Hallo, ich bin gerade dabei ein CIC Filter zur SampleRate Reduzierung zu entwerfen (dsPic). Jedoch bin ich mir nicht ganz sicher, ob ich es richtig umgesetzt habe. Vielleicht hat noch jemand Anregungen für Verbesserungen. Es müssen NumbOutputSample * DecimationFactor Inputsamples im Eingangsarray vorhanden sein. Ich bin mir deswegen unsicher, da bei konstanten Eingangssamples eine Verstärkung >1 auftritt. Stefan typedef struct { uint16 R; // decimation factor uint16 N; // number of stages uint16 M; // comb delay, select 1 or 2 (not used now) int32 *intDelay; // ptr to delay array int32 *combDelay; // ptr to comb delay array } CICStruct; // protoype declaration void CIC ( // CIC filtering uint16 numSamps, // number of input samples (N) // N = R*p (p integer) int16 *dstSamps, // ptr to output samples // (y[n], 0 <= n < N) int16 *srcSamps, // ptr to input samples // (x[n], 0 <= n < N*R) CICStruct *filter // filter structure: ); void CIC (uint16 numSamps, int16 *dstSamps, int16 *srcSamps, CICStruct *filter) { uint16 i; uint16 i_cic; uint16 samples = 0; int32 tempX; // holds value between CIC stages int32 combY; for(i = 0; i < numSamps; i++) { // save new input sample into variable tempX = (int32)*srcSamps; // process for all N CIC stages for(i_cic = 0; i_cic < filter->N; i_cic++) { // y[n] = x[n] + y[n-1] tempX = tempX + *(filter->intDelay + i_cic); // make y[n] to y[n-1] for next loop *(filter->intDelay + i_cic) = tempX; }//for stages // select next input sample srcSamps++; samples++; // decimation and COMB filter if (samples == filter->R) { samples = 0; // process for all CIC stages for(i_cic = 0; i_cic < filter->N; i_cic++) { // backup x[n] combY = tempX; // y[n] = x[n] - x[n-1] tempX = tempX - *(filter->combDelay + i_cic); // make: x[n] to x[n-1] for next sample *(filter->combDelay + i_cic) = combY; }//for stages // save to output and select next output destination *dstSamps = (int16)tempX; dstSamps++; }//if COMB }//for numSamps }//CIC
Hallo, da sich noch keiner gemeldet hat, möchte ich nachfragen, ob schon jemand einen CIC implementiert hat und sich mal meinen Entwurf anschauen kann? MFG
Hallo, da das CIC vor der Dezimation aus Integratoren besteht, findet eine Verstärkung statt. Gmax = (RM)^N; R -> Dezimationsfaktor, M -> Anzahl der Verzögerer in den Combs (sinnvoll ist 1!), N -> Anzahl der Stufen von Integratoren und Combs. Ich habe sowohl CICs als auch SCICs in C und VHDL realisiert und sie waren auch Thema meiner Diplomarbeit. Dieser möchte ich hier allerdings nicht so streuen. Wenn Du einen Vorschlag hast, wie ich sie Dir zukommen lassen kann, sag' Bescheid. Gruß
Ich habe noch die Scilab-Variante entdeckt. Das sollte helfen..
1 | // ++ |
2 | // Die Funktion cicsim() simuliert einen CIC-Dezimator mit |
3 | // den Parametern M, N und R für einen Eingangsvektor x |
4 | // und gibt einen Ausgangsvektor y zurück. |
5 | // -- |
6 | function [y]=cicsim(x, M, N, R) |
7 | ints=zeros(1,N); |
8 | comb=zeros(N,M+2) |
9 | l = 1; |
10 | // Iteration über alle Samples: |
11 | for i=1:size(x,'*') |
12 | // Integrieren: |
13 | ints = [x(i) ints(1:$-1)] + ints; |
14 | // Dezimieren: |
15 | if (modulo(i,R) == 0) then |
16 | // Differenzieren: |
17 | comb = [[ints($); comb(1:$-1, $)] comb(:, 1:$-1)]; |
18 | comb(:, $) = comb(:, 1) - comb(:, $-1); |
19 | y(l) = comb($,$); l=l+1; |
20 | end |
21 | end |
22 | // Verstärkung kompensieren: |
23 | y = y/int((M*R)^N); |
24 | endfunction |
