1 | #include <msp430x16x.h>
2 |
3 | #include <msp430def.h>
4 |
5 | #pragma interrupt_handler timera_isr: TIMERA0_VECTOR timera_isr: TIMERA1_VECTOR
6 | #pragma interrupt_handler timerb_isr: TIMERB0_VECTOR timerb_isr: TIMERB1_VECTOR
7 | #pragma interrupt_handler adc_isr: ADC_VECTOR
8 | #pragma interrupt_handler sio0_isr: USART0TX_VECTOR
9 |
10 | void init_Clock();
11 | void timera_init();
12 | void timerb_init();
13 | void mittel();
14 | void init_DAC();
15 | void init_SIO();
16 | void init_ADC();
17 | //void wait_05ms();
18 | void wait_250us(unsigned int ui_Faktor);
19 |
20 | unsigned int temp;
21 | unsigned int val_DAC;
22 | unsigned char n_tb = 0;
23 | volatile n_led = 0;
24 | unsigned char n_mw = 0;
25 | unsigned int Messwerte[4];
26 | unsigned int Messwerte_LED0[4];
27 | unsigned int Messwerte_LED1[4];
28 | unsigned int Messwerte_LED2[4];
29 | unsigned long Summe;
30 | unsigned long dunkel;
31 | unsigned char Ziffern[4];
32 | unsigned int ui_Faktor;
33 | unsigned char text[1] = "A";
34 | unsigned char text2[1] = "B";
35 | unsigned int *ptr_mw0;
36 | unsigned int *ptr_mw1;
37 | unsigned int *ptr_mw2;
38 | unsigned int *ptr_mw;
39 | unsigned int mw = 0;
40 | unsigned int mw0 = 0;
41 | unsigned int mw1 = 0;
42 | unsigned int mw2 = 0;
43 | unsigned int mw0_a;
44 | unsigned int mw0_b;
45 | unsigned long value;
46 | unsigned char split[2];
47 | unsigned char n_send = 0;
48 | unsigned char Ziffern_send[4];
49 | unsigned long Mittelwert_send = 0;
50 |
51 | void main(void)
52 | {
53 | _STOP_WATCHDOG(); //definiert in "msp430def.h"
54 |
55 | ptr_mw = &mw;
56 | ptr_mw0 = &mw0;
57 | ptr_mw1 = &mw1;
58 | ptr_mw2 = &mw2;
59 |
60 | P1SEL = 0x00; //Std.IO
61 | P1DIR = 0xFF; //alles Ausgänge
62 | P1OUT = 0x00; // at startup all outputs off
63 | P1OUT |= 0x10; // Verstaerkung -1
64 | //P1OUT |= 0x01;
65 | P2SEL = 0x00; //Std.IO
66 | P2DIR = 0xFF; //alles Ausgänge
67 |
68 | P5SEL = 0xFF; //Std.IO
69 |
70 | P3SEL = 0xf0; //P3.0..3 Standard I/O; P3.4..7 Peripheral Modul Function (UART)
71 | P3DIR = 0x00; //P3.0..3 Ausgaenge; P3.4..7 = x
72 |
73 | P6SEL = 0xFF; //Peripheral Modul Function (ADC12)
74 |
75 | init_Clock();
76 | timera_init();
77 | timerb_init();
78 | init_DAC();
79 | init_ADC();
80 | init_SIO();
81 |
82 |
83 | //Interruptfreigaben
84 | //ADC12IE = 0xFFFF; //Int-Freigabe für das Ergebnisregister ADC12MEM0
85 | //ADC12IE = ADC12IE2;
86 | //ADC12IE = 0x0004; // ADC12 memory 0,2,
87 | ADC12IE = 0x0001;
88 | TACCTL0 |= CCIE; //Timer A C/C Int Enable (für TACCR0)
89 |
90 | TBCCTL0 |= CCIE; //Tiemr_B C/C Int Enable (für TBCCR0)
91 |
92 | IE1 |= UTXIE0; //SIO0 TX-Int freigeben
93 |
94 | _BIS_SR(GIE); //GIE = 1, globale Interruptfreigabe
95 |
96 |
97 | TACTL |= MC_1; //Timer_A starten
98 | // CPU Takt
99 | DCOCTL = DCO0 + DCO1 + DCO2;
100 | BCSCTL1 = RSEL0 + RSEL1 + RSEL2 + DIVA_0;
101 | BCSCTL2 = SELM_2 + DIVM_0 + DIVS_0 + SELS;
102 |
103 |
104 | while(1); //Endlosschleife - Warten auf Interrupts
105 |
106 | }
107 |
108 |
109 | void init_Clock( void )
110 | { unsigned char i = 0;
111 | // Turning XT1 (32kHz) on
112 | _BIC_SR (OSCOFF); // Turn on XT1
113 | BCSCTL1 &= ~XTS; // LF mode
114 | for (i = 0xFFFF; i > 0; i--); // Time for osc. to set
115 | // XT1 is on
116 |
117 | // Turning XT2 (8MHz) on
118 | BCSCTL1 &= ~XT2OFF; // Turn on XT2
119 | do
120 | { // pruefroutine, ob 8 Mhz-oszillator schon stabil ist
121 | IFG1 &= ~OFIFG; // OSCFault flag loeschen (zeigt oszillatorfehler an)
122 | for (i=0xFF;i>0;i--); // warten, ob es wieder gesetzt wird
123 | }
124 | while ((IFG1 & OFIFG) != 0); // OSCFault immer noch gesetzt?
