We're looking for something that will emulate a TAPI modem, or multiple TAPI modems, using SIP (VOIP) connections for the "virtual modems". This would need to work in Windows. Does anyone have any ideas about how this could be accomplished?
tapiman schrieb: > We're looking for something that will emulate a TAPI modem, or multiple > TAPI modems, using SIP (VOIP) connections for the "virtual modems". > This would need to work in Windows. Does anyone have any ideas about > how this could be accomplished? Hello, this means to encode data into analogue audio to encode this into a digital VOIP data stream to send the data over TCP/IP, while you could simply send the data directly over TCP/IP. Absolutely senseless and it will probably not function, because VOIP codecs are optimized for human speaking, not for data, even G3 Fax does in most cases not function over VOIP. regards Reinhard
