Hallo
Ich habe nen ATMega32 und bekomme bei diesen Zeilen:
1 | volatile WORD Timer; /* 100Hz increment timer */
2 | volatile WORD DIAL_CNT=0;
3 |
4 | /*---------------------------------------------------------*/
5 | /* 100Hz timer interrupt generated by OC2 */
6 | /*---------------------------------------------------------*/
7 | GICR |= (1<<INT0)| (1<<INT1);
8 | MCUCR|= (1<<ISC01)|(1<<ISC11)| (1<<ISC10 );
9 |
10 | ISR(TIM2_COMP_vect)
11 | {
12 | Timer++; /* Performance counter for this module */
13 | disk_timerproc(); /* Drive timer procedure of low level disk I/O module */
14 | }
15 |
16 | ISR(INT0_vect){
17 | DIAL_CNT+=1;
18 | }
19 |
20 | ISR(INT1_vect){
21 | DIAL_CNT=0;
22 |
23 | }
...folgende Fehlermeldungen:
../main.c:43: error: expected identifier or '(' before 'volatile'
../main.c:43: error: expected ')' before '(' token
../main.c:44: error: expected identifier or '(' before 'volatile'
../main.c:44: error: expected ')' before '(' token
../main.c:46: warning: 'TIM2_COMP_vect' appears to be a misspelled
signal handler
../main.c:56: error: redefinition of '__vector_1'
../main.c:52: error: previous definition of '__vector_1' was here
Bin da recht hilflos...
...und dankbar für jede Hilfe.