125 |
126 | }
127 |
128 |
129 | void timera_init()
130 | {
131 | TACTL = TASSEL_2 | ID_3; //SourceClock = SMCLK
132 |
133 | TACCR0 = 0x3000;
134 |
135 | }
136 |
137 |
138 | void timerb_init()
139 | {
140 |
141 | TBCTL = TBSSEL_1 | ID_0; //SourceClock = ACLK
142 |
143 | TBCCR0 = 0x15;
144 | }
145 |
146 |
147 | void init_DAC(void)
148 | {
149 | DAC12_0CTL = DAC12IR + DAC12SREF_2 + DAC12AMP_5 + DAC12ENC; // 1 reference voltage, medium speed
150 | DAC12_1CTL = DAC12IR + DAC12SREF_2 + DAC12AMP_5 + DAC12ENC; // 1 reference voltage, medium speed
151 | }
152 |
153 | void init_ADC(void)
154 | {
155 | ADC12CTL0 = SHT0_14 + ADC12ON ;
156 | ADC12CTL1 = CSTARTADD_0 + SHS_0 + SHP + ADC12DIV_0 + ADC12SSEL_2 + CONSEQ_0;
157 | //ADC12MCTL0 = SREF_2 + INCH_2; //ADC12MEM0, A2 PIN62
158 | ADC12MCTL0 = SREF_2 + INCH_3; //ADC12MEM0, A3 PIN5
159 | ADC12CTL0 |= ENC; //ADC startfähig machen
160 |
161 | }
162 |
163 | void init_SIO(void)
164 | {
165 | //SIO0
166 | ME1 |= UTXE0; //Transmitter enablen
167 | U0CTL |= CHAR; //8 data bits, 1 stop bit, no parity (8N1)
168 | //U0TCTL |= 0x10; //ACLK als UCLK festlegen
169 | U0TCTL |= SSEL1; // SMCLK als UCLK festlegen
170 | //UBR00=0xA0; UBR10=0x01; UMCTL0=0x00; /* uart0 8000000Hz 19198bps */
171 | //UBR00=0x41; UBR10=0x03; UMCTL0=0x09; /* uart0 8000000Hz 9600bps */
172 | UBR00=0x45; UBR10=0x00; UMCTL0=0xAA; /* uart0 8000000Hz 115107bp */
173 | //UBR00=0x45; UBR10=0x00; UMCTL0=0xD6; /* uart0 8000000Hz 114942bps */
174 |
175 | //UBR00=0x22; UBR10=0x00; UMCTL0=0xDD; /* uart0 8000000Hz 230547bps */
176 |
177 |
178 | U0BR1 = 0x00;
179 |
180 | U0CTL &= ~SWRST; //USART freigeben
181 |
182 | // IFG1 &= ~UTXIFG0; //initales Int-Flag löschen
183 | }
184 |
185 | void sio0_isr(void)
186 |
187 | {
188 |
189 | if(n_send < 4)
190 |
191 | {
192 |
193 | U0TXBUF = Ziffern[n_send];
194 |
195 | n_send++;
196 |
197 | }
198 |
199 | else
200 |
201 | {
202 |
203 | n_send = 0;
204 |
205 |
206 | }
207 |
208 | }
209 |
210 | void write_DAC0(unsigned int val_DAC)
211 | {
212 | DAC12_0DAT = val_DAC;
213 | }
214 | void write_DAC1(unsigned int val_DAC2)
215 | {
216 | DAC12_1DAT = val_DAC2;
217 | }
218 | void timera_isr()
219 |
220 | { /////// Initphase ////
221 | /// sekunden einlesen.. mitteln .. wert in unteres drittel des Wertebereichs ziehen, offset spannung waehlen und setzen,..verstaerkung auf Grundwert zurueck rechnen
222 | ///DAC1 Ref 2.5V
223 |
224 | //TESTOV:
225 | write_DAC0(0xa00);
226 |
227 | if(n_led == 0)
228 | {
229 | P1OUT = 0x00;
230 |
231 | }
232 | if(n_led == 1)
233 | {
234 | P1OUT |= 0x80; //P1.7 einschalten
235 | write_DAC1(0xa00);
236 |
237 | }
238 | if(n_led == 2)
239 | {
240 | P1OUT |= 0x40; //P1.6 einschalten
241 | write_DAC1(0x851); //LED
242 |
243 | }
244 | if(n_led == 3)
245 | {
246 | //write_DAC0(0x00);
247 | //a00 1,5V, 334 0.5V, 670 1V
248 | P1OUT |= 0x20; //P1.5 einschalten
249 | write_DAC1(0xfff); //LED
250 | }
251 |
252 | TBCCR0 = 0x15; //Timer_B starten (wirksam erst nach dem ersten
253 |
254 | TBCTL |= MC_1; //Timer_B erstmalig starten
255 | //P2OUT &= 0xfe;
256 | }
257 |
258 |
259 |
