Hallo, habe versucht die Global Clock einzubinden klappt aber nicht:
1 | entity MAIN_STRUKTUR is
2 |
3 | Port ( MASTER_CLK : in std_logic; -- 27 MHZ EINGANG
4 | MASTER_EINGANG : in STD_LOGIC_VECTOR (11 downto 0);
5 | MASTER_RESET : in STD_LOGIC;
6 | SYSTEM_CLK_200MHZ_P : in std_logic;
7 | SYSTEM_CLK_200MHZ_N : in std_logic;
8 | CLK_200MHZ : out std_logic;
9 | end MAIN_STRUKTUR;
10 |
11 | architecture Behavioral of MAIN_STRUKTUR is
12 |
13 | begin
14 | -- IBUFGDS: Differential Global Clock Input Buffer
15 | -- Spartan-6
16 | -- Xilinx HDL Language Template, version 11.3
17 |
18 | IBUFGDS_inst : IBUFGDS
19 | generic map (
20 | DIFF_TERM => FALSE, -- Differential Termination
21 | IOSTANDARD => "DEFAULT")
22 | port map (
23 | O => CLK_200MHZ, -- Clock buffer output
24 | I => SYSTEM_CLK_200MHZ_P, -- Diff_p clock buffer input (connect directly to top-level port)
25 | IB => SYSTEM_CLK_200MHZ_N -- Diff_n clock buffer input (connect directly to top-level port)
26 | );
27 |
28 | -- End of IBUFGDS_inst instantiation
29 |
30 | END Behavioral;
Hier bekomme ich folenden Fehler:
1 | ERROR:HDLCompiler:69 - "D:\VHDL TUTORIAL\SIMULATOR_PULS\MAIN_STRUKTUR.vhd" Line 136: <ibufgds> is not declared.
Wenn ich es über
1 | Begin [/Begin] mache kommt ein Syntax Fehler:
2 | [vhdl]
3 | ERROR:HDLCompiler:806 - "D:\VHDL TUTORIAL\SIMULATOR_PULS\MAIN_STRUKTUR.vhd" Line 60: Syntax error near "IBUFGDS_inst".
Was mache ich den Falsch?
Igor
