1 | /************************************************************************/
2 | /* */
3 | /* Debouncing 8 Keys */
4 | /* Sampling 4 Times */
5 | /* With Repeat Function */
6 | /* */
7 | /* Author: Peter Dannegger */
8 | /* danni@specs.de */
9 | /* */
10 | /************************************************************************/
11 |
12 | #include <stdint.h>
13 | #include <avr/io.h>
14 | #include <avr/interrupt.h>
15 |
16 | #ifndef F_CPU
17 | #define F_CPU 1000000 // processor clock frequency
18 | #warning kein F_CPU definiert
19 | #endif
20 |
21 | #define KEY_DDR DDRD
22 | #define KEY_PORT PORTD
23 | #define KEY_PIN PIND
24 | #define KEY0 7
25 | #define KEY1 6
26 | #define KEY2 5
27 | #define ALL_KEYS (1<<KEY0 | 1<<KEY1 | 1<<KEY2)
28 |
29 | #define REPEAT_MASK (1<<KEY1 | 1<<KEY2) // repeat: key1, key2
30 | #define REPEAT_START 50 // after 500ms
31 | #define REPEAT_NEXT 20 // every 200ms
32 |
33 | #define LED_DDR DDRC
34 | #define LED_PORT PORTC
35 | #define LED0 3
36 | #define LED1 4
37 | #define LED2 5
38 |
39 | volatile uint8_t key_state; // debounced and inverted key state:
40 | // bit = 1: key pressed
41 | volatile uint8_t key_press; // key press detect
42 |
43 | volatile uint8_t key_rpt; // key long press and repeat
44 |
45 |
46 | ISR( TIMER0_OVF_vect ) // every 10ms
47 | {
48 | static uint8_t ct0, ct1, rpt;
49 | uint8_t i;
50 |
51 | TCNT0 = (uint8_t)(int16_t)-(F_CPU / 1024 * 10e-3 + 0.5); // preload for 10ms
52 |
53 | i = key_state ^ ~KEY_PIN; // key changed ?
54 | ct0 = ~( ct0 & i ); // reset or count ct0
55 | ct1 = ct0 ^ (ct1 & i); // reset or count ct1
56 | i &= ct0 & ct1; // count until roll over ?
57 | key_state ^= i; // then toggle debounced state
58 | key_press |= key_state & i; // 0->1: key press detect
59 |
60 | if( (key_state & REPEAT_MASK) == 0 ) // check repeat function
61 | rpt = REPEAT_START; // start delay
62 | if( --rpt == 0 ){
63 | rpt = REPEAT_NEXT; // repeat delay
64 | key_rpt |= key_state & REPEAT_MASK;
65 | }
66 | }
67 |
68 | ///////////////////////////////////////////////////////////////////
69 | //
70 | // check if a key has been pressed. Each pressed key is reported
71 | // only once
72 | //
73 | uint8_t get_key_press( uint8_t key_mask )
74 | {
75 | cli(); // read and clear atomic !
76 | key_mask &= key_press; // read key(s)
77 | key_press ^= key_mask; // clear key(s)
78 | sei();
79 | return key_mask;
80 | }
81 |
82 | ///////////////////////////////////////////////////////////////////
83 | //
84 | // check if a key has been pressed long enough such that the
85 | // key repeat functionality kicks in. After a small setup delay
86 | // the key is reported beeing pressed in subsequent calls
87 | // to this function. This simulates the user repeatedly
88 | // pressing and releasing the key.
89 | //
90 | uint8_t get_key_rpt( uint8_t key_mask )
91 | {
92 | cli(); // read and clear atomic !
93 | key_mask &= key_rpt; // read key(s)
94 | key_rpt ^= key_mask; // clear key(s)
95 | sei();
96 | return key_mask;
97 | }
98 |
99 | ///////////////////////////////////////////////////////////////////
100 | //
101 | uint8_t get_key_short( uint8_t key_mask )
102 | {
103 | cli(); // read key state and key press atomic !
104 | return get_key_press( ~key_state & key_mask );
105 | }
106 |
107 | ///////////////////////////////////////////////////////////////////
108 | //
109 | uint8_t get_key_long( uint8_t key_mask )
110 | {
111 | return get_key_press( get_key_rpt( key_mask ));
112 | }
113 |
114 | int main( void )
115 | {
116 | KEY_DDR &= ~ALL_KEYS; // konfigure key port for input
117 | KEY_PORT |= ALL_KEYS; // and turn on pull up resistors
118 |
119 | TCCR0 = (1<<CS02)|(1<<CS00); // divide by 1024
120 | TIMSK = 1<<TOIE0; // enable timer interrupt
121 |
122 | LED_PORT = 0xFF;
123 | LED_DDR = 0xFF;
124 |
125 | while(1){
126 | if( get_key_short( 1<<KEY1 ))
127 | LED_PORT ^= 1<<LED1;
128 |
129 | if( get_key_long( 1<<KEY1 ))
130 | LED_PORT ^= 1<<LED2;
131 |
132 | // single press and repeat
133 |
134 | if( get_key_press( 1<<KEY2 ) || get_key_rpt( 1<<KEY2 )){
135 | uint8_t i = LED_PORT;
136 |
137 | i = (i & 0x07) | ((i << 1) & 0xF0);
138 | if( i < 0xF0 )
139 | i |= 0x08;
140 | LED_PORT = i;
141 | }
142 | }
143 | }
