1 | unsigned char KS8721_AutoNegotiate(Ks8721 *pKs)
2 | {
3 | unsigned int retryMax;
4 | unsigned int value;
5 | unsigned int value2;
6 | unsigned int phyAnar;
7 | unsigned int phyAnalpar;
8 | unsigned int retryCount= 0;
9 | unsigned char phyAddress;
10 | unsigned char rc = 1;
11 | int auto_neg_configure = 1;
12 |
13 | ASSERT(pKs, "-F- KS8721_AutoNegotiate\n\r");
14 | phyAddress = pKs->phyAddress;
15 | retryMax = pKs->retryMax;
16 |
17 | EMAC_EnableMdio();
18 |
19 | if (!EMAC_ReadPhy(phyAddress, KS8721_PHYID1, &value, retryMax))
20 | {
21 | TRACE_ERROR("Pb EMAC_ReadPhy Id1\n\r");
22 | rc = 0;
23 | goto AutoNegotiateExit;
24 | }
25 |
26 | if (!EMAC_ReadPhy(phyAddress, KS8721_PHYID2, &phyAnar, retryMax))
27 | {
28 | TRACE_ERROR("Pb EMAC_ReadPhy Id2\n\r");
29 | rc = 0;
30 | goto AutoNegotiateExit;
31 | }
32 | value2 = ((phyAnar>>10) & KS8721_LSB_MASK);
33 |
34 | if( ( value == KS8721_OUI_MSB ) && ( value2 == KS8721_OUI_LSB))
35 | {
36 | // TRACE_DEBUG("Vendor Number Model = 0x%X\n\r", ((phyAnar>>4)&0x3F));
37 | // TRACE_DEBUG("Model Revision Number = 0x%X\n\r", (phyAnar&0x7));
38 | }
39 | else
40 | {
41 | TRACE_ERROR("Problem OUI value -> no Micrel PHY found\n\r");
42 | }
43 |
44 | // Setup control register
45 | rc = EMAC_ReadPhy(phyAddress, KS8721_BMCR, &value, retryMax);
46 | if (rc == 0)
47 | {
48 | goto AutoNegotiateExit;
49 | }
50 |
51 | value &= ~KS8721_AUTONEG; // Remove autonegotiation enable
52 | value &= ~(KS8721_LOOPBACK|KS8721_POWER_DOWN);
53 | value |= KS8721_ISOLATE; // Electrically isolate PHY
54 | rc = EMAC_WritePhy(phyAddress, KS8721_BMCR, value, retryMax);
55 | if (rc == 0)
56 | {
57 | goto AutoNegotiateExit;
58 | }
59 |
60 | // Set the Auto_negotiation Advertisement Register
61 | // MII advertising for Next page
62 | // 100BaseTxFD and HD, 10BaseTFD and HD, IEEE 802.3
63 | phyAnar = KS8721_NP | KS8721_TX_FDX | KS8721_TX_HDX |
64 | KS8721_10_FDX | KS8721_10_HDX | KS8721_AN_IEEE_802_3;
65 | rc = EMAC_WritePhy(phyAddress, KS8721_ANAR, phyAnar, retryMax);
66 | if (rc == 0)
67 | {
68 | goto AutoNegotiateExit;
69 | }
70 |
71 | // Read & modify control register
72 | rc = EMAC_ReadPhy(phyAddress, KS8721_BMCR, &value, retryMax);
73 | if (rc == 0)
74 | {
75 | goto AutoNegotiateExit;
76 | }
77 |
78 | value |= KS8721_SPEED_SELECT | KS8721_AUTONEG | KS8721_DUPLEX_MODE;
79 | rc = EMAC_WritePhy(phyAddress, KS8721_BMCR, value, retryMax); //Set Autonegotiate enable; CONNECTION ABORTED
80 | if (rc == 0)
81 | {
82 | goto AutoNegotiateExit;
83 | }
84 |
85 | // Restart Auto_negotiation
86 | value |= KS8721_RESTART_AUTONEG; // Restart Auto negotiate
87 | value &= ~KS8721_ISOLATE;
88 | rc = EMAC_WritePhy(phyAddress, KS8721_BMCR, value, retryMax);
89 | if (rc == 0)
90 | {
91 | goto AutoNegotiateExit;
92 | }
93 | // Check AutoNegotiate complete
94 | while (1)
95 | {
96 | rc = EMAC_ReadPhy(phyAddress, KS8721_BMSR, &value, retryMax);
97 | if (rc == 0)
98 | {
99 | TRACE_ERROR("rc==0\n\r");
100 | goto AutoNegotiateExit;
101 | }
102 | //TRACE_DEBUG(" _BMSR: 0x%X\n\r", value);
103 | // Done successfully
104 | if (value & KS8721_AUTONEG_COMP)
105 | {
106 | TRACE_INFO("AutoNegotiate complete\n\r");
107 | // rc = EMAC_WritePhy(phyAddress, DM9161_BMCR, value, retryMax);
108 | // TRACE_DEBUG(" _BMCR: 0x%X\n\r", value);
109 | break;
110 | }
111 |
112 | // Timeout check
113 | if (retryMax)
114 | {
115 | if (++ retryCount >= retryMax)
116 | {
117 | KS8721_DumpRegisters(pKs);
118 | TRACE_INFO("no AutoNeg link partner found -> set 100Base HalfDuplex\n\r");
119 |
120 | // TRACE_FATAL("TimeOut\n\r");
121 | auto_neg_configure = 0;
122 | break;
123 | }
124 | }
125 | }
