ich habe einen seltsames Problem mit dem AVR ISP mkII zusammen mit
avrdude im Linux.
Verhalten ist wie folgt:
1. Ich schließe den AVR ISP mkII an das Target Board an. Der mkII
beginnt orange zu blinken, was schon mal seltsam ist.
2. Ich führe avrdude aus:
1 | sudo avrdude -c avrisp2 -p ATMEGA32 -P usb -n -B 20 -v
2 |
3 | avrdude: Version 5.10, compiled on Apr 3 2010 at 18:48:10
4 | Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
5 | Copyright (c) 2007-2009 Joerg Wunsch
6 |
7 | System wide configuration file is "/etc/avrdude.conf"
8 | User configuration file is "/root/.avrduderc"
9 | User configuration file does not exist or is not a regular file, skipping
10 |
11 | Using Port : usb
12 | Using Programmer : avrisp2
13 | Setting bit clk period : 20.0
14 | avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200045946
15 | AVR Part : ATMEGA32
16 | Chip Erase delay : 9000 us
17 | PAGEL : PD7
18 | BS2 : PA0
19 | RESET disposition : dedicated
20 | RETRY pulse : SCK
21 | serial program mode : yes
22 | parallel program mode : yes
23 | Timeout : 200
24 | StabDelay : 100
25 | CmdexeDelay : 25
26 | SyncLoops : 32
27 | ByteDelay : 0
28 | PollIndex : 3
29 | PollValue : 0x53
30 | Memory Detail :
31 |
32 | Block Poll Page Polled
33 | Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
34 | ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------
35 | eeprom 4 10 64 0 no 1024 4 0 9000 9000 0xff 0xff
36 | flash 33 6 64 0 yes 32768 128 256 4500 4500 0xff 0xff
37 | lfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
38 | hfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
39 | lock 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
40 | signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
41 | calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00
42 |
43 | Programmer Type : STK500V2
44 | Description : Atmel AVR ISP mkII
45 | Programmer Model: AVRISP mkII
46 | Hardware Version: 1
47 | Firmware Version Master : 1.13
48 | Vtarget : 4.9 V
49 | SCK period : 20.12 us
50 |
51 | avrdude: AVR device initialized and ready to accept instructions
52 |
53 | Reading | ################################################## | 100% 0.01s
54 |
55 | avrdude: Device signature = 0xffffff
56 | avrdude: Yikes! Invalid device signature.
57 | Double check connections and try again, or use -F to override
58 | this check.
59 |
60 |
61 | avrdude done. Thank you.
Was offensichtlich nicht wirklich funktioniert
3. Anschließend blinkt der mkII rot, was noch seltsamer ist.
Nach langem rumprobieren habe ich nun das AVR Studio in einer Win7 VM
probiert - und siehe da, es geht. Es blinkt nach wie vor erst orange,
aber dann geht alles.
Nun Frage ich mich: Wo hakt es beim avrdude? Irgendeine Idee?
Gruß,
Julian
