Guten Morgen alle zusammen,
ich versuche zur Zeit einen Funk-Chip (RFM12B) über das SPI-Interface
mit meinem AVR32-Board (EVK1101) zu verbinden.
Ich initialisiere SPI folgendermaßen:
1 | static const gpio_map_t SPI_GPIO_MAP =
2 | {
3 | {SCK, 0 }, //GPIO15, Function A // SPI Clock.
4 | {MISO, 0 }, //GPIO25, Function A // MISO.
5 | {MOSI, 0 }, //GPIO14, Function A // MOSI.
6 | {NSEL, 0 }, //GPIO16, Function A // CS0
7 | };
8 |
9 |
10 | // SPI options.
11 | static const spi_options_t spi_options =
12 | {
13 | .reg = 0, //! The SPI channel to set up.
14 | .baudrate = 500000,
15 | .bits = 8, //! Number of bits in each character (8 to 16).
16 | .spck_delay = 0, //! Delay before first clock pulse after selecting slave.
17 | .trans_delay = 4, //! Delay between each transfer/character.
18 | .stay_act = 0, //! Sets this chip to stay active after last transfer to it.
19 | .spi_mode = 1, //! Which SPI mode to use when transmitting.
20 | .modfdis = 0, //! Disables the mode fault detection.
21 | };
22 |
23 | void init_spi()
24 | {
25 | // Assign I/Os to SPI.
26 | if(gpio_enable_module(SPI_GPIO_MAP, sizeof(SPI_GPIO_MAP) / sizeof(SPI_GPIO_MAP[0])) != GPIO_SUCCESS)
27 | show_error();
28 |
29 | // Initialize as master.
30 | if(spi_initMaster(&AVR32_SPI, &spi_options) != SPI_OK)
31 | show_error();
32 |
33 | // Set selection mode: variable_ps, pcs_decode, delay.
34 | if(spi_selectionMode(&AVR32_SPI, 0, 0, 0) != SPI_OK)
35 | show_error();
36 |
37 | if(spi_selectChip(&AVR32_SPI, 0) != SPI_OK)
38 | show_error();
39 |
40 | if(spi_setupChipReg(&AVR32_SPI, &spi_options, 20000000) != SPI_OK)
41 | show_error();
42 |
43 | // Enable SPI.
44 | spi_enable(&AVR32_SPI);
45 |
46 | }
Und jetzt würde ich gerne per spi_write() befehle an meinen Chip senden.
Allerdings ist nur das erste Senden erfolgreich, alle anschliessenden
spi_write() liefern SPI_ERROR_TIMEOUT zurück:
1 | while(1)
2 | {
3 | spi_status_t status = spi_write(&AVR32_SPI, a);
4 | if(status == SPI_OK)
5 | LED_On(0b00001000);
6 | else if(status == SPI_ERROR_TIMEOUT)
7 | show_error();
8 | else
9 | show_error2();
10 | }
Merkwürdigerweise funktioniert es aber wenn ich vor jedem write erneut
ein init ausführe.
Hat jemand eine Idee was ich falsch mache?
gruß Oliver
