1 | /* This is a simple demo project written for use with
2 | * the HI-TECH Software PICC compiler. It may be compiled
3 | * and run on the Microchip PICDEM 2 PLUS DEMO BOARD.
4 | * Features demonstrated include driving the LCD display and
5 | * the A2D converter.
6 |
7 | Additional files required for this demo are included in the
8 | PIC\SAMPLES directories:
9 | DELAY\delay.c
10 | DELAY\delay.h
11 | lcd.c
12 | lcd.h
13 | */
14 |
15 | #include <htc.h>
16 | #include <stdio.h>
17 | //#include <pic16f887.h>
18 | #include "lcd.h"
19 | #include "delay.h"
20 | //#include "picdem2_lcd_htc.h"
21 |
22 | /* this is the maximum value of an A2D conversion. */
23 | #define MAXVOLTAGE 5
24 |
25 | void init(void){
26 | lcd_init(FOURBIT_MODE);
27 | ADON=1; /* enable A2D converter */
28 | ADIE=0; /* not interrupt driven */
29 | ADCON1=0x0E;
30 | ADCON0=1;
31 | TRISB=0x00; // Set PORTB in output mode
32 | T1CON=0x31; // turn on timer 1
33 | TMR1IE=1; // timer 1 is interrupt enabled
34 | PEIE=1; // enable peripheral interrupts
35 | GIE=1; // turn on interrupts
36 | }
37 |
38 | void interrupt isr(void){
39 | if(TMR1IE && TMR1IF){
40 | PORTB++;
41 | TMR1IF=0;
42 | }
43 | }
44 |
45 | void main(void){
46 | unsigned char last_value;
47 | unsigned char volts;
48 | unsigned char decivolts;
49 | unsigned char outString[20];
50 |
51 | init();
52 | lcd_clear();
53 | DelayMs(500);
54 | DelayMs(500);
55 | DelayMs(500);
56 | lcd_puts("test");
57 |
58 | while(1)
59 | {
60 |
61 | }
62 | }
63 |
64 |
65 |
66 | /*
67 | * LCD interface example
68 | * Uses routines from delay.c
69 | * This code will interface to a standard LCD controller
70 | * like the Hitachi HD44780. It uses it in 4 or 8 bit mode
71 | *
72 | */
73 |
74 | #include <htc.h>
75 | //#include <pic16f887.h>
76 | #include "lcd.h"
77 |
78 | static bit fourbit; // four or eight bit mode?
79 |
80 | #ifdef CHECKBUSY
81 |
82 | unsigned char
83 | lcd_read_cmd_nowait(void)
84 | {
85 | unsigned char c, readc;
86 |
87 | LCD_DATA_TRIS |= ~OUTPUT_DATA; // Set data lines to input
88 |
89 | LCD_RW = 1; // Read LCD
90 | _delay(2); // short propagation delay
91 |
92 | if (fourbit) {
93 | LCD_STROBE_READ(readc); // Read high nibble
94 | // Move 4 bits to high nibble while zeroing low nibble
95 | c = ( ( readc << 4 ) & 0xF0 );
96 | LCD_STROBE_READ(readc); // Read low nibble
97 | c |= ( readc & 0x0F ); // Or in 4 more bits to low nibble
98 | } else {
99 | LCD_STROBE_READ(readc);
100 | c = readc;
101 | }
102 | LCD_RW = 0; // Return to default mode of writing LCD
103 | LCD_DATA_TRIS &= OUTPUT_DATA; // Return to default mode of writing LCD
104 |
105 | return(c);
106 | }
107 |
108 | void
109 | lcd_check_busy(void) // Return when the LCD is no longer busy, or we've waiting long enough!
110 | {
111 | // To avoid hanging forever in event there's a bad or
112 | // missing LCD on hardware. Will just run SLOW, but still run.
