1 | 'Uart Protokoll:
2 | 'Drive : R_l -pwm_l -r_r -pwm_r
3 | 'drive:1-120-1-130
4 |
5 |
6 | $regfile = "m16def.dat"
7 | $crystal = 16000000
8 | $baud = 9600
9 |
10 | $include "sub.bas"
11 |
12 |
13 | Config Serialin = Buffered , Size = 30 , Bytematch = 13
14 | Declare Sub Serial0charmatch()
15 |
16 |
17 |
18 | 'Config Outputs
19 |
20 |
21 | Config Portc.4 = Output 'M_left1a
22 | M_left1a Alias Portc.4
23 | Config Portc.5 = Output 'M_left2a
24 | M_left2a Alias Portc.5
25 | Config Portc.6 = Output 'M_left3a
26 | M_right3a Alias Portc.6
27 | Config Portc.7 = Output 'M_left4a
28 | M_right4a Alias Portc.7
29 |
30 |
31 | 'Declare Motor-PWM
32 | Config Portb.0 = Output 'm-left-enable
33 | M_left_e Alias Portb.0
34 | Config Portb.1 = Output 'm-right-enable
35 | M_right_e Alias Portb.1
36 |
37 |
38 | 'Config Inputs
39 | Config Portd.2 = Input 'emergency-out
40 | Em_out Alias Portc.0
41 | Em_out = 1 'enable pullup
42 |
43 |
44 | 'Config Interrupts
45 | ' Config Int0 = Falling 'fallende Flanke
46 | ' On Int0 On_em_out
47 | ' Enable Int0
48 |
49 |
50 | Enable Interrupts
51 |
52 |
53 | 'Config Var's
54 | Dim Tmp As Byte
55 | Dim New_command As String * 30
56 | Dim Incoming_array(5) As String * 30
57 | Dim Command_array(5) As String * 10
58 |
59 |
60 | Dim Pwm_1 As Integer
61 | Dim Pwm_2 As Integer
62 |
63 |
64 | 'Dim Direc_l As String * 1
65 | 'Dim Pwm_l As String * 3
66 | 'Dim Direc_r As String * 1
67 | 'Dim Pwm_r As String * 3
68 |
69 |
70 | Dim Drive_command(4) As String * 15
71 |
72 |
73 |
74 | Declare Sub Exc_drive(byval Direc_l As String , Byval Pwm_l As String , Direc_r As String , Byval Pwm_r As String)
75 |
76 |
77 |
78 | Do
79 |
80 |
81 |
82 | If New_command <> "" Then
83 |
84 | New_command = Ucase(new_command)
85 |
86 | 'Anweisung aufteilen
87 | Tmp = Split(new_command , Incoming_array(1) , ":")
88 |
89 | Select Case Incoming_array(1)
90 | Case "DRIVE"
91 | Tmp = Split(incoming_array(2) , Command_array(1) , "-")
92 | ' Drive_command(1) = Command_array(1)
93 | ' Drive_command(2) = Command_array(2)
94 | ' Drive_command(3) = Command_array(3)
95 | ' Drive_command(4) = Command_array(4)
96 |
97 |
98 | 'Direc_l = Command_array(1)
99 | ' Pwm_l = Command_array(2)
100 | ' Direc_r = Command_array(3)
101 | ' Pwm_r = Command_array(4)
102 |
103 | 'Print Command_array(1) ; " " ; Command_array(2) ; " " ; Command_array(3) ; " " ; Command_array(4)
104 |
105 | ' Gosub Exc_drive
106 | Print Command_array(1) ; " "
107 | Print Command_array(2) ; " "
108 | Print Command_array(3) ; " "
109 | Print Command_array(4) ; " "
110 |
111 | Call Exc_drive(command_array(1) , Command_array(2) , Command_array(3) , Command_array(4))
112 |
113 |
114 | Case Else
115 | Print "ERROR: unknown command"
116 | End Select
117 |
118 | New_command = ""
119 | End If
120 |
121 |
122 | 'Wait 100
123 |
124 |
125 | 'Call Exc_drive( "1" , "120" , "1" , "130")
126 |
127 |
128 | Loop
129 | End
130 |
131 |
132 |
133 | Sub Serial0charmatch()
134 |
135 | Input New_command Noecho
136 | Print New_command
137 |
138 | End Sub
139 |
140 |
141 |
142 |
143 | 'Exc_drive:
144 | ' If Drive_command(1) = "1" Then Gosub Forward_left 'drive forward
145 | ' If Drive_command(1) = "0" Then Gosub Backward_left 'drive backward
146 |
147 | ' If Drive_command(3) = "1" Then Gosub Forward_right 'drive forward
148 | ' If Drive_command(3) = "0" Then Gosub Backward_right 'drive backward
149 |
150 | ' Pwm_1 = Val(drive_command(2))
151 | ' Pwm_2 = Val(drive_command(4))
152 |
153 | ' Pwm1a = Pwm_1
154 | ' Pwm1b = Pwm_2
155 |
156 | ' Print Pwm_1 ; " " ; Pwm_2
157 |
158 | 'Return
159 |
160 |
161 |
162 |
163 |
164 | Sub Exc_drive(byval Direc_l As String * 1 , Byval Pwm_l As String * 3 , Direc_r As String * 1 , Byval Pwm_r As String * 3)
165 |
166 | Print Direc_l ; " "
167 | Print Pwm_l ; " "
168 | Print Direc_r ; " "
169 | Print Pwm_r ; " "
170 |
171 |
172 | If Direc_l = "1" Then Gosub Forward_left 'drive forward
173 | If Direc_l = "0" Then Gosub Backward_left 'drive backward
174 |
175 | If Direc_r = "1" Then Gosub Forward_right 'drive forward
176 | If Direc_r = "0" Then Gosub Backward_right 'drive backward
177 |
178 | Pwm_1 = Val(pwm_l)
179 | Pwm_2 = Val(pwm_r)
180 |
181 | Pwm1a = Pwm_1
182 | Pwm1b = Pwm_2
183 |
184 | 'Print Pwm_1 ; " " ; Pwm__l ; " " ; Direc__r ; " " ; Pwm__r
185 |
186 |
187 | End Sub
188 |
189 |
190 |
191 |
192 | Forward_left:
193 | M_left1a = 1
194 | M_left2a = 0
195 | Return
196 |
197 |
198 | Backward_left:
199 | M_left1a = 0
200 | M_left2a = 1
201 | Return
202 |
203 |
204 | Forward_right:
205 | M_right4a = 1
206 | M_right3a = 0
207 | Return
208 |
209 |
210 | Backward_right:
211 | M_right4a = 0
212 | M_right3a = 1
213 | Return
214 |
215 |
216 | Stop_drive:
217 |
218 | Pwm1a = 0
219 | Pwm1b = 0
220 |
221 | M_left1a = 0
222 | M_left2a = 0
223 |
224 | M_right4a = 0
225 | M_right3a = 0
226 |
227 | Return
