1 | #include "mac.h"
2 |
3 | #include "lpc2468.h"
4 |
5 | #include "ucos_ii.h"
6 | #include "os_cpu.h"
7 |
8 | SDRAM OS_EVENT *macsem;
9 | SDRAM OS_EVENT *macmbox;
10 |
11 | void MAC_fInitialize(OS_EVENT* m)
12 | {
13 | tDWord dwID;
14 | macsem = OSSemCreate(0);
15 | macmbox = m;
16 | tByte err;
17 |
18 | PCONP |= BIT_30; /* power up the mac */
19 | PINSEL2 |= (BIT_00 | BIT_02 | BIT_08 | BIT_16 | /* select the rmii pins */
20 | BIT_18 | BIT_20 | BIT_28 | BIT_30);
21 | PINSEL3 |= (BIT_00 | BIT_02); /* select the mdio and clk pins */
22 | MAC1 = (BIT_08 | BIT_09 | BIT_10 | BIT_11 | BIT_14 | BIT_15); /* reset */
23 | Command = (BIT_03 | BIT_04 | BIT_05); /* reset the mac */
24 | MAC1 = 0; /* deassert the resets */
25 | MAC2 = 0; /* set the mac into the default state */
26 | IPGR = IPGR_DEFAULT; /* set the back-to-back inter packet gap */
27 | CLRT = CLRT_DEFAULT; /* set the collision window and retransmission count */
28 | MAXF = MAX_FRAME; /* maximum frame length */
29 |
30 | MCFG = (BIT_02 | BIT_03 | BIT_04 | BIT_15); /* divide clk by 20, reset mii */
31 | MCFG ^= BIT_15; /* deassert the mii reset */
32 | MCMD = 0; /* clear the command register */
33 | Command = (BIT_09 | BIT_06 /*| BIT_07*/); /* enable the rmii */
34 | SUPP = BIT_08; /* enable 100MBit mode */
35 | MAC_fWritePHY(PHY_BCR, BIT_15); /* reset the phy */
36 | while(MAC_fReadPHY(PHY_BCR) & BIT_15); /* wait until reset is done */
37 | dwID = (MAC_fReadPHY(PHY_ID1) << 16); /* get PHY manufacturer and revision */
38 | dwID |= (MAC_fReadPHY(PHY_ID2) & 0xFFF0);
39 | if(dwID != KSZ8001_ID) /* check if this is a KSZ8001L PHY */
40 | {
41 | return; /* abort */
42 | }
43 | MAC_fWritePHY(PHY_ICS, BIT_08 | BIT_10); /* enable link interrupt */
44 | MAC_fWritePHY(PHY_CTL, BIT_14); /* enable the link and act LEDs */
45 | MAC_fWritePHY(PHY_BCR, BIT_12 | BIT_09); /* enable & start autonegotiation */
46 |
47 | PINSEL4 |= BIT_22; /* enable EINT1 interrupt */
48 | VICVectPriority15 = 0; /* set up the phy interrupt */
49 | VICVectAddr15 = (tDWord)MAC_fPHYInterrupt;
50 | VICIntEnable |= BIT_15; /* enable the link up/down interrupt */
51 |
52 | OSSemPend(macsem, 0, &err); /* wait until link established */
53 |
54 | SA0 = (MAC_ADDRESS1 << 8) | MAC_ADDRESS2; /* set up the mac address */
55 | SA1 = (MAC_ADDRESS3 << 8) | MAC_ADDRESS4;
56 | SA2 = (MAC_ADDRESS5 << 8) | MAC_ADDRESS6;
57 | MAC_fInitRxDescriptors(); /* initialize rx descriptors */
58 | MAC_fInitTxDescriptors(); /* initialize tx descriptors */
59 |
60 | RxFilterCtrl = (BIT_01 | BIT_02 | BIT_05); /* uni-, multi- and broadcast */
61 |
62 | Command |= (BIT_00 | BIT_01); /* enable receiver and transmitter */
63 | MAC1 |= BIT_00; /* enable the receiver */
64 |
65 | VICVectPriority21 = 0; /* set up the mac interrupt */
66 | VICVectAddr21 = (tDWord)MAC_fMACInterrupt;
67 | VICIntEnable |= BIT_21; /* enable the mac interrupt */
68 | IntClear = 0xFFFFFFFF;
69 | IntEnable = BIT_03;
70 | return;
71 | }
72 |
73 | static void MAC_fPHYInterrupt(void)
74 | {