260 | void timerb_isr()
261 |
262 | {
263 | //P2OUT |= 0x02;
264 | n_tb++; //Inkrement des Timer_B Periodenzählers
265 |
266 | if(n_tb == 8) //4 Durchlaeufe (n_tb=4)
267 | { P1OUT = 0x00; //P1 ausschalten
268 | write_DAC1(0x00);
269 | P1OUT |= 0x10; //verstaerkung -1 an
270 | //P1OUT |= 0x01; //
271 | TBCCR0 = 0; //Timer_B stoppen
272 | n_tb = 0; //Rücksetzen des Timer_B Periodenzählers
273 |
274 | n_led++; // Zaehler naechste LED
275 | if(n_led == 4)
276 | {
277 | n_led = 0;
278 | }
279 | }
280 |
281 | ADC12CTL0 |= ADC12SC; //SC = Start Conversion
282 | while ((ADC12CTL1 & ADC12BUSY) == 1);
283 | //P2OUT &= 0xfd;
284 | }
285 |
286 | void adc_isr()
287 | {
288 | //P2OUT |= 0x04; //Pin4
289 | Messwerte[n_mw] = ADC12MEM0;;
290 | n_mw++;
291 |
292 | if(n_mw == 8)
293 | {
294 |
295 | n_mw = 0;
296 | if(n_led == 0)
297 | {
298 | mitteln();
299 |
300 |
301 | }
302 |
303 | if(n_led == 1)
304 | {
305 | mitteln();
306 | to_ascii();
307 | senden0();
308 |
309 | }
310 | if(n_led == 2)
311 | {
312 | mitteln();
313 | to_ascii();
314 | senden1();
315 | }
316 | if(n_led == 3)
317 | {
318 | mitteln();
319 | to_ascii();
320 | senden2();
321 | }
322 |
323 |
324 | }
325 |
326 |
327 |
328 | ADC12IFG = 0x0000;
329 |
330 | }
331 |
332 |
333 |
334 |
335 |
336 |
337 | void senden0(unsigned long value)
338 |
339 | {
340 | //split[0]= mw0 ; // low byte
341 | //split[1]= mw0/256; // high byte
342 | U0TXBUF = 0x23; //initiales Senden #
343 | }
344 |
345 | void senden1(unsigned long value)
346 |
347 | {
348 | //split[0]= mw1 ; // low byte
349 | //split[1]= mw1/256; // high byte
350 | U0TXBUF = 0x21; //initiales Senden "
351 | }
352 |
353 | void senden2(unsigned long value)
354 |
355 | {
356 | //split[0]= mw2; // low byte
357 | //split[1]= mw2/256; // high byte
358 | //mw2=0x600;
359 | U0TXBUF = 0x25; //initiales Senden %
360 | }
361 |
362 | void mitteln()
363 |
364 | {
365 |
366 | unsigned char i = 0;
367 |
368 |
369 |
370 | Summe = 0;
371 |
372 |
373 |
374 | for(i=0; i<8; i++)
375 |
376 | {
377 |
378 | Summe += Messwerte[i];
379 |
380 | }
381 |
382 |
383 |
384 | Summe /= i;
385 |
386 |
387 | i = 0;
388 |
389 | }
390 |
391 |
392 |
393 |
394 |
395 | void to_ascii()
396 |
397 | {
398 |
399 | unsigned char i;
400 |
401 |
402 |
403 | //Beschreiben des Ziffern-Arrays mit ASCII-Nullen
404 |
405 | for(i=0; i<4; i++)
406 |
407 | {
408 |
409 | Ziffern[i] = 0x30;
410 |
411 | }
412 |
413 |
414 |
415 | //Algorithmus zur Zerlegung des Spannungswertes in die einzelnen Ziffern
416 |
417 | while(Summe > 999) //1.000er Stelle abspalten
418 |
419 | {
420 |
421 | Summe -= 1000;
422 |
423 | Ziffern[0]++;
424 |
425 | }
426 |
427 |
428 |
429 | while(Summe > 99) //100er Stelle abspalten
430 |
431 | {
432 |
433 | Summe -= 100;
434 |
435 | Ziffern[1]++;
436 |
437 | }
438 |
439 |
440 |
441 | while(Summe > 9) //10er Stelle abspalten
442 |
443 | {
444 |
445 | Summe -= 10;
446 |
447 | Ziffern[2]++;
448 |
449 | }
450 |
451 |
452 |
453 | while(Summe > 0) //1er Stelle abspalten
454 |
455 | {
456 |
457 | Summe -= 1;
458 |
459 | Ziffern[3]++;
460 |
461 | }
462 |
463 | }
