch Gate-Open LED On and Off // * - Flash Ready LED every 3 Seconds // * - TODO: // * - If Gate is longer Open than 600 Seconds Call Entry 1 // * - Check Incoming Calls and Open Garage if OK // ********************************************************************/ int main (void) { uint8_t i = 0; // Counter uint8_t j = 0; // Counter uint8_t CID_OK = 0; // Caller ID is on Auth-List Init_Chip(); // Init Ports, Timers, UART and Interrupts LED_Init_On; // Switch Init LED On UART_Send_Active = 0; // Clear Transmit-Buffer UART_Rec_Ptr = 0; // Clear Receive-Buffer cnt_Gate_Open = 0; // Reset Gate-Counter sei(); // Emable Interrupts Phone_Init(); // Init the Phone Phone_ReadSimPhonebook(); // Read Entrys 1-9 of SIM Phonebook LED_Init_Off; // Switch Init LED On // Loop Forever for (;;) { // Check Gate State if (Gate_Is_Open) { LED_Gate_On; // Switch Gate-Open LED On if (cnt_Gate_Open == 0){ cnt_Gate_Open = 1; // Start Gate-Open Counter } } else { LED_Gate_Off; // Switch Gate-Open LED On cnt_Gate_Open = 0; // Reset Gate-Open Counter } // Check if Gate is open Longer than Max_Gate_Open * 100ms // Then Call Phonennumber stored on SIM Position 1 if (cnt_Gate_Open > Max_Gate_Open) { cnt_Gate_Open = 0; // Reset Gate-Open Counter cnt_Ready_Led = 0; LED_Init_On; // Switch Init LED On for 5 Secs. while(UART_Send_Active); // Wait until UART Send Buffer Empty UART_Send_Active=1; // UART Send Active // Call first Number in SIM-Memory copy CMD_atDT to Buffer Str_Cpy ((uint8_t*)UART_Send_Buffer, CMD_atDT); j = Str_Len((uint8_t*)UART_Send_Buffer); UART_Send_Buffer[j++]= 0xd; // Attach <CR> UART_Send_Buffer[j++]= 0xa; // Attach <LF> UART_Send_Buffer[j] = '\0'; // End Of String UDR = UART_Send_Buffer[0]; // Send first character } // Ready LED: Flash every 5 Seconds für 100ms if (cnt_Ready_Led > 50) { LED_Ready_On; if (cnt_Ready_Led > 51) { cnt_Ready_Led= 0; LED_Init_Off; } } else { LED_Ready_Off; } // If ',' and 'C','L','I','P' Received // Check if Number is in EEPROM, then open Gate if (UART_Rec_CLIP == 1){ // Reset UART_Rec_CLIP UART_Rec_CLIP = 0; // Reset Gate-Open Counter cnt_Gate_Open = 0; // Copy Number without [+49|0] from Receive Buffer temporaly to Receivebuffer if (UART_Rec_Buffer[0] == '0') { i = 1; // 01701234567 received, skip '0' } else { i = 3; // +491701234567 received, skip '+49' } j = 0; while (UART_Rec_Buffer[i] != ','){ // Copy Received CLIP-Message[j] to UART_Send_Buffer // DEBUG: // eeprom_write_byte(&EEPROM_Array[100+j],UART_Rec_Buffer[i]); UART_Send_Buffer[j++] = UART_Rec_Buffer[i++]; } UART_Send_Buffer[j] = '\0'; // Check if Number in UART_Send_Buffer is in EEPROM (right-justified) CID_OK = 0; // Browse Rest of EEPROM until SIM_End. On every SIM_Delimiter check String for (i=2;i<10;i++){ // i countd from 2 to 9 if (CID_OK == 0) { // Search Only until found first Number // Let j point to next SIM_Delimiter while (eeprom_read_byte(&EEPROM_Array[j]) != SIM_Delimiter) j++; // Check if EEPROM-String AFTER j is equal to UART_Send_Buffer (RIGHT JUSTIFIED) // DEBUG: eeprom_write_byte(&EEPROM_Array[100+i],j); CID_OK = EEP_eq_SB(j); j++; } } if (CID_OK != 0){ Open_Gate(); } // Hang UP UART_Print(CMD_atH0,0); } } return (0); }
BOR! Is das dein Ernst jetzt? Pack den Code in eine Text Datei oder wenigstens in [ C ] Tags. Unfassbar.
