1 | 2x AT90S1200 (Atmel, MCU 1kB Flash)
2 | 1x ATMEGA128L-8AI (Atmel, MCU 128kB Flash) EUR 12,00
3 | 1x AT91SAM7S256AU-001 (Atmel, ARM MCU) EUR 10,00
4 | 2x ATMEGA8L-8AU (Atmel, MCU 8kB Flash) EUR 3,00 pro Stück
5 | 4x ATMEGA8L-8PU (Atmel, MCU 8kB Flash) EUR 3,00 pro Stück
6 | 3x ATMEGA8-16PI (Atmel, MCU 8kB Flash) [2x auf Lochraster inkl. 2x MAX232CPE, 2x Sub-D9, 2x Quarz]
7 |
8 | 2x PIC16F84-04/P (Microchip, MCU)
9 | 1x PIC16F84A-20/P (Microchip, MCU)
10 | 1x PIC16F877-04/P (Microchip, MCU) inkl. Sockel 40pol.
11 |
12 | 1x XC2S100-5TQ144C (Xilinx, Spartan 2 FPGA) EUR 15,00
13 | 1x XC9572-15 PC84C (Xilinx, CPLD PLCC84) EUR 5,00
14 |
15 | 1x ADV7125KST140 (Analog Devices, 8-Bit High Speed Video DAC)
16 | 1x ADV7125JST140 (Analog Devices, 8-Bit High Speed Video DAC)
17 | 1x FMS3818KRC (Fairchild, 8-Bit High Speed Video DAC)
18 |
19 | 11xAS7C31026-12TC (Alliance, 5V/3.3V 64K x 16 CMOS SRAM)
20 | 9x AS7C34098-12TC (Alliance, 5V/3.3V 256K x 16 CMOS SRAM)
21 | 1x HY628400A (Hynix, SRAM 512Kx8 70ns)
22 | 1x D442012LGY-B85X-MJH (NEC, SRAM)
23 |
24 | 2x AM29LV640DL-90RZI (AMD, 64Mbit Flash)
25 | 2x AM29DL322DB-70REI (AMD, 32Mbit Flash)
26 |
27 | 1x ST16C2552CJ (ST, Dual UART)
28 | 1x DM9000E (Davicom, Ethernet-MAC) inkl. Übertrager TAIMAG HA-003
29 | 2x RTL8019AS (Realtek, Ethernet-MAC) inkl. jeweils passendem Übertrager FB2022
30 | 5x DP83846AVHG (National Semiconductor, Ethernet PHY)
31 | 2x SL811HS (Cypress, USB host controller)
32 | 4x CY7C68013A-100AXC (Cypress, USB device controller) EUR 10,00 pro Stück
33 | 2x DS2480B (Maxim, RS232 to 1-Wire)
34 | 2x DS2490 (Maxim, USB to 1-Wire)
35 |
36 | 1x Sample-Box "Signal Processing Solutions" von Analog Devices (diverse SMD-ICs)
37 | 1x Sample-Box "Amplifier Kit" von Analog Devices (diverse SMD-ICs)
38 |
39 | 1x DVB-S NIM Philips SU1278/LV-2 (unbenutzt)
40 | 1x DVB-C NIM Philips CU1216L/A (ausgelötet)
41 | 1x LNBP21D2 (ST, LNBP SUPPLY AND CONTROL IC WITH STEP-UP CONVERTER AND I2C INTERFACE)
42 |
43 | 1x 68pol. PC-Card Stecker 90° (JEIDA68M) EUR 4,78
44 | 3x Compact-Flash Stecker 90°
45 |
46 | 2x Feuchtesensor Hope-RF
47 | 2x Luftdruck(?)-Sensor Hope-RF
48 |
49 | 2x Telegesis ETRX1 802.15.4 Funkmodule (ATmega128 + CC2420)
50 |
51 | 1x ELV 433MHz Sendemodul
52 | 1x ELV 433MHz Empfangsmodul
53 |
54 | 1x Gyroskop auf PCB mit Stiftleiste (unbekannt)
