1 | #include <LPC21xx.H>
2 | #include <stdarg.h>
3 |
4 | void I2CISR (void) __irq ;
5 | //I2C interrupt
6 | void I2CTransferByte(unsigned Addr,unsigned Data); //Background call to start master send and receive byte transfers
7 |
8 | unsigned I2CAdresse;
9 | unsigned I2CData;
10 |
11 |
12 | int main(void)
13 | {
14 |
15 | VICVectCntl1 = 0x00000029; //select a priority slot for a given interrupt
16 | VICVectAddr1 = (unsigned)I2CISR; //pass the address of the IRQ into the VIC slot
17 | VICIntEnable = 0x00000200; //enable interrupt
18 |
19 | PINSEL0 = 0x50; //Switch GPIO to I2C pins
20 |
21 |
22 | // Initial I2C Data Rate = 100KHz(VPB=29.4912MHz)
23 | // I2C Data Rate = 29.4912MHz / 294
24 | // = 100.31KHz
25 | I2SCLH = 0x00000093; // Clock High = 147
26 | I2SCLL = 0x00000093; // Clock Low = 147
27 |
28 |
29 |
30 | while(1)
31 | {
32 | //Display löschen
33 | I2CTransferByte(0xDE,0x11); //DC1
34 | I2CTransferByte(0xDE,0x03); //lengh
35 | I2CTransferByte(0xDE,0x1B); //ESC
36 | I2CTransferByte(0xDE,0x44); //D
37 | I2CTransferByte(0xDE,0x4C); //L
38 | I2CTransferByte(0xDE,0x11 + 0x03 + 0x1B+ 'D' + 'L');
39 | }
40 | }
41 |
42 |
43 | void I2CTransferByte(unsigned Addr,unsigned Data)
44 | {
45 | I2CAdresse = Addr; //Place address and data in Globals to be used by
46 | //the interrupt
47 | I2CData = Data;
48 | I2CONCLR = 0x0000006C; //Clear all I2C settings
49 | I2CONSET = 0x00000040; //Enable the I2C interface
50 | I2CONSET = 0x00000020; //Start condition
51 | }
52 |
53 |
54 | void I2CISR (void) __irq //I2C interrupt routine
55 | {
56 |
57 | switch (I2STAT) //Read result code and switch to next action
58 | {
59 | // Start and Send byte conditions
60 |
61 | case ( 0x08): //Start bit
62 | I2CONCLR = 0x20; //Clear start bit
63 | I2DAT = I2CAdresse; //Send address and write bit
64 | break;
65 |
66 | case (0x18): //Slave address+W, ACK
67 | I2DAT = I2CData; //Write Mem,ory start address to tx register
68 | break;
69 |
70 | case (0x20): //Salve address +W, Not ACK
71 | I2DAT = I2CAdresse; //Resend address and write bi
72 | break;
73 |
74 | case (0x28):
75 | I2CONSET = 0x10; //Stop condition
76 | break;
77 |
78 | case (0x30) : //Data sent, NOT Ack
79 | I2DAT = I2CData; //Write data to tx register
80 | break;
81 |
82 |
83 | //Receive byte conditions
84 |
85 | case (0x40) : //Slave Address +R, ACK
86 | I2CONSET = 0x04; //Enable ACK for data byte
87 | break;
88 |
89 | case (0x48) : //Slave Address +R, Not Ack
90 | I2CONSET = 0x20; //Resend Start condition
91 | break;
92 |
93 | case (0x50) : //Data Received, ACK
94 |
95 | I2CONSET = 0x10; //Stop condition
96 | //Signal end of I2C activity
97 |
98 | break;
99 |
100 | case (0x58): //Data Received, Not Ack
101 | I2CONSET = 0x20; // Resend Start condition
102 | break;
103 |
104 | default :
105 | break;
106 |
107 | }
108 |
109 | I2CONCLR = 0x08; //Clear I2C interrupt flag
110 | VICVectAddr = 0x00000000; //Clear interrupt in
111 |
112 | }
