1 | #define BAUD_UART 4800UL
2 | #ifndef F_CPU
3 | #define F_CPU 1000000UL
4 | #endif
5 |
6 | #include <avr/io.h>
7 | #include <avr/interrupt.h>
8 | #include <avr/pgmspace.h>
9 | #include <avr/eeprom.h>
10 | #include <stdlib.h>
11 | #include <util/delay.h>
12 | #include <stdint.h>
13 |
14 | #define RF_PORT PORTB
15 | #define RF_DDR DDRB
16 | #define RF_PIN PINB
17 |
18 | /*
19 | rf12 ATmega32
20 |
21 | SDI <-------- MOSI (PB5)
22 | SDO --------> MIS0 (PB6)
23 | SCK <-------- SCK (PB7)
24 | nSEL <-------- SS <=> CS (PB4)
25 | nIERQ --------> INT0 (PD2)
26 | VDI --------- INT1 (PD3)
27 | */
28 |
29 | #define SDI PB5
30 | #define SDO PB6
31 | #define SCK PB7
32 | #define CS PB4
33 |
34 |
35 | void USART_Transmit_String( unsigned char *data, uint8_t length );
36 | void USART_Transmit( unsigned char data );
37 | //***************************************************************************************************
38 | #ifndef cbi //cbi(RF_PORT, CS) --> PORTB &= ~(1<<CS)
39 | #define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
40 | #endif
41 |
42 | #ifndef sbi
43 | #define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
44 | #endif
45 | //***************************************************************************************************
46 | uint16_t rf12_trans(uint16_t wert);
47 | // transfer 1 word to/from module
48 | void rf12_init(void);
49 | // initialize module
50 | void rf12_setfreq(unsigned short freq);
51 | // set center frequency
52 | void rf12_setbaud(unsigned short baud);
53 | // set baudrate
54 | void rf12_setpower(unsigned char power, unsigned char mod);
55 | // set transmission settings
56 | void rf12_setbandwidth(unsigned char bandwidth, unsigned char gain, unsigned char drssi);
57 | // set receiver settings
58 | void rf12_txdata(unsigned char *data, unsigned char number);
59 | // transmit number of bytes from array
60 | void rf12_rxdata(unsigned char *data, unsigned char number);
61 | // receive number of bytes into array
62 | void rf12_ready(void);
63 | // wait until FIFO ready (to transmit/read data)
64 |
65 | //*geaendert fuer 868Mhz
66 | #define RF12FREQ(freq) ((freq-860.0)/0.005)
67 | // macro for calculating frequency value out of frequency in MHz
68 | //***************************************************************************************************
69 | void USART_Init( void )
70 | {
71 | uint16_t baud_t = (uint16_t)((uint32_t) F_CPU/(16*BAUD_UART)-1);
72 | /* Set baud rate */
73 | UBRRH = (unsigned char)(baud_t>>8);
74 | UBRRL = (unsigned char)(baud_t);
75 | /* Enable receiver and transmitter */
76 | UCSRB = (1<<RXEN)|(1<<TXEN);
77 | /* Set frame format: 8data, 2stop bit */
78 | UCSRC = (1<<URSEL)|(1<<USBS)|(3<<UCSZ0);
79 | }
80 |
81 | void USART_Transmit( unsigned char data )
82 | {
83 | /* Wait for empty transmit buffer */
84 | while ( !( UCSRA & (1<<UDRE)) )
85 | ;
86 | /* Put data into buffer, sends the data */
87 | UDR = data;
88 | }
89 |
90 | void USART_Transmit_String( unsigned char *data, uint8_t length )
91 | {
92 | for( uint8_t i = 0; i < length; i++ )
93 | USART_Transmit( data[i] );
94 | }
95 | //***************************************************************************************************
96 | uint16_t rf12_trans(uint16_t wert)
97 | { unsigned short werti=0;
98 | unsigned char i;
99 |
100 | cbi(RF_PORT, CS);
101 | for (i=0; i<16; i++)
102 | {
103 | if (wert&32768) //0b1000 0000 0000 0000
104 | sbi(RF_PORT, SDI);
105 | else
106 | cbi(RF_PORT, SDI);
107 |
108 | werti<<=1;
109 | if (RF_PIN&(1<<SDO))
110 | werti|=1;
111 |
112 | sbi(RF_PORT, SCK);
113 | wert<<=1;
114 | _delay_us(0.3);
115 | cbi(RF_PORT, SCK);
116 | }
117 | sbi(RF_PORT, CS);
118 | return werti;
119 | }
120 |
121 | void rf12_init(void)
122 | {
123 | RF_DDR = (1<<SDI)|(1<<SCK)|(1<<CS);
124 | RF_PORT=(1<<CS);
125 | // wait until POR done
126 | for (unsigned char i=0; i<10; i++)
127 | _delay_ms(10);
128 |
129 | rf12_trans(0x80E8); //1. Configuration Command --> el und ef = 1; 868MHz band; 12,5pF
130 | //rf12_trans(0x ); //2. Power Conmmand
131 | rf12_trans(0xA67C); //3. Frequenzy setting Command --> 868,3MHz
132 | rf12_trans(0xC646); //4. Data Rate Command ---> cs=0; Bit Rate RAW Physical: 4800
