1 | volatile uint16_t id_tag = 0x068F;
2 | volatile uint16_t adc_data_buffer[64];
3 |
4 | ISR(CANIT_vect)
5 | {
6 | cli();
7 |
8 | uint8_t rx_data[8];
9 | uint16_t meanValue = 0;
10 | uint8_t channel;
11 | uint8_t rx_dlc = CANCDMOB & ((1<<DLC3)|(1<<DLC2)|(1<<DLC1)|(1<<DLC0));
12 |
13 | CANPAGE = CANHPMOB & 0xF0;
14 | for (uint8_t data_index = 0; data_index < rx_dlc; data_index++)
15 | *(rx_data + data_index) = CANMSG;
16 |
17 | can_clear_mob();
18 |
19 | switch(rx_data[0]){
20 | case (1):
21 | for (int i=0; i<64; i++)
22 | txCan(adc_data_buffer[i], i);
23 | break;
24 |
25 | case (2):
26 | if (rx_data[1] >= 64){ // --- invalid channel number
27 | channel = 0xE2;
28 | meanValue = 0;
29 | }
30 | else {
31 | channel = rx_data[1];
32 | meanValue = adc_data_buffer[channel];
33 | }
34 | txCan(meanValue, channel);
35 | break;
36 |
37 | } // switch (rx_data[0])
38 |
39 | rxCan();
40 | sei();
41 | }
42 |
43 | void rxCan(void)
44 | {
45 | can_msg rx_data_msg;
46 |
47 | rx_data_msg.status = 0;
48 | rx_data_msg.ext = 0; // CAN 2.0A
49 | rx_data_msg.id = id_tag; // CAN Identifier
50 | rx_data_msg.dlc = 2; // Data Length
51 | rx_data_msg.cmd = RX_DATA_MASKED; // Receive Data frame
52 |
53 | // --- use first free MOb
54 | // --- if no MOb is available wait for one
55 | rx_data_msg.handle = 0x00;
56 |
57 | can_config_mob(&rx_data_msg);
58 | }
59 |
60 | void txCan(uint16_t tx_data, uint8_t channel)
61 | {
62 | can_msg tx_data_msg;
63 | uint8_t tx_data_buffer[4];
64 | uint8_t chk = 0;
65 |
66 | tx_data_buffer[0] = channel;
67 | tx_data_buffer[1] = (uint8_t)(tx_data >> 8);
68 | tx_data_buffer[2] = (uint8_t)(tx_data);
69 |
70 | // --- calculate 8-bit LRC
71 | for (int i=0; i<3; i++)
72 | chk = chk^tx_data_buffer[i];
73 | tx_data_buffer[3] = chk;
74 |
75 | tx_data_msg.status = 0;
76 | tx_data_msg.pt_data = tx_data_buffer;
77 | tx_data_msg.ext = 0; // CAN 2.0A
78 | tx_data_msg.id = id_tag; // CAN Identifier
79 | tx_data_msg.dlc = 4; // Data Length
80 | tx_data_msg.cmd = TX_DATA; // Transmit
81 |
82 | // --- use first free MOb
83 | // --- if no MOb is available wait for one
84 | tx_data_msg.handle = can_get_free_mob();
85 | while(tx_data_msg.handle == NO_MOB)
86 | tx_data_msg.handle = can_get_free_mob_ext();
87 |
88 | can_config_mob(&tx_data_msg);
89 | }
90 |
91 | void can_clear_mob(void)
92 | {
93 | // --- Set all MOb registers to 0
94 | CANIDM4 = 0x00; CANIDM3 = 0x00; CANIDM2 = 0x00; CANIDM1 = 0x00;
95 | CANIDT4 = 0x00; CANIDT3 = 0x00; CANIDT2 = 0x00; CANIDT1 = 0x00;
96 | CANSTMOB=0x00;
97 | CANCDMOB = 0;
98 | for (int num_data = 0; num_data < 8; num_data++)
99 | CANMSG = 0;
100 | }
101 |
102 | void can_config_mob (can_msg* mob_conf)
103 | {
104 | CANPAGE = (mob_conf->handle << 4);
105 | can_clear_mob(); // to be sure MOb is cleared
106 |
107 | switch(mob_conf->cmd){
108 |
109 | case TX_DATA:
110 | can_set_id(mob_conf->ext, mob_conf->id);
111 | for (int cpt=0; cpt<mob_conf->dlc; cpt++)
112 | CANMSG = *(mob_conf->pt_data + cpt);
113 | CANCDMOB |= (mob_conf->dlc);
114 | CANCDMOB |= (1 << CONMOB0); }
115 | break;
116 |
117 | case RX_DATA_MASKED:
118 | can_set_id(mob_conf->ext, mob_conf->id);
119 | CANIDM4=0xFD; CANIDM3=0xFF; CANIDM2=0xFF; CANIDM1=0xFF;
120 | CANIDT4 &= ~(1<<RTRTAG)
121 | CANCDMOB |= (mob_conf->dlc);
122 | CANCDMOB |= (2 << CONMOB0); }
123 | break;
124 | }
