Ich bekomme immer den folgenden Fehler: 45:reset = mode:2..3; ^ [0009ca] missing Symbol: ; Wäre schön, wenn mir jemand helfen kann. Habe den Grund dafür bisher nicht gefunden. M.E. sind alle ; vorhanden
1 | Name GAL_Counter ; |
2 | PartNo 00 ; |
3 | Date 28.05.2010 ; |
4 | Revision 01 ; |
5 | Designer Heiko Prinz ; |
6 | Company privat ; |
7 | Assembly None ; |
8 | Location ; |
9 | Device g22v10 ; |
10 | |
11 | /* *************** INPUT PINS *********************/
12 | PIN 1 = clk ; /* B */ |
13 | PIN 2 = up_do ; /* A */ |
14 | PIN 3 = res ; /* D-E */ |
15 | |
16 | /* *************** OUTPUT PINS *********************/
17 | PIN 20 = out3 ; /* */ |
18 | PIN 21 = out2 ; /* */ |
19 | PIN 22 = out1 ; /* */ |
20 | PIN 23 = out0 ; /* */ |
21 | |
22 | /* Definition */
23 | |
24 | field count = [out3..0]; /* Index = Bitposition! */ |
25 | $define S0 'b'0000 |
26 | $define S1 'b'0001 |
27 | $define S2 'b'0010 |
28 | $define S3 'b'0011 |
29 | $define S4 'b'0100 |
30 | $define S5 'b'0101 |
31 | $define S6 'b'0110 |
32 | $define S7 'b'0111 |
33 | $define S8 'b'1000 |
34 | $define S9 'b'1001 |
35 | $define S10 'b'1010 |
36 | $define S11 'b'1011 |
37 | $define S12 'b'1100 |
38 | $define S13 'b'1101 |
39 | $define S14 'b'1110 |
40 | $define S15 'b'1111 |
41 | |
42 | field mode = [res,up_do]; |
43 | up = mode:0; |
44 | down = mode:1; |
45 | reset = mode:2..3]; |
46 | |
47 | /* Logic Equations */
48 | sequence count { |
49 | present S0 if up next S1; |
50 | if down next S15; |
51 | if reset next S0; |
52 | present S1 if up next S2; |
53 | if down next S0; |
54 | if reset next S0; |
55 | present S2 if up next S3; |
56 | if down next S1; |
57 | if reset next S0; |
58 | present S3 if up next S4; |
59 | if down next S2; |
60 | if reset next S0; |
61 | present S4 if up next S5; |
62 | if down next S3; |
63 | if reset next S0; |
64 | present S5 if up next S6; |
65 | if down next S4; |
66 | if reset next S0; |
67 | present S6 if up next S7; |
68 | if down next S5; |
69 | if reset next S0; |
70 | present S7 if up next S8; |
71 | if down next S6; |
72 | if reset next S0; |
73 | present S8 if up next S9; |
74 | if down next S7; |
75 | if reset next S0; |
76 | present S9 if up next S10; |
77 | if down next S8; |
78 | if reset next S0; |
79 | present S10 if up next S11; |
80 | if down next S9; |
81 | if reset next S0; |
82 | present S11 if up next S12; |
83 | if down next S10; |
84 | if reset next S0; |
85 | present S12 if up next S13; |
86 | if down next S11; |
87 | if reset next S0; |
88 | present S13 if up next S14; |
89 | if down next S12; |
90 | if reset next S0; |
91 | present S14 if up next S15; |
92 | if down next S13; |
93 | if reset next S0; |
94 | present S15 if up next S0; |
95 | if down next S14; |
96 | if reset next S0; |
97 | }