133 | rf12_trans(0x9528); //5. Receiver Command ---> VDI output; Medium; 400KHz BW; -6dB -103dbRSSI
134 | //rf12_trans(0xc2AC); //6. Datafilter Command ---> al = 1; ml = 0; DQD = 3; digital = 0; analog = 1
135 | //rf12_trans(0xCA81); //7. FIFO / Reset Mode Command --> al: sync pattern = 0; FIFO fill = 0; Disable high sens; reset =1
136 | //8. Receiver FIFO Mode
137 | rf12_trans(0x6253); //9. AFC Command --> ;AFC automatic mode = Offset always; st : Strobe edge = 0;fi : Fine mode = 1
138 | // --> ;oe : Offset rgister enable = 1
139 | // --> ;en : Calculate offset = 1
140 | // --> ;Range limit = +7fres to -8fres
141 | //10. TX Config
142 | //11. Transmitter Register Write
143 | rf12_trans(0xE000); //12. Wake-Up Timer Command --> 0ms
144 | rf12_trans(0xC800); //13. Low Duty-Cycle Command --> en : Enable low duty-cycle = 0;Duty-cycle = .66666%
145 | rf12_trans(0xc0E0); //14. LB Det./Clock Div. Command--> 10MHz; VIb=2,2V
146 | }
147 | /*
148 | void rf12_setbandwidth(unsigned char bandwidth, unsigned char gain, unsigned char drssi)
149 | {
150 | rf12_trans(0x9500|((bandwidth&7)<<5)|((gain&3)<<3)|(drssi&7));
151 | }
152 |
153 | void rf12_setfreq(unsigned short freq)
154 | { if (freq<96) // 430,2400MHz //868MHz
155 | return;
156 | else if (freq>3903) // 439,7575MHz
157 | freq=3903;
158 | rf12_trans(0xA000|freq);
159 | }
160 |
161 | void rf12_setbaud(unsigned short baud)
162 | {
163 | if (baud<664)
164 | baud=664;
165 | if (baud<5400) // Baudrate= 344827,58621/(R+1)/(1+CS*7)
166 | rf12_trans(0xC680|((43104/baud)-1));
167 | else
168 | rf12_trans(0xC600|((344828UL/baud)-1)); // R=344828/Baud-1
169 | }
170 |
171 | void rf12_setpower(unsigned char power, unsigned char mod)
172 | {
173 | rf12_trans(0x9800|(power&7)|((mod&15)<<4));
174 | }
175 | */
176 | void rf12_ready(void)
177 | { cbi(RF_PORT, CS);
178 | while (!(RF_PIN&(1<<SDO))); // wait until FIFO ready
179 | }
180 |
181 | void rf12_txdata(unsigned char *data, unsigned char number)
182 | { unsigned char i;
183 | PORTD = (1<<PIND5); //TX_LED_2 on
184 | rf12_trans(0x8239); // TX on Power Command
185 | rf12_ready();
186 | rf12_trans(0xB8AA);
187 | rf12_ready();
188 | rf12_trans(0xB8AA);
189 | rf12_ready();
190 | rf12_trans(0xB8AA);
191 | rf12_ready();
192 | rf12_trans(0xB82D);
193 | rf12_ready();
194 | rf12_trans(0xB8D4);
195 | for (i=0; i<number; i++)
196 | { rf12_ready();
197 | rf12_trans(0xB800|(*data++));
198 | }
199 | rf12_ready();
200 | PORTD = (!(1<<PIND5));
201 | rf12_trans(0x8208); // TX off
202 | _delay_ms(1);
203 | }
204 |
205 | void rf12_rxdata(unsigned char *data, unsigned char number)
206 | { unsigned char i;
207 | PORTD = (1<<PIND6); //RX_LED_1 on
208 | rf12_ready();
209 | rf12_trans(0x82C8); // RX on Power Command
210 | rf12_ready();
211 | rf12_trans(0xCA81); // set FIFO mode
212 | rf12_ready();
213 | rf12_trans(0xCA83); // enable FIFO
214 |
215 | for (i=0; i<number; i++)
216 | { rf12_ready();
217 | *data++=rf12_trans(0xB000);
218 | }
219 |
220 | rf12_ready();
221 | PORTD = (!(1<<PIND6));//RX_LED off
222 | rf12_trans(0x8208); // RX off
223 | _delay_ms(1);
224 | }
225 |
226 | //**********************************************************************
227 | void send(void);
228 | void receive(void);
229 |
230 | void receive(void){
231 | unsigned char test[32];
232 | rf12_rxdata(test,32);
233 | // daten verarbeiten
234 | USART_Transmit_String( test, 32 );
235 | }
236 |
237 | void send(void){
238 | unsigned char test[]= "Dies ist ein 868MHz Test !!!\n";
239 | rf12_txdata(test,32);
240 | USART_Transmit_String( test, 32 );
241 | }
242 |
243 | int main(void){
244 |
245 | USART_Init();
246 | DDRD = 0xff;
247 |
248 | rf12_init(); // ein paar Register setzen (z.B. CLK auf 10MHz)
249 | //rf12_setfreq(RF12FREQ(868.3)); // Sende/Empfangsfrequenz auf 433,92MHz einstellen
250 | //rf12_setbandwidth(5, 1, 4); // 200kHz Bandbreite, -6dB Verstärkung, DRSSI threshold: -79dBm
251 | //rf12_setbaud(19200); // 19200 baud
252 | //rf12_setpower(0, 6); // 1mW Ausgangangsleistung, 120kHz Frequenzshift
253 |
254 | for (;;)
255 | {
256 | //send();
257 | //USART_Transmit_String("Test \n", 6);
258 | for (unsigned char i=0; i<100; i++)
259 | {_delay_ms(10);
260 | PORTD = (1<<PIND6);
261 | }
262 | receive();
263 | }
264 | }