75 | tWord wInterrupt = MAC_fReadPHY(PHY_ICS); /* get the interrupt source */
76 | if(wInterrupt & BIT_00)
77 | {
78 | tWord wMode = (MAC_fReadPHY(PHY_100BTX) & (BIT_04 | BIT_03 | BIT_02));
79 | switch(wMode)
80 | {
81 | case MODE_10M_HALF_DUPLEX:
82 | {
83 | MAC2 = (BIT_04 | BIT_05 | BIT_07); /* crc, padding, half duplex */
84 | SUPP = 0; /* 10MBit mode */
85 | Command &= ~BIT_10; /* issue half duplex command */
86 | IPGT = 0x12; /* default setting for 10 MBits, half duplex */
87 | break;
88 | }
89 | case MODE_10M_FULL_DUPLEX:
90 | {
91 | MAC2 = (BIT_00 | BIT_04 | BIT_05 | BIT_07); /* crc, padding, full duplex */
92 | SUPP = 0; /* 10MBit mode */
93 | Command |= BIT_10; /* issue full-duplex command */
94 | IPGT = 0x15; /* default setting for 10 MBits, full duplex */
95 | break;
96 | }
97 | case MODE_100M_HALF_DUPLEX:
98 | {
99 | MAC2 = (BIT_04 | BIT_05 | BIT_07); /* crc, padding, half duplex */
100 | SUPP = 0; /* enable 100MBit mode */
101 | Command &= ~BIT_10; /* issue half-duplex command */
102 | IPGT = 0x12; /* default setting for 100 MBits, half duplex */
103 | break;
104 | }
105 | case MODE_100M_FULL_DUPLEX:
106 | {
107 | MAC2 = (BIT_00 | BIT_04 | BIT_05 | BIT_07); /* crc, padding, full duplex */
108 | SUPP = BIT_08; /* enable 100MBit mode */
109 | Command |= BIT_10; /* issue full-duplex command */
110 | IPGT = 0x15; /* default setting for 100 MBits, full duplex */
111 | break;
112 | }
113 | }
114 | OSSemPost(macsem);
115 | }
116 | else if(wInterrupt & BIT_02)
117 | {
118 | }
119 | EXTINT |= BIT_01;
120 | }
121 |
122 | static void MAC_fMACInterrupt(void)
123 | {
124 | tDWord dwIntStatus = IntStatus; /* get the interrupt source */
125 | if(dwIntStatus & BIT_00) /* rx overrun */
126 | {
127 | IntClear = BIT_00; /* acknowledge interrupt */
128 | }
129 | if(dwIntStatus & BIT_01) /* rx error */
130 | {
131 | IntClear = BIT_01; /* acknowledge interrupt */
132 | }
133 | if(dwIntStatus & BIT_02) /* rx finished */
134 | {
135 | IntClear = BIT_02; /* acknowledge interrupt */
136 | }
137 | if(dwIntStatus & BIT_03) /* rx done */
138 | {
139 | tWord wIdx = RxConsumeIndex; /* get the index of the next received frame */
140 | OSMboxPost(macmbox, (void*)dwRxDescriptors[wIdx * 2]);
141 | wIdx++;
142 | if(wIdx == MAC_RX_FRAGMENTS)
143 | wIdx = 0;
144 | RxConsumeIndex = wIdx;
145 | IntClear = BIT_03;
146 | }
147 | if(dwIntStatus & BIT_04) /* tx underrun */
148 | {
149 | IntClear = BIT_04; /* acknowledge interrupt */
150 | }
151 | if(dwIntStatus & BIT_05) /* tx error */
152 | {
153 | IntClear = BIT_05; /* acknowledge interrupt */
154 | }
155 | if(dwIntStatus & BIT_06) /* tx finished */
156 | {
157 | IntClear = BIT_06; /* acknowledge interrupt */
158 | }
159 | if(dwIntStatus & BIT_07) /* tx done */
160 | {
161 | IntClear = BIT_07; /* acknowledge interrupt */
162 | }
163 | if(dwIntStatus & BIT_12) /* software interrupt */
164 | {
165 | IntClear = BIT_12; /* acknowledge interrupt */
166 | }
167 | if(dwIntStatus & BIT_13) /* wakeup */
168 | {
169 | IntClear = BIT_13; /* acknowledge interrupt */
170 | }
171 | }
