1 | /**
2 | * @name Definitions for MCU Clock Frequency
3 | * Adapt the MCU clock frequency in Hz to your target.
4 | */
5 | #define XTAL 8000000 /**< clock frequency in Hz, used to calculate delay timer */
6 |
7 |
8 | /**
9 | * @name Definition for LCD controller type
10 | * Use 0 for HD44780 controller, change to 1 for displays with KS0073 controller.
11 | */
12 | #define LCD_CONTROLLER_KS0073 0 /**< Use 0 for HD44780 controller, 1 for KS0073 controller */
13 |
14 | /**
15 | * @name Definitions for Display Size
16 | * Change these definitions to adapt setting to your display
17 | */
18 | #define LCD_LINES 2 /**< number of visible lines of the display */
19 | #define LCD_DISP_LENGTH 16 /**< visibles characters per line of the display */
20 | #define LCD_LINE_LENGTH 0x40 /**< internal line length of the display */
21 | #define LCD_START_LINE1 0x00 /**< DDRAM address of first char of line 1 */
22 | #define LCD_START_LINE2 0x40 /**< DDRAM address of first char of line 2 */
23 | #define LCD_START_LINE3 0x14 /**< DDRAM address of first char of line 3 */
24 | #define LCD_START_LINE4 0x54 /**< DDRAM address of first char of line 4 */
25 | #define LCD_WRAP_LINES 0 /**< 0: no wrap, 1: wrap at end of visibile line */
26 |
27 | #define LCD_IO_MODE 1 /**< 0: memory mapped mode, 1: IO port mode */
28 | #if LCD_IO_MODE
29 | /**
30 | * @name Definitions for 4-bit IO mode
31 | * Change LCD_PORT if you want to use a different port for the LCD pins.
32 | *
33 | * The four LCD data lines and the three control lines RS, RW, E can be on the
34 | * same port or on different ports.
35 | * Change LCD_RS_PORT, LCD_RW_PORT, LCD_E_PORT if you want the control lines on
36 | * different ports.
37 | *
38 | * Normally the four data lines should be mapped to bit 0..3 on one port, but it
39 | * is possible to connect these data lines in different order or even on different
40 | * ports by adapting the LCD_DATAx_PORT and LCD_DATAx_PIN definitions.
41 | *
42 | */
43 | #define LCD_PORT PORTC /**< port for the LCD lines */
44 | #define LCD_DATA0_PORT LCD_PORT /**< port for 4bit data bit 0 */
45 | #define LCD_DATA1_PORT LCD_PORT /**< port for 4bit data bit 1 */
46 | #define LCD_DATA2_PORT LCD_PORT /**< port for 4bit data bit 2 */
47 | #define LCD_DATA3_PORT LCD_PORT /**< port for 4bit data bit 3 */
48 | #define LCD_DATA0_PIN 4 /**< pin for 4bit data bit 0 */
49 | #define LCD_DATA1_PIN 5 /**< pin for 4bit data bit 1 */
50 | #define LCD_DATA2_PIN 6 /**< pin for 4bit data bit 2 */
51 | #define LCD_DATA3_PIN 7 /**< pin for 4bit data bit 3 */
52 | #define LCD_RS_PORT LCD_PORT /**< port for RS line */
53 | #define LCD_RS_PIN 3 /**< pin for RS line */
54 | #define LCD_RW_PORT LCD_PORT /**< port for RW line */
55 | #define LCD_RW_PIN 2 /**< pin for RW line */
56 | #define LCD_E_PORT LCD_PORT /**< port for Enable line */
57 | #define LCD_E_PIN 1 /**< pin for Enable line */
58 | ...
