1 | #include <avr/io.h>
2 | #include <avr/interrupt.h>
3 | #include <stdint.h>
4 |
5 |
6 | #define F_CPU 8000000UL
7 | #include <util/delay.h>
8 |
9 | #define BAUD 38400UL
10 | #define UBRR_BAUD ((F_CPU/(16UL*BAUD))-1)
11 |
12 |
13 | #define red 0
14 | #define green 1
15 | #define clock 2
16 | #define bright 3
17 | #define reset 4
18 | #define brtwrt 6
19 | #define brtclk 5
20 |
21 | #define cres 1
22 | #define cclk 0
23 |
24 | volatile uint16_t datar[144];
25 | volatile uint16_t datag[144];
26 |
27 | volatile uint8_t i;
28 |
29 | volatile uint8_t col = 0;
30 | volatile uint8_t row = 0;
31 |
32 | volatile uint8_t module = 0;
33 |
34 |
35 | void slm1608()
36 | {
37 | PORTC &= ~(1<<reset); //reset
38 | PORTC |= (1<<bright);
39 | PORTC |= (1<<reset);
40 | PORTC &= ~(1<<bright);
41 | PORTC &= ~(1<<reset);
42 |
43 | PORTC |= (1<<bright); //bright auf high
44 |
45 | PORTC |= (1<<brtwrt); //brgwrt an
46 |
47 | for(col = 0; col < 16; col++){
48 | for(row = 0; row < 16; row++){
49 | if( (datar[(module*16)+col]) & (1 << row) ){
50 | PORTC |= (1<<red);
51 | }
52 | if( (datag[(module*16)+col]) & (1 << row) ){
53 | PORTC |= (1<<green);
54 | }
55 |
56 | PORTC |= (1<<clock);
57 | PORTC |= (1<<brtclk);
58 | PORTC &= ~(1<<brtclk);
59 | PORTC &= ~(1<<clock);
60 |
61 | PORTC &= ~(1<<red);
62 | PORTC &= ~(1<<green);
63 | }
64 |
65 | PORTC &= ~(1<<bright);
66 | _delay_us(200);
67 | PORTC |= (1<<bright);
68 | }
69 |
70 | if(module == 2)
71 | {
72 | PORTA |= (1<<cres); //reset high
73 | PORTA &= ~(1<<cres); //reset low
74 |
75 | for(i = 0; i<6; i++){
76 | PORTA &= ~(1<<cclk); //clock low
77 | PORTA |= (1<<cclk); //clock high
78 | }
79 |
80 | datar[3] = 2134;
81 |
82 | module = 0;
83 | }
84 |
85 | PORTA &= ~(1<<cclk); //clock low
86 | PORTA |= (1<<cclk); //clock high
87 |
88 | module ++;
89 |
90 |
91 | }
92 |
93 |
94 | void uart_init(void)
95 | {
96 | // Baudrate einstellen (Normaler Modus)
97 | UBRRH = (unsigned char) (UBRR_BAUD>>8);
98 | UBRRL = (unsigned char) (UBRR_BAUD & 0x0ff);
99 |
100 | // Aktivieren des Empfängers, des Senders und des "Daten empfangen"-Interrupts
101 | UCSRB = (1<<RXCIE)|(1<<RXEN)|(1<<TXEN);
102 |
103 | // Einstellen des Datenformats: 8 Datenbits, 1 Stoppbit
104 | UCSRC = (1<<URSEL)|(1<<UCSZ1)|(1<<UCSZ0);
105 | }
106 |
107 |
108 | int main(void)
109 | {
110 | uart_init();
111 |
112 |
113 | sei();
114 |
115 | DDRA = 0xFF; //4017
116 | DDRC = 0xFF; //Data SLM1608
117 |
118 | PORTC = 0;
119 | PORTA = 0;
120 |
121 | _delay_ms(1);
122 | PORTA |= (1<<cres); //reset high
123 | _delay_ms(1);
124 | PORTA &= ~(1<<cres); //reset low
125 | _delay_ms(1);
126 |
127 | for(i = 0; i<144; i++){
128 | datar[i] = 0;
129 | }
130 |
131 | for(i = 0; i<6; i++){
132 | PORTA |= (1<<cclk); //clock high
133 | _delay_ms(1);
134 | PORTA &= ~(1<<cclk); //clock low
135 | _delay_ms(1);
136 | }
137 |
138 |
139 | datar[0] = 51503;
140 | datag[2] = 65535;
141 |
142 | module = 0;
143 |
144 | while(1){
145 | slm1608();
146 | }
147 |
148 | }
149 |
150 |
151 | ISR(USART_RXC_vect) //Interrupt für UARTSIG_UART_RECV
152 | {
153 |
154 | unsigned char buffer;
155 |
156 | // Daten aus dem Puffer lesen ...
157 | buffer = UDR;
158 |
159 | // ... warten bis der Sendepuffer leer ist ...
160 | while ( !( UCSRA & (1<<UDRE)) )
161 | ;
162 |
163 | datar[5] = 3123 // wenn ein Zeichen gekommen ist, wird ROT[5] auf 3123 gesetzt
164 |
165 | UDR = 0x30; // 0 senden
166 | }