Anstatt Sourcecode einfach zu kopieren, solltest du dir erstmal das AVR-Tutorial durchlesen. Und wenn du zu dumm dazu bist, die Compiler-Fehler zu verstehen, dann siehe oben oder lass es besser bleiben. MfG Marius
>... >avr-gcc -mmcu=attiny2313... >... > * Hardware: ATS90S2313 >...
Danke für die Hilfen. Bin Anfänger und könnte Hilfe brauchen! Aber was bekommt man hier - nur eine dumme Antwort.
Hallo, was erwartest Du? Es wurde alles nötige gesagt. Das Programm ist für einen AT90S2313 geschrieben, Du versuchst es für einen ATTiny2313 zu compilieren. Datenblätter beider ICs greifen, die Unterschiede in den Registernamen, die der Compiler anmault, ergründen und anpassen. Das wird wohl keiner für Dich machen wollen. PS: die 6 warnings zu den pointern bei den Funktionsaufrufen sind unschön, stören aber zumindest im Moment nicht die Funktion. Gruß aus Berlin Michael
Danke das ging mit ATS90S2313.... jetzt nur noch Warnungen! Habe den fertigen Source Files "attiny2313" gegen den "ATS90S2313" als GCC Projekt geladen. Danach Build angewählt - ...... Jetzt nur noch Warnungen! Frage: Ich habe ein Atmel Evaluation- und Addon Board von der Fa. Pollin und einen attiny2313 im Sockel stecken. In den Source Files aber den ATS90S2313! Kann ich einfach in PonyProg2000 den attiny2313 anwählen und den Hexcode erzeugen? lg Andreas
Die beiden Controller sind mehr oder weniger pinkompatibel, aber nicht binärkompatibel http://www.atmel.com/dyn/resources/prod_documents/doc4298.pdf SFR-Namen, SFR-Bit Namen, IRQ-Vektor-Namen sind unterschiedlich Johann
> Kann ich einfach in PonyProg2000 den attiny2313 anwählen und den Hexcode > erzeugen? Eigne dir mal Wissen über die ganze Toolchain und deren einzelne Werkzeuge (Compiler/Assembler/Linker, Debugger und Programmer) an. Dann weißt du wenigstens, in welchem Arbeitsschritt es klemmt. Es ist klar, dass du das lernen mußt. Bei anderen ist es auch nicht gleich nach dem Einschalten gelaufen. Ein Tipp: kleinere Schritte sorgen dafür, dass du nicht so hart auf die Schnauze fällst ;-) Mach erst mal das Hello World des uC (selber, nicht herkopieren): eine blinkende LED, dann das obligatorische Lauflicht.
Hallo, danke!!! Ich lerne doch schon :-) und es gefällt mir sogar sehr gut. Hier habe ich noch etwas ... http://www.robomodules.de/portal/index.php?id=257&type=1 Statt des AT90S2313, der inzwischen nicht mehr hergestellt wird, kann allerdings auch problemlos der modernere ATtiny2313 verwendet werden. Er ist pinkompatibel und wird an Stelle des AT90S2313 ohne weitere Modifikationen in die Schaltung eingesetzt. Die bestehenden Programme können weiterhin für den AT90S2313 übersetzt werden und trotzdem in den ATtiny2313 programmiert werden. Zur Programmierung ist in diesem Fall unbedingt PonyProg ab Version 2.06f zu verwenden. Dort muss dann der Mikrocontollertyp über „Device -> AVR Micro“ auf „ATtiny2313“ gesetzt werden. Damit sich der ATtiny2313 vollständig kompatibel zum AT90S2313 verhält, sind noch die Konfigurationsbits, wie in der folgenden Abbildung angegeben, einzustellen.