113 | unsigned int retry;
114 | unsigned char c;
115 |
116 | for (retry=1000; retry-- > 0; ) {
117 | c = lcd_read_cmd_nowait();
118 | if (0==(c&0x80)) break; // Check busy bit. If zero, no longer busy
119 | }
120 | }
121 |
122 | #endif
123 |
124 | void
125 | lcd_send(unsigned char c)
126 | {
127 | LCD_EN = 1;
128 | if (fourbit) {
129 | LCD_TX(c>>4); // load upper nibble
130 | LCD_EN = 0;
131 | NOP();
132 | NOP();
133 | LCD_EN = 1;
134 | LCD_TX(c); // load lower nibble
135 | } else {
136 | LCD_DATA = c; // load both nibbles
137 | }
138 | LCD_EN = 0;
139 |
140 | }
141 |
142 | /* send a command to the LCD */
143 | void
144 | lcd_cmd(unsigned char c)
145 | {
146 | LCD_WAIT; // may check LCD busy flag, or just delay a little, depending on lcd.h
147 | LCD_RS = 0;
148 | lcd_send(c);
149 | }
150 |
151 | /* send data to the LCD */
152 | void
153 | lcd_data(unsigned char c)
154 | {
155 | LCD_WAIT; // may check LCD busy flag, or just delay a little, depending on lcd.h
156 |
157 | LCD_RS = 1;
158 | lcd_send(c);
159 | LCD_RS = 0;
160 | }
161 |
162 | /* write a string of chars to the LCD */
163 | void
164 | lcd_puts(const char * s)
165 | {
166 | while(*s)
167 | lcd_data(*s++);
168 |
169 | }
170 |
171 | /* initialize the LCD */
172 | void
173 | lcd_init(unsigned char mode)
174 | {
175 | char init_value;
176 |
177 | fourbit = 0;
178 | if (mode == FOURBIT_MODE){
179 | fourbit = 1;
180 | init_value = 0x3;
181 | }else{
182 | init_value = 0x3F;
183 | }
184 |
185 | #if (_PICDEM2_REVISION_ == 6)
186 | LCD_CTRL &= 0x0F;
187 | // All data and control lines on same TRIS register
188 | LCD_DATA_TRIS &= (OUTPUT_DATA & OUTPUT_CTRL);
189 | LCD_VCC = 1; // turn on the power to the LCD
190 | #else
191 | LCD_RS = 0;
192 | LCD_EN = 0;
193 | LCD_RW = 0;
194 |
195 | // Set control lines digital
196 | ADCON1 = 7;
197 |
198 | // Set control lines to output
199 | LCD_RS_TRIS = OUTPUT_PIN;
200 | LCD_EN_TRIS = OUTPUT_PIN;
201 | LCD_RW_TRIS = OUTPUT_PIN;
202 | // Set data lines to output
203 | LCD_DATA_TRIS &= OUTPUT_DATA;
204 | #endif
205 | __delay_ms(15);
206 | LCD_EN = 1;
207 | LCD_TX(init_value);
208 | LCD_EN = 0;
209 | __delay_ms(5);
210 | LCD_EN = 1;
211 | LCD_DATA |= init_value;
212 | LCD_EN = 0;
213 | __delay_us(200);
214 | LCD_EN = 1;
215 | LCD_DATA |= init_value;
216 | LCD_EN = 0;
217 | __delay_us(200);
218 |
219 | if (fourbit){
220 | LCD_WAIT; //may check LCD busy flag, or just delay a little, depending on lcd.h
221 | LCD_EN = 1;
222 | LCD_TX(0x2); // Set 4-bit mode
223 | LCD_EN = 0;
224 | lcd_cmd(0x28); // Function Set
225 | }else{
226 | lcd_cmd(0x38);
227 | }
228 | lcd_cmd(0xF); //Display On, Cursor On, Cursor Blink
229 | lcd_clear(); //Display Clear
230 | lcd_cmd(0x6); //Entry Mode
231 | lcd_goto(0); //Initialize DDRAM address to zero
232 | }
