Hi to you, i hope that you or some of the programmers here can help me or just to share if he has or have the same problem like mine. So, it's about something that i though will be an easy thing that obviously is not like that that's why i'm here... Trying to boot the original MBR of Win98 or Dos or any other ofter loading my program was not successful.My program is doing this: Copy the original MBR to sector 5(not used i have the check with DE). Copy itself to sector 1(replacing the original MBR) After boot: -Load itself somewhere(empty) in the RAM and continue execution from there -Then Load the Original MBR(WIN 98/DOS/etc.) to 0000:7c00 and retf to the last instruction saved on the stack(es:bx)-->0000:7c00 * I don't know why but there is some kind of mistake mine or i don't know... I have looked at many many other boot managers and there were an exelent examples of doing this but it's not working again!!!!! * Something that i should mention about is that i'm doing this over floppy disk but i dont think that there is some big difference between FD and Hard Disk. * The result is that BIOS boot from the Diskett but.After this it wait and if you press key it load again my MBR and againg and so on... ----------------------- So if someone can help with advice or to tell me why this stupid MBR(Win98) don't want to run correctly.???PLEASE i'll be very GRATEFULL to HIM or HER! Thanks Michael
what exactly do want to do?? sounds like booting 2 or more different os´s maybe you should have a look on linux bootloaders like grup
